Towing rear suspension, air bags or helper leafs? #2872908
01/11/21 11:08 PM
01/11/21 11:08 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Got me a real nice 2011 2500 diesel shortbed. It rides great, but when I hook the trailer to it, it drops that back like a rock. I have bags on my 2003 2500 diesel and they have been great, should I do that again, or add the helper leafs? I was also planning to add a rear sway bar if that matters.
Re: Towing rear suspension, air bags or helper leafs? [Re: Dragula] #2872937
01/12/21 12:05 AM
01/12/21 12:05 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
At least with air bags you can change the stiffness of the ride when it's empty or not towing.
Re: Towing rear suspension, air bags or helper leafs? [Re: Dragula] #2872941
01/12/21 12:11 AM
01/12/21 12:11 AM
n.c.
geo. Offline
geo.  Offline
n.c.
wondering what your tongue weight is?
Do you have an equalizer hitch?
I'm asking 'cause I just bought an '08 Mega Cab.
I used air lift bags on my Durango, but I know its more involved and $$$ on a vehicle with leaf springs.
I'd probably go with bags again, 'cause I like the unloaded ride too.
Re: Towing rear suspension, air bags or helper leafs? [Re: geo.] #2873097
01/12/21 11:36 AM
01/12/21 11:36 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Bag it and don't look back. I like to run the fill line to the fuel door. Stays nice and clean, easy to get to, and does not take a beating when mounted in the rear.
Re: Towing rear suspension, air bags or helper leafs? [Re: Dragula] #2873140
01/12/21 01:12 PM
01/12/21 01:12 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
bag it!
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Towing rear suspension, air bags or helper leafs? [Re: W.I.N. Racing] #2873397
01/12/21 08:52 PM
01/12/21 08:52 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Get a proper hitch
Angry white pureblood male
Re: Towing rear suspension, air bags or helper leafs? [Re: ruderunner] #2873417
01/12/21 09:20 PM
01/12/21 09:20 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I had bags on my 2004 quad cab 4x4 shortbed one ton and loved them. The original owner had a 200 gallon diesel tank in the back to fill his construction equipment and left them on when he traded it in. Bad it and forget it! The only thing I wish he would have put in was a built in compressor with a switch in the cab. To change stiffness there were dual fillers in the bumper to fill it manually.
JB Rhinehart, Realist
A-Body's RULE!
Re: Towing rear suspension, air bags or helper leafs? [Re: Rhinodart] #2874223
01/14/21 12:58 PM
01/14/21 12:58 PM
Dragula Offline OP
Dragula  Offline OP
Originally Posted by ruderunner
Get a proper hitch
Can you elaborate on this?
Bags it is....Might even opt for an on board compressor with pressure read out. My tongue weight must be up there pretty good, none of the 1/2 ton truck like my trailer and my '03 2500 ended up with bags on after a few years.
Re: Towing rear suspension, air bags or helper leafs? [Re: Dragula] #2874270
01/14/21 02:09 PM
01/14/21 02:09 PM
5thAve Offline
5thAve  Offline
He probably means using a weight distribution hitch.
You might want to check the tongue weight to make sure it's not overloading the hitch on the truck,
Bags sound like the best way to go. I guess that's the one disadvantage of the newer truck suspensions.
Re: Towing rear suspension, air bags or helper leafs? [Re: Dragula] #2874536
01/14/21 11:09 PM
01/14/21 11:09 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Is this for a tag trailer? If so the proper weight distribution hitch is all that's needed. Never had any issue with my 2500 with a tag. However when I went to a heavier and longer gooseneck trailer I added bags.
Re: Towing rear suspension, air bags or helper leafs? [Re: 5thAve] #2874984
01/16/21 08:07 AM
01/16/21 08:07 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Yes weight distribution hitch.
Just because the rear end doesn't squat doesn't mean the package is balanced properly. If you've never towed with weight distribution you don't know what you're missing.
Re: Towing rear suspension, air bags or helper leafs? [Re: Dragula] #2875032
01/16/21 11:03 AM
01/16/21 11:03 AM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
air bags 100%
Re: Towing rear suspension, air bags or helper leafs? [Re: mgoblue9798] #2875053
01/16/21 12:18 PM
01/16/21 12:18 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Air bags !!! I had a set on my 02 Durango, when I bought my 08 H.Q.C. I actually made brackets to adapt the same set to the 08 after 17 years one bag developed a leak I purchased a new pair and they bolted right to the same brackets. when I purchased the 08 the nose sat lower than the rear , I installed a 2 inch leveling kit the air bags are good for keeping the truck level even when not towing.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Towing rear suspension, air bags or helper leafs? [Re: 11secdart] #2904135
03/29/21 10:40 PM
03/29/21 10:40 PM
Dragula Offline OP
Dragula  Offline OP
I towed with weight distribution hitch on my RV....Never needed one with a Dodge.....I did get the air bags on...Perfect fit. I just need to wire in the compressor and the they are done. Love how they fit no messing around. Wondering if a Hellwig rear sway bar will fit with the air bags?
Feels like I need new shocks on this truck too. I am thinking Bilsteins, what say Moparts?
