What cordless air compressor? #2876334
01/18/21 10:29 PM
01/18/21 10:29 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
I'm tired of lugging an air bubble to the track.
Which cordless compressor do you use and are you happy with it?
'63 Dodge 330
11.19 @ 121 mph
Re: What cordless air compressor? [Re: GY3] #2876342
01/18/21 10:43 PM
01/18/21 10:43 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I use a Ryobi 18V inflator. It's slow, and the gauge is totally inaccurate, but its inexpensive and it is great for making adjustments to tire pressure. If you need to air up a flat it is going to take a minute, but it will do the job.
Mine is a few years old, they have some different ones now that may be faster and better. Mine has an analog gauge and I see some newer ones have a digital that might read correctly.
68 Barracuda Formula S 340
Re: What cordless air compressor? [Re: GY3] #2876359
01/18/21 11:26 PM
01/18/21 11:26 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
10lb CO2 tank......Best setup I have used. Got air all season.
Re: What cordless air compressor? [Re: Dragula] #2876364
01/18/21 11:33 PM
01/18/21 11:33 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I asked this very question a while back, and ended up buying this....
https://www.harborfreight.com/20v12...si-inflatordeflator-tool-only-64533.html
Bought the heavier duty 3 amp battery and charger. Have used it in my car lot tons. Airs up flats quickly. You can set it to a pre selected amount, walk away, and it shuts off when desired pressure is reached.
Got around 100 bucks in the whole deal, couldn't be happier. Battery lasts forever. Think i have charged it one time, probably aired up a dozen flats.
Will use next summer for race car. Its also very light to carry
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: What cordless air compressor? [Re: B3422W5] #2876425
01/19/21 09:41 AM
01/19/21 09:41 AM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
This was very helpful in that when I pulled it up it mentioned the DeWalt competitor and I have all DeWalt tools and batteries, so.. up
I had never really thought about this before yesterday but it seems like a good option and something to carry in the truck all the time.
'63 Dodge 330
11.19 @ 121 mph
Re: What cordless air compressor? [Re: GY3] #2876452
01/19/21 10:23 AM
01/19/21 10:23 AM
Minn
SportF Offline
SportF  Offline
Minn
Hey I bought one from "Hinkle" race cars after seeing the ad. It great, comes with its own box that has enough room to pack a lunch. You'll need that lunch if you are going to put more than a pound of air into a slick in the lanes. Comes with its own pressure gauge that is almost 1/2 inch in diameter. You can just look at the tool gauge and know you have to get your real gauge out.
If you are going to fill a tire, you can just screw the hose on to the tire and hit the trigger catch and walk away while it fills. Then later, that same day, you can come back and check on the pressure.
One small inconvenience is you have to put about a 1/2 a pound too much in a slick because that is about what you lose when disconnecting the handy screw on connection.
And it was only $50 bucks.
It's for sale if you want to try it.
Re: What cordless air compressor? [Re: SportF] #2876480
01/19/21 11:21 AM
01/19/21 11:21 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
lol so you are saying it could use some improvement?
The Ryobi one i use is trigger activated, I keep one of my wifes hair ties on the handle just in case I need to add more than a couple of lbs I can leave it unattended.
Re: What cordless air compressor? [Re: Bad340fish] #2876615
01/19/21 02:48 PM
01/19/21 02:48 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
I ended up buying the DCC020IB from DeWalt today.
I have all DeWalt stuff so it was an easy choice. $100 you can't go wrong.
Seems to be a pretty nice unit!
'63 Dodge 330
11.19 @ 121 mph
Re: What cordless air compressor? [Re: SportF] #2876938
01/19/21 11:24 PM
01/19/21 11:24 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
SportF... that was awesome! laugh2
Re: What cordless air compressor? [Re: J_BODY] #2877043
01/20/21 09:10 AM
01/20/21 09:10 AM
Minn
SportF Offline
SportF  Offline
Minn
The funny sad part is that its true.
