Re: Hyd roller cam
[Re: cesar perez]
#2882867
02/01/21 06:50 PM
02/01/21 06:50 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Who makes the largest hyd cam ? What is the lift with 1.5 rockers When I was looking into a hyd roller I think Howards had the "biggest" cam in the catalogs Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Hyd roller cam
[Re: fourgearsavoy]
#2882884
02/01/21 07:35 PM
02/01/21 07:35 PM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
You can run Hyd. rollers on just about any solid profile lobe. Most Hyd. profiles are actually more aggressive anyway. With regards to the Comp lobe master catalog, and depending on how big you want to go you could use the TK, CSZ, DSZ or even the QRI lobe families. I typically look and the lobe aggressiveness and comparing the duration @ .020, 050, and .200 against each other to get a feel for what lobe offers the most area under the curve to work within the overall lift and spring restraints you will have to deal with.
All this is good in theory but the limitations are with the spring you can run with the hydraulic roller lifters. Most of the time you can't run the spring you need to take advantage of the larger lobe profiles. In any case, you are probably going to have to run a short travel lifter.
AG.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Hyd roller cam
[Re: turbobitt]
#2885993
02/09/21 07:10 PM
02/09/21 07:10 PM
Posts: 1,908 Nebraska
4406bbl
Nebraska
AG. Agree on the short travel lifters, who makes them for sb/bb mopars? I have seen them for ls and gen3 hemis. I am doing a small block and am getting ready to make shims for my lifters.
