This summer's passes.
#2880996
01/27/21 05:28 PM
01/27/21 05:28 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
So I finally got my Super Bee to Pacemakers this past summer after all the lockdowns and protocols. For those that don't know the combo, the Cliff Notes version: '69 Bee. 512 low deck stroker with an ultralight crank, 10.5:1 compression, Trick Flow 240 heads, TF Track Heat intake, Thumpercarb 950. Scott Brown solid lift cam .563/.555. 18 spline Hemi 4-speed, 3.54 gears in the S-60. Cal-Trac split mono leafs with Smith Racecraft Assassin Bars. All of my reaction times were abysmal, so I won't list them. My first pass was a 2.549 60', but I drove through the clutch. It ran 11.9649@ 60.39 MPH. My friend that went with me asked those hard questions like " Did you let off the clutch all the way?" " What did you launch at?" "What did you shift at?" All of which I really didn't have an answer to. I'm guessing the answer to the first question would be no.
My next pass was a 2.3601 60' for an 8.5159@ 90.74. It felt good, pulled nice, and I still have no idea what I launched at or shifted at. I'm still getting used to the car, and I'm still all over the place staging, launching, etc.
The last pass was worse, 2.4661 60' and 8.751 @89.82 MPH. Not exactly the passes I hoped to put down, but I'll get there.
I took it out again a couple weeks later and ran my best pass to date, 2.0722 60' and 8.3304@91.77 mph.
The next pass was my best in the car, 2.0171 60' and a 7.9606@94.35 mph. There were some passes after that, but between poor release of the line lock, the car getting too hot and stumbling on launch and some other driver-initiated flubs, they were nothing to brag about. All passes were made on Mickey Thompson Sportsman SR radials aired down to 20 pounds. I look forward to this spring to try to dial in the driver mod and see what I can get it to run before I get overcome by the urge to add more power. I'm adding 02 sensors to it to try to dial it in some more. It was a blast after 7 years of working on it, breaking it, and upgrading it to finally pull into the beams.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
Re: This summer's passes.
[Re: n20mstr]
#2881006
01/27/21 05:55 PM
01/27/21 05:55 PM
Posts: 1,030 ohio
67mprfan
ohio
Congrats on getting out to do what you enjoy , keep at maybe I'll see you at 1 of the Ohio tracks and we both can work out the bugs on learning how to drive
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: OhioMopar]
#2881010
01/27/21 06:05 PM
01/27/21 06:05 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
It's making some steam! You need some real tires!
[Re: OhioMopar]
#2881011
01/27/21 06:08 PM
01/27/21 06:08 PM
Posts: 17,886 S.E. Michigan
ZIPPY
S.E. Michigan
Good deal. Sure seems like a more race-oriented type of tire would probably help.
Rich H.
Esse Quam Videri
[Re: 67mprfan]
#2881014
01/27/21 06:09 PM
01/27/21 06:09 PM
Posts: 570 UK
rb446
UK
Well done in getting it out there, .......we were in a similar situation with our '69RR with a totally new combo last year, car had a mild 440 running a best of 12.5@106 in 2019, driver hadn't driven anything faster, our new 589ci mild street wedge combo was a big learning curve for him, starting off with an easy 11.3@119 pass ending up after 8 or so runs with a best of 10.35@130. we just hope we get the chance here in UK to actually race this year as we only have the one real track, SPR.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: justinp61]
#2881324
01/28/21 02:54 PM
01/28/21 02:54 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Nice going on getting out. Get some good tires and then she will show you alot. Ron
[Re: 67mprfan]
#2882784
02/01/21 03:10 PM
02/01/21 03:10 PM
OhioMopar
Mt.Gilead, Ohio
Congrats on getting out to do what you enjoy , keep at maybe I'll see you at 1 of the Ohio tracks and we both can work out the bugs on learning how to drive That seems like a good plan.
[Re: an8sec70cuda]
#2882785
02/01/21 03:14 PM
02/01/21 03:14 PM
OhioMopar
Mt.Gilead, Ohio
It's making some steam! You need some real tires! I agree. I'm still researching what tires to go with. I thought about trying my luck with the new MT drag radials, they are supposed to work better with a clutch, but I'm still thinking. I want to go to a shorter tire, like 26" to maybe give me a little more gear. I'm not a fan of bias plies, but I think that may be the only way to make it hook.
[Re: ZIPPY]
#2882786
02/01/21 03:15 PM
02/01/21 03:15 PM
OhioMopar
Mt.Gilead, Ohio
Good deal. Sure seems like a more race-oriented type of tire would probably help. Indeed.
[Re: justinp61]
#2882792
02/01/21 03:21 PM
02/01/21 03:21 PM
OhioMopar
Mt.Gilead, Ohio
The mph on the last pass is fast enough to run 7.20's. I'm shooting for 7.70 next. Then 7.50. Then I'd like to be more consistent at around 7.30-7.35 by the end of next season. That's about as fast as I can go without a bar. Maybe in the fall I'll shoot for some hero runs. I'd like to get the car in the low 11's, knocking on the door to 10's in the next couple years.
[Re: 383man]
#2882793
02/01/21 03:22 PM
02/01/21 03:22 PM
OhioMopar
Mt.Gilead, Ohio
Nice going on getting out. Get some good tires and then she will show you alot. Ron I sure hope so.
[Re: ProSport]
#2882795
02/01/21 03:24 PM
02/01/21 03:24 PM
OhioMopar
Mt.Gilead, Ohio
Thanks man. I'll get there.
[Re: JERICOGTX]
#2882797
02/01/21 03:28 PM
02/01/21 03:28 PM
OhioMopar
Mt.Gilead, Ohio
It does. But I drive it more than I race it. Until I find an overdrive I can either 1) afford/purchase or 2)make fit without hacking the car up, I'll stick with the 3.54.
