426 Hemi Casting number decode please #2882251
01/31/21 12:29 AM
01/31/21 12:29 AM
Texas
Texican Offline OP
Texican  Offline OP
Texas
I have what I believe is a replacement block 426 hemi.
This engine has been machined, built and tested on a run stand but I'm trying to determine the detail behind the actual casting numbers.
The block reads: 2468330-M
5A22
There is nothing stamped on the top pad.
Thanks for any help
Re: 426 Hemi Casting number decode please [Re: Texican] #2882258
01/31/21 01:09 AM
01/31/21 01:09 AM
That's a over the counter replacement Mega block, I can't try to look up the casting number (I don't have them) to see what bore size it was originally so hopefully some one else that can tell you will luck
Re: 426 Hemi Casting number decode please [Re: Cab_Burge] #2882276
01/31/21 04:17 AM
01/31/21 04:17 AM
NY
B1duster Offline
B1duster  Offline
NY
Mopar block mid 90’s to early 2000’s. The first ones did not have the beefed up lifter area.
This is mine, same casting #. As far as I know these only came as non-Siamese,
replacement Hemi blocks, but have thicker main webbing than an original Hemi block.
The next version carried the same casting# and had the beefed up lifter area and was
available in Non Siamese and Siamese in either wedge or Hemi.
The Mega blocks I have, both wedge and Hemi, have the beefed lifter area.
Found this:
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2710172/nos-block-2468330-m-id.html
http://www.dodgecharger.com/forum/index.php?topic=105144.0
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2744441/mega-block-questions.html
Re: 426 Hemi Casting number decode please [Re: B1duster] #2882527
01/31/21 07:09 PM
01/31/21 07:09 PM
Texas
Texican Offline OP
Texican  Offline OP
Texas
Very good information.
Thanks to all !
Re: 426 Hemi Casting number decode please [Re: Texican] #2882538
01/31/21 07:29 PM
01/31/21 07:29 PM
Texas
Texican Offline OP
Texican  Offline OP
Texas
Is there any information that shows the date of the Block ?
Is the 4 digit code next to the casting number some kind of date code ?
THanks
Re: 426 Hemi Casting number decode please [Re: Texican] #2882608
01/31/21 09:54 PM
01/31/21 09:54 PM
NY
B1duster Offline
B1duster  Offline
NY
Read through those links. They mention something about the encrypted codes of the casting foundry being impossible to crack - .... except by a connecting rod
Re: 426 Hemi Casting number decode please [Re: B1duster] #2883269
02/02/21 08:00 PM
02/02/21 08:00 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
drumhit
That was better than fair. laugh2