Re: What cordless air compressor? [Re: SportF] #2877089
01/20/21 11:01 AM
01/20/21 11:01 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have a bibkle cordless one and no complaints. Of course I never expected it to inflate a tire. I will add .2-3 to my Big Bubbas pretty quickly without issue. Of course I did away with the screw on connection and added a typical inflator chuck, as that's a no brainer and pretty simple thing to do. If you are looking to put 5lbs of air then it clearly is not the right tool, thats what compressors are for. To make a last minute change in the lanes it has been the right tool
Re: What cordless air compressor? [Re: Al_Alguire] #2877114
01/20/21 11:33 AM
01/20/21 11:33 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I had intended to buy that unit.
Frankly glad i ended up with the one i got. It can pump up a dead flat tire quickly, so adding a couple pounds at the track will be a piece of cake. And it is very light and portable.
For once, i think i actually did something right... lol
1.41 best 60 foot
6.60 at 103.90 1/8
Re: What cordless air compressor? [Re: Al_Alguire] #2877117
01/20/21 11:33 AM
01/20/21 11:33 AM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
That's what I bought the DeWalt for.
I played with it early this morning. I have a CJ5 that has been sitting in the garage way too long and decided to air up one of the huge mud tires on it. It didn't take long at at all to at least get the rim off the ground.
'63 Dodge 330
11.19 @ 121 mph
Re: What cordless air compressor? [Re: Al_Alguire] #2877118
01/20/21 11:34 AM
01/20/21 11:34 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I've got a Schumacher multi-purpose, purchased at Walmart. It has the air compressor, a jumper pack, and 120 v inverter outlet, cigarette lighter outlet, USB ports, and a light. It's heavy, but yet portable, very handy, it has a built-in battery that you charged by plugging a standard extension cord into the unit. The battery lasts a long time between charges. The problem is that the air compressor will not completely fill a tire before it shuts off on some kind of a circuit breaker or temperature limit switch or something. Then you have to wait 5 or 10 minutes before it will start again. If you just need to put three or four pounds in a tire, it's fine. But if you need to completely fill a tire from empty, or even add 10 lb to a good sized slick, this should not be your choice. I'm thinking I might dig into mine and find whatever is shutting it off and bypass it. Or maybe I'll put a computer fan next to the compressor to keep it cool.
when I first bought this thing and discovered that behavior, I called Schumacher about it. They told me to bring it back to Walmart and exchange it, which I did. The new one did the same thing.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: What cordless air compressor? [Re: Hemi_Joel] #2877130
01/20/21 11:57 AM
01/20/21 11:57 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I paid $24 for it two years ago during a winter sale when I was ordering Racepak stuff which was on sale for the dragster. Perfectly happy with my "investment"
Re: What cordless air compressor? [Re: Al_Alguire] #2877511
01/20/21 08:32 PM
01/20/21 08:32 PM
East Brunswick New Jersey
N
NoFrills Offline
NoFrills  Offline
N
I have a Wal-Mart 12 volt think it's a slime brand that I took up to a Milwaukee 18 volt battery it don't seam to mind the extra voltage
Re: What cordless air compressor? [Re: Al_Alguire] #2877645
01/21/21 01:06 AM
01/21/21 01:06 AM
montana
BANDIT Offline
BANDIT  Offline
montana
Somewhere along the line, I ended up with a Craftsman jumper pack that has a portable air compressor built in, great idea. On my dragster ,I have an air pump on car for shifter and SLE, simply added an air chuck coupler so that I can plug a short hose on to air up tires in lanes. I had a couple of old air bag pumps off of used pickups, they work great as on board pumps, and the newer plastic ones are really light. Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: What cordless air compressor? [Re: BANDIT] #2877698
01/21/21 07:49 AM
01/21/21 07:49 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I had some Lowes gift cards to use up, so I picked up the Dewalt compressor. All my cordless tools are Dewalt, so it made sense, to go that route for me. Tried it out last night, and so far I really like it. Set the desired tire pressure, and walk away. Will work great in the staging lanes, to adjust a couple tenths.
69 GTX 68 Road Runner
Re: What cordless air compressor? [Re: JERICOGTX] #2877936
01/21/21 03:59 PM
01/21/21 03:59 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
i have a ridgid. has auto fill or manual fill. love ir.
Re: What cordless air compressor? [Re: trw1982] #2878090
01/21/21 09:30 PM
01/21/21 09:30 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I got one of the Jerry Bickel ones last year. One best not be in a hurry.
