Re: A new year
[Re: JCFcuda]
#2883061
02/02/21 11:45 AM
02/02/21 11:45 AM
Posts: 336 Creston, Iowa
340man4ever
Creston, Iowa
Thank you for the update! Best of wishes to you for your continued success
Curator at Adams County Speed Shop
Re: A new year
[Re: Alan Prusiensky]
#2883162
02/02/21 03:54 PM
02/02/21 03:54 PM
Posts: 774 Southington Ct.
turbobitt
Southington Ct.
Piston shape and hone was the most return I have found. Alan, I know you probably can't give away much but I was under the impression that the piston was shaped to to yield the absolute minimum volume in the cylinder ? So in other words the valve pockets and cylinder chamber shape with some minimal clearance and the compression ratio is whatever that yields ? AG.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: A new year
[Re: turbobitt]
#2883402
02/03/21 03:09 AM
02/03/21 03:09 AM
Posts: 104 New Jersey
Alan Prusiensky
New Jersey
I stumbled on to the dome back in the middle of 18 and I didn't really figure it out 100 percent until a couple of weeks ago. I always found in pretty much every engine I built put the flattest piston you can make and you will make the most power. some reason that isn't what the Hemi wants. I have a idea why the charge doesn't swirl when it enters the chamber with a flat piston it tumbles. What is so crazy I have taken apart a lot of pro stock engines built by a lot of smart people and what I have found they all have pretty flat pistons. If I make my piston flat with the exact same compression my motor will be done 75hp. Piston shape and hone was the most return I have found. Alan, I know you probably can't give away much but I was under the impression that the piston was shaped to to yield the absolute minimum volume in the cylinder ? So in other words the valve pockets and cylinder chamber shape with some minimal clearance and the compression ratio is whatever that yields ? AG.
Re: A new year
#2883606
02/03/21 03:14 PM
02/03/21 03:14 PM
Posts: 43,741 Bend,OR USA
Cab_Burge
I stumbled on to the dome back in the middle of 18 and I didn't really figure it out 100 percent until a couple of weeks ago. I always found in pretty much every engine I built put the flattest piston you can make and you will make the most power. some reason that isn't what the Hemi wants. I have a idea why the charge doesn't swirl when it enters the chamber with a flat piston it tumbles. What is so crazy I have taken apart a lot of pro stock engines built by a lot of smart people and what I have found they all have pretty flat pistons. If I make my piston flat with the exact same compression my motor will be done 75hp. [quote=turbobitt][quote=Alan Prusiensky]Piston shape and hone was the most return I have found. Alan, Dang them Hemiroid motors for being different
Re: A new year
[Re: HardcoreB]
#2886871
02/11/21 07:05 PM
02/11/21 07:05 PM
Posts: 250 Iceland
BadMoonRacer
Iceland
Everyday, you are one day less from putting Mopar in the winners circle, were it belongs in Pro Stock.
Your fans in Iceland look forward to when it happens!
Ragnar in Iceland
66 Charger, 451, .582" lift, 11" conv. 4.10:1. 4118 lbs 11.75@117 mph on regular Firestone Firehawk radials. Icelandic Champion in MC 2007, 2008, 2009 and 2022.
Re: A new year
#2887484
02/13/21 12:04 AM
02/13/21 12:04 AM
Posts: 201 PA
Scully
PA
Piston shape and hone was the most return I have found. Hi Alan, is there any chance you'd be willing to share a typical RpK, RK and RvK you strive for, if not, I understand.
Re: A new year
[Re: Scully]
#2887537
02/13/21 09:22 AM
02/13/21 09:22 AM
Alan Prusiensky
New Jersey
Rpk 7-9 Rk 18-22 Rvk 35-40 Every block and ring combination is different so what works for me probably won't for you. I'm pretty much done with trying different hone stuff this is been working pretty well lately. Piston shape and hone was the most return I have found. Hi Alan, is there any chance you'd be willing to share a typical RpK, RK and RvK you strive for, if not, I understand.
