Re: trashed another rear, what rear to use now? 489,742,741
[Re: dizuster]
#287518
04/13/09 11:49 PM
04/13/09 11:49 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
forget the 83/4 get a dana
Jeez', It's a 9.5:1 360 with a hydraulic cam for God's sake...and it didn't even break the ring gear or axle shaft, it broke a posi.
"Get a Dana"
How many more of them does he have to break before it won't seem so ridiculous
I've seen similiar motors scatter 727's like they were made of fine china. The combo is obviously hard on parts or this thread wouldn't be here.
As for the question, If you can't swing the dana now, go with the spool. It's cheap, and there's no pin to come out and smash your gears.
Most who say you can't drive a spool on the street, have never tried. My car is a spool(now in the dana, and was in the 8 3/4 too), and street driven. I doubt you would know the difference if you drove it
[Re: Cab_Burge]
#287519
04/13/09 11:51 PM
04/13/09 11:51 PM
dave571
a dana isint in the budget right now. its either fix the 8 3/4 or let it sit broken.
Let it sit until you can afford a GOOD Dana, small blocks with 4 speeds kill 8 3/4 eventually every time you race them, street or strip In fact any 4 speed Mopar that is raced on the street or strip will break the 8 3/4 eventually if it makes any power and hooks up at all Huh, Quicktree
When I was reading this post, I thought it was Quicktree
[Re: dave571]
#287520
04/14/09 01:29 AM
04/14/09 01:29 AM
Posts: 43,269 Bend,OR USA
Cab_Burge
It ain't my favorite Ford Nine inch fan, it is me, the 8 3/4 lover. But not in 4 speed cars that hook Sorry to disappoint you or any other true Mopar lovers like me But I would rather be truthful and help a fellow Mopar racer save some bucks and frustration on trying to do something with a 8 3/4 to make it live behind a 4 speed when it won't live 4 speed cars eat parts, you have to feed the monster, you can feed it tires or axles or U joints or ring and pinion or clutches and so on, but you got to feed it. I like feeding them tires and clutches, not U joints, axles or ring and pinion gears Been there, done that many years ago, Hemi Cuda 4 speed on nine inch tires on 8 3/4 in a 4 speed car
[Re: Cab_Burge]
#287521
04/14/09 01:57 AM
04/14/09 01:57 AM
dave571
I'm with you here.
The proof is in the pudding. He's breaking them. Plain and simple.
Isn't the definition of insanity, to keep doing the same thing over and over, and expect a different result?
I understand budget restraints(that the original poster has mentioned), so thats why I suggested the spool. Hopefully that just doesn't make the breaking point move to the caps next.
[Re: dave571]
#287522
04/14/09 07:07 AM
04/14/09 07:07 AM
Posts: 1,349 warfordsburg, PA
dirt
warfordsburg, PA
I dont want to keep doing the same thing over thats why i started this thread. i thought the cone posi units may just be weaker than the disc type. the 3 i broke were 3 different cars over about 13 years. I have smaller radial tires on it now also for the street, the sticky tires are not on it anymore unless i decide to race it and get better parts. i tried a spool in another car and i didnt like it at all.the tires churped pulling out of parking lots, the got the cops attention ,the town cops like to have something to complain about. I have a lot of center sections i could use ,489,742,741. what one is better? I would like to get a dana for it but i would just like to get it driveable again until i can afford it. I figure i will keep the sticky tires off it until i get better parts.
[Re: justinp61]
#287524
04/14/09 08:37 AM
04/14/09 08:37 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
the auburn (cone style) limited slip is a POS....some other (more expensive options) than rebuilding one of your existing clutch units would be the detroit tru-trac (torsen style limited slip) or a detroit locker.
