bronze valve guides yes or no #2880445
01/26/21 03:07 PM
01/26/21 03:07 PM
RapidRobert Offline OP
considering a new set of EQ heads, tho not from Hughes. I see on the Hughes site that they say that these are a must with EQ heads. These will be dirt track circle track raced. should I spring extra for them or pass? Thank you for your time.
Re: bronze valve guides yes or no [Re: RapidRobert] #2880463
01/26/21 03:29 PM
01/26/21 03:29 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Absolutely bronze liners in a circle track car. You mentioned bronze " valve guides", but all you need is bronze liners,.
RIP Monte Smith
Re: bronze valve guides yes or no [Re: CompWedgeEngines] #2880473
01/26/21 03:36 PM
01/26/21 03:36 PM
Got it, thank you up
