Re: Engine Diaper
[Re: n20mstr]
#2885349
02/07/21 10:22 PM
02/07/21 10:22 PM
Posts: 2,056 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Belly pan has to have a 2” min depth . I have one on my car . A lot easier than a diaper Any pictures of it that you can post? Thanks, Brian
Re: Engine Diaper
[Re: n20mstr]
#2885396
02/08/21 12:36 AM
02/08/21 12:36 AM
Posts: 2,530 PA
moparacer
PA
The pans dont look like they would do a very good job of containing oil and parts if it kicks a rod out the side of the block...A diaper runs up both sides of the bock to the head gaskets.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
Re: Engine Diaper
[Re: rebel]
#2885527
02/08/21 01:34 PM
02/08/21 01:34 PM
Posts: 422 montana
BANDIT
montana
My pans are wider and attach to the frame or cage, diapers suck! Hard to get off, get oily, hold heat in motor, just have always seemed like a PIA to me. I have a brake in shop, and access to sheet aluminum. It’s kinda fun to bend up your own. I talked with our NHRA tech guy, and he says there is no minimum spec on material until you get into fuel or top Alcohol type cars. I believe the aluminum I use is .029 or .039, have to go look for sure. Usually can use Addell clamps on cage tubing and slugs elsewhere. Always just have 4 attaching points. Just my personal preference tho. Jim.
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
