Re: 1978 dodge d150 towing capacity
[Re: chargers777]
#2876495
01/19/21 11:40 AM
01/19/21 11:40 AM
Posts: 4,670 Star Idaho
67vertman
Star Idaho
3500 lbs towing and a 1500 lbs load capacity, if my memory serves me correctly!
My Monster are real!
Living within your means makes life pretty easy.
[Re: chargers777]
#2876564
01/19/21 01:37 PM
01/19/21 01:37 PM
Posts: 2,094 Byron, NY
W.I.N. Racing
Byron, NY
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: chargers777]
#2881510
01/28/21 11:48 PM
01/28/21 11:48 PM
Posts: 10,486 Freeport IL USA
poorboy
Freeport IL USA
They probably didn't list towing capacity for anything other then the 1 ton trucks back in the day those trucks were new.
3500 towing and 1500 weight capacity was probably about right for a d150.
I pulled a 3200 lbs dirt track car on a 1,000 lbs trailer, with probably 1,000 lbs of tools, jack, & tires in the box. On nights we were on the way home from a rain out, it was a pretty white knuckle drive. My big block truck was set up to tow and it was a very good trailer with brakes. It had the power, but I was on the edge of the suspension, steering, and brakes, even with the trailer brakes. One season was enough.
The 3/4 ton I replaced the 1/2 ton with about a year later was much better. Several years after that I replaced the 3/4 ton with a single wheel one ton, the loaded trailer didn't effect it at all. Gene