[Re: patrick]
#287525
04/14/09 08:56 AM
04/14/09 08:56 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
The 489 or 742 case are the ones to use. Both are strong. Pick one and get a new clutch style suregrip or spend the bucks on a locker for it if you don't want to use a spool. CHIP
[Re: an8sec70cuda]
#287526
04/14/09 09:05 AM
04/14/09 09:05 AM
Posts: 52,972 Romeo MI
MR_P_BODY
If you decide to go with the 489 case put in a solid pinion spacer which is already in the 742 case, go with either as long as you have the clutch posi for it
[Re: dirt]
#287527
04/14/09 10:01 AM
04/14/09 10:01 AM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
I tore up another rear. the pin that runs throught the posi unit came out and ran into the pinion gear and destroyed it. it was the type of posi without the clutch disc in it. this is the 3rd time this type of posi has came apart on me like this. all different cars but same type of posi. the clutch type has never came apart on me like this.
is this type of posi unit just not as strong?
And yet you chose to keep using the cone type even after you killed the second one ... WHAT were you thinking ??
Cone types are GARBAGE and you should have realized that after the FIRST one failed ...
I've got a rebuilt one if you're feeling LUCKY ...
[Re: Cab_Burge]
#287528
04/14/09 10:06 AM
04/14/09 10:06 AM
JohnRR
U.S.S.A.
I have to agree with this, I killed a 3.23 single track behind a 340 with a 4 speed ... Chrysler released a TSB 1969 for 69 B bodies with an 8 3/4 and 3.91 gears in 4 speed cars , if they came in broken to replace the rear with a 4.10 Dana ...
[Re: Blown61]
#287532
04/14/09 01:20 PM
04/14/09 01:20 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Aside from a crappy posi, what kills 8.75's the caps? I have not read about anyone breaking an axle just the caps.http://www.dragracingonline.com/xi_3-toc.html http://www.risesales.com/pages/Dragracecentral/john_mccormack.html
look at this car
I had an 8-3/4" 742 case in my 74 charger with a pretty hot 440 and an automatic. It was a clutch sure grip. The first time it broke, it broke the cross shafts right through the thrust plug holes. The pieces took out the ring gear. After I bought all new pieces and a higher strength cross shaft/pinion set, it lasted a few more years, but broke the same way. I've used a Dana ever since.
IMO I recommend in this order:
Dana 60 with Power Lok sure grip (clutch) or Detroit locker 8-3/4" with Power Lok sure grip (clutches)or Detroit Locker (if available) with aluminum MP center section 8-3/4" with spool and 742 or 489 case 8-3/4" with Power Lok sure grip (clutches)with 742 or 489 case and billet caps 8-3/4" with Power Lok sure grip (clutches) with 742 or 489 case
Even though you use the Power Lok, another weak area could be exposed (usually the left cap will break). It rally comes down to shock load (4 speed) weight and engine torque.
[Re: LAR_414]
#287534
04/14/09 10:03 PM
04/14/09 10:03 PM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
A 4 speed will break 8 3/4 parts if it hooks up a bit. I would not go spool!
And a solid hub dual disc clutch will break something between the clutch and the Dana. Put some slicks on it and you will find that something
[Re: dirt]
#287535
04/15/09 01:07 AM
04/15/09 01:07 AM
JohnRR
U.S.S.A.
To everyone who keeps asking me why i keep using the cone posi here is your answer. I didnt know what was in the rear until i broke it and tor the rear apart, it was 3 different cars.I didnt use that type again. but if the car i got came with it in it there was no way to know until i broke it and tore it down. thanks for all of the advice.
Sorry , you made it sound like you just kept putting cone types in everytime you broke one hoping third time was a charm ...
[Re: dirt]
#287536
04/15/09 10:59 AM
04/15/09 10:59 AM
Posts: 3,533 Indiana
Fury Fan
Indiana
No, it was some people that replied that made it seem like he kept rebuilding them.
In typical webboard fashion, once you get more than a 1/2 page of replies your original question is distorted...
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: 446acuda]
#287537
04/15/09 11:11 AM
04/15/09 11:11 AM
Posts: 4,573 ...gently down the stream
LAR_414
You're probably right, but I plan on spinning the tires at the track. My dad's been doing it this way for 40 years. At my power level, I'll let the slicks turn a few revolutions and my parts should survive just fine!
