Re: 5.9 Differences?
[Re: A990]
#2880401
01/26/21 01:27 PM
01/26/21 01:27 PM
Posts: 5,386 fredericksburg,va
cudaman1969
fredericksburg,va
02 probaly uses the side mounts like my van, might have to change intake. Not sure what year the sensors changed, reason being I have an early manifold that has less hookups than the 01, either water or air temp sensor, can’t remember. But check the mounts to see if blocks have both
[Re: Hotwheelsjr]
#2880411
01/26/21 01:42 PM
01/26/21 01:42 PM
Posts: 22,083 Rio Linda, CA
John_Kunkel
Much ado about nothing
Rio Linda, CA
FWIW, the Hollander Interchange says no 5.9 interchange between '94-'01 and '02-later.
I'm supposed to respect my elders, but its getting harder and harder for me to find one now.
[Re: John_Kunkel]
#2880418
01/26/21 02:00 PM
01/26/21 02:00 PM
Posts: 372 montana
BANDIT
montana
I just swapped a 2000 tranny into a 1998, had to change the electronic pieces on valvebody so the connectors would match up. Not sure what would be different on engines. Jim.
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.50@162. 4900 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA
[Re: John_Kunkel]
#2880464
01/26/21 03:29 PM
01/26/21 03:29 PM
cudaman1969
fredericksburg,va
FWIW, the Hollander Interchange says no 5.9 interchange between '94-'01 and '02-later. I’m thinking that would mean bolt in and go, each year seems to have big and little changes made. But basic engine-heads could just about go in any year vehicle.
[Re: cudaman1969]
#2880632
01/26/21 08:33 PM
01/26/21 08:33 PM
Posts: 10,641 Kalispell Mt.
HotRodDave
Kalispell Mt.
injectors are different, easy to swap, as are most other sensors as the plugs are different. Whoremonger balancer is probably one piece on the later one and two on the earlier one, no issue there as the one piece can just be left and will work fine in place of the 2 piece. 02 and later 46re trans has a different neutral safety switch mount and no easy way to swap them with the 01 and earlier ones.
[Re: John_Kunkel]
#2880637
01/26/21 08:37 PM
01/26/21 08:37 PM
HotRodDave
Kalispell Mt.
hollander is wrong-ish about the engine swap, some later aplications use a motor mount with 4 bolts in a square pattern on the side of the block and those bosses are not on the earlier blocks so you can go one way but not the other in some rigs but it does not apply to durangos, the triangle bolt pattern is still on the later block so no issue putting it in an older one.
[Re: HotRodDave]
#2880641
01/26/21 08:39 PM
01/26/21 08:39 PM
HotRodDave
Kalispell Mt.
vacuum ports on the intake are probably different, either your gonna need to put in or remove some t fittings or better yet you should be replacing the intake plenum gasket while you have it out anyhow so just put the 99 intake with new gaskets back on the 02 engine.
[Re: A990]
#2881153
01/28/21 12:22 AM
01/28/21 12:22 AM
Posts: 10,684 Surface of the Sun, AZ
Hotwheelsjr
As far as I know nothing is different between those two years. Love those Dakotas and Durangos. fwiw, The SLT would have a 5.2, so that motor isn't the original. SLT was just a trim level. 99 Durangos were equipped with the 3.9l V6 as standard and the 5.2 and 5.9 were options. There weren't many V6 Durangos sold, so the 5.2 and 5.9 ones were the most popular and readily available. I've seen a couple SXT (base trim level) with V6s, but every SLT I've seen has been a 5.2 or 5.9. There was also a SLT "Plus" trim level that basically just added leather and premium sound (Infinity).
[Re: HotRodDave]
#2882798
02/01/21 03:29 PM
02/01/21 03:29 PM
Posts: 507 Atlanta, GA
mgoblue9798
Atlanta, GA
hollander is wrong-ish about the engine swap, some later aplications use a motor mount with 4 bolts in a square pattern on the side of the block and those bosses are not on the earlier blocks so you can go one way but not the other in some rigs but it does not apply to durangos, the triangle bolt pattern is still on the later block so no issue putting it in an older one. Correct. I used a 97 truck block for my build in a 2002 Ram Van. Was told by junk yard it would not work bc of motor mounts, but had no trouble. Of course I looked at them pretty close before building it.
