Rattle can spray undercoating #2877439
01/20/21 05:44 PM
01/20/21 05:44 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
I want to clean up and touch the fenderwells of my car.
What is the best spray can stuff avail.
I would prefer not go buy equipment for a 1 time job. Not to mention I doubt my little compressor would run a Shultz gun very well anyway
Re: Rattle can spray undercoating [Re: gtx6970] #2877447
01/20/21 06:01 PM
01/20/21 06:01 PM
Avondale AZ
Prodart440 Online work
Prodart440  Online Work
Avondale AZ
I use 3M Rubberized undercoating, part # 08883.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: Rattle can spray undercoating [Re: Prodart440] #2877451
01/20/21 06:08 PM
01/20/21 06:08 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Bill the best I ever used was 3M in a Green can. Maybe the one posted above.
Ron
Re: Rattle can spray undercoating [Re: RJS] #2877486
01/20/21 07:44 PM
01/20/21 07:44 PM
So Near, Yet So Far
topside Offline
topside  Offline
So Near, Yet So Far
Problem is the factory stuff was very coarse & heavy.
I've yet to find a rattle-can that can duplicate the OEM texture.
Seems to me it's partly the nozzles, too small to get a coarse texture.
The other half is the propellant, can't get enough solid material in the can.
** somebody please prove me wrong here, with a photo & brand **
Closest I've come to it was Resto Rick's stuff & a shutz gun, but hoo boy, whadda messy process...
Re: Rattle can spray undercoating [Re: topside] #2877678
01/21/21 04:15 AM
01/21/21 04:15 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Thanks.
I will look into the 3m stuff.
Im not looking for dead nuts oe correct. Especially prefer to not buying equipment to do this one car.
Just something decent texture and thats better than heavy black paint like some I've tried years past
Re: Rattle can spray undercoating [Re: RJS] #2878445
01/22/21 03:39 PM
01/22/21 03:39 PM
SE Pa.
LimeliteAero Offline
SE Pa.
Ron
Ron, did the green can stuff have decent texture? I know it's not going to be real toothy but as Bill mentioned Im also looking for something reasonable but don't want to have to deal with the big hog nozzle schultz guns! I want to get my wheel wells protected which are pretty visible compared to the bottom.
Re: Rattle can spray undercoating [Re: LimeliteAero] #2878485
01/22/21 04:27 PM
01/22/21 04:27 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Ive done some digging and it looks like 3M # 08883 USED to be in a green can,
Now in a white can
If I can get it local , I'll pick up a can this weekend maybe and see how it does
https://www.oreillyauto.com/detail/...7-ounce-undercoating/08883/4462184?pos=5
Re: Rattle can spray undercoating [Re: gtx6970] #2878509
01/22/21 05:02 PM
01/22/21 05:02 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
It won't be factory but I liked the way it dried and had a nice Black look compared to many that have a Brown look.
I experimented after these pictures with a bigger nozzle and that help to make it chunckie.
Ron
Re: Rattle can spray undercoating [Re: RJS] #2878544
01/22/21 06:20 PM
01/22/21 06:20 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Rattle can spray undercoating [Re: gtx6970] #2878631
01/22/21 09:56 PM
01/22/21 09:56 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Heard a couple good reports of This Transtar undercoat, will probably give it a try.
Rich H.
Esse Quam Videri
Re: Rattle can spray undercoating [Re: ZIPPY] #2881663
01/29/21 11:46 AM
01/29/21 11:46 AM
KY
65pacecar Offline
65pacecar  Offline
KY
I’ve had good luck with Wurth undercoating in the rattle can. After some practice you can get the pattern pretty close.
Re: Rattle can spray undercoating [Re: 65pacecar] #2882107
01/30/21 05:38 PM
01/30/21 05:38 PM
MN
Droop69 Offline
Droop69  Offline
MN
I have also had good luck with Wurth undercoating.
