M/E Wagner PCV Valve #2883403
02/03/21 03:28 AM
02/03/21 03:28 AM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
Who's running one? What's your long time experience and would you buy it again?
I'm thinking about getting one and if someone wants to get one too we can maybe set up a group buy (25% discount - we would need at least 5 valves in total).
Re: M/E Wagner PCV Valve [Re: DGS] #2883411
02/03/21 07:07 AM
02/03/21 07:07 AM
541 slobovia
A990 Online content
A990  Online Content
541 slobovia
I run one on my truck, and am very impressed. They are easy to disassemble to clean, and even have a parts kit if you lose or break something.
Well worth the money IMHO
Re: M/E Wagner PCV Valve [Re: A990] #2883434
02/03/21 09:05 AM
02/03/21 09:05 AM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
I'm running one in my 44/512 with M1 intake and a Holley Sniper. Works great.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: M/E Wagner PCV Valve [Re: ChrgrCuda] #2883464
02/03/21 10:43 AM
02/03/21 10:43 AM
Denver, CO
BigBlockGTS Offline
BigBlockGTS  Offline
Denver, CO
Are they high volume? IE- would they work well in a boosted application? I need one for my procharged Cobra.
Re: M/E Wagner PCV Valve [Re: BigBlockGTS] #2883469
02/03/21 10:53 AM
02/03/21 10:53 AM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
I was advised by others on here to try one myself. If you get a group discount , count me in !! I want to try it too.
6.50 @105.26
Re: M/E Wagner PCV Valve [Re: Kindafast] #2883482
02/03/21 12:02 PM
02/03/21 12:02 PM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
I've been running one since I put the new 'plant together. Took a bit of fiddling with the engine running in and tightening up. The most visible benefit is is no oil film seeping around seals (valve cover grommets being the most visible). I run a fairly healthy cam (235*/.55") and fairly high compression for pump gas/iron heads.
For my own unscientific testing, sitting at idle with a regular PCV valve, I'd get regular puffs of vapor out the breather (running an open K&N). With the Wagner valve dialed, no visible vapor from the breather at idle. I haven't figured out a way to check the cruise flow for some positive benefit, but no oil film seems to be all that is observable.
Dyno and track time will show it to work as advertised, I'm sure, but clean engine is the most notable benefit to the average street car. in my mind.
Re: M/E Wagner PCV Valve [Re: Kindafast] #2883491
02/03/21 12:26 PM
02/03/21 12:26 PM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
That would make 3 people getting one - two more to go.
Re: M/E Wagner PCV Valve [Re: DGS] #2883495
02/03/21 12:31 PM
02/03/21 12:31 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Will it work on my 451 with 8" idle vacuum and 15" at cruise? If so, I'm interested in one.
Re: M/E Wagner PCV Valve [Re: DGS] #2883513
02/03/21 01:04 PM
02/03/21 01:04 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
I'm in, what do I do?
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: M/E Wagner PCV Valve [Re: metallicareload] #2883551
02/03/21 01:59 PM
02/03/21 01:59 PM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
Once I have at least 5 units together I'll set up the group buy with the manufacturer and get all the details. After that I need your e-mail and you will receive a paypal invoice from ME Wagner. After you have paid the valve will directly be shipped to you.
For technical questions please talk directly to the guys at ME Wagner: http://mewagner.com/
Re: M/E Wagner PCV Valve [Re: DGS] #2883571
02/03/21 02:24 PM
02/03/21 02:24 PM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
I have one in the toolbox waiting for me to add it to my wedge which is carbureted. I plan to go EFI sometime soon. AndyF brought up a good point on PCV running on a EFI car ... the EFI IAC will try to compensate for the PCV valve flow. If that flow moves around, the IAC will try to compensate. If you are the tuner or are watching a EFI system self-learn, this might be confusing and lead to idle stability issues.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: M/E Wagner PCV Valve [Re: rumblefish72] #2883626
02/03/21 03:41 PM
02/03/21 03:41 PM
AndyF Offline
AndyF  Offline
I have two of the ME Wagner valves sitting in my take off box. I installed them for awhile on my cars and then took them off. I ended up designing my own fixed orifice PCV.
Re: M/E Wagner PCV Valve [Re: AndyF] #2883633
02/03/21 03:50 PM
02/03/21 03:50 PM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
Do you have a picture of your valve? Does is work better?
Re: M/E Wagner PCV Valve [Re: DGS] #2883663
02/03/21 04:56 PM
02/03/21 04:56 PM
Washington
madscientist Offline
Washington
I use one and half installed another 4. It’s all I use.
Re: M/E Wagner PCV Valve [Re: DGS] #2883781
02/03/21 09:33 PM
02/03/21 09:33 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
I've had one on the Coupe for about 3 years now, 238@0.050 duration, so not crazy but pretty healthy...a number of different stock-type PCV filters just weren't cutting it. This ended up being a very handy approach and I would say a prefect solution (given my weekend driver street car needs). It's adjustable, did not have any problems with mine and it's good to know the adjustability is there as the motor combination changes further.
Re: M/E Wagner PCV Valve [Re: Diplomat360] #2883984
02/04/21 01:26 PM
02/04/21 01:26 PM
moparx Offline
moparx  Offline
i bought two when the first group buy was on here.
they both work great !
beer
Re: M/E Wagner PCV Valve [Re: moparx] #2884061
02/04/21 04:26 PM
02/04/21 04:26 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
I'm in if you haven't done it yet. I've been meaning to get one, glad I saw this.
'71 Duster
'17 Ram 1500
Re: M/E Wagner PCV Valve [Re: RMCHRGR] #2884188
02/05/21 01:16 AM
02/05/21 01:16 AM
N96 D21
torqueflite Offline
torqueflite  Offline
N96 D21
I would also like to be included in a group buy if it works out , Ive been wanting to try one .
Re: M/E Wagner PCV Valve [Re: torqueflite] #2884206
02/05/21 03:55 AM
02/05/21 03:55 AM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
Great, we now have enough interested parties to start the group buy! up
So far we have:
DGS
Mike67 (other forum)
Kindafast
BigBlockGTS (maybe)
DrCharles (maybe)
metallicareload
RMCHRGR
torqueflite
I will keep the group buy open for a few more days if more people want to join. I'm going to send out PMs soon to those interested in the valve.
Re: M/E Wagner PCV Valve [Re: DGS] #2884227
02/05/21 08:12 AM
02/05/21 08:12 AM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
Sounds great to me just let me know and thanks !!!
So far we have:
DGS
Kindafast
BigBlockGTS (maybe)
DrCharles (maybe)
metallicareload
RMCHRGR
torqueflite
6.50 @105.26
