71 Chally tail panel. What adhesive for reflectors? #2874365
01/14/21 05:24 PM
01/14/21 05:24 PM
Columbus, GA
Michael Ecks Offline OP
Columbus, GA
Anyone restored one of these? A couple of my reflectors are checked/shattered pretty bad and so I'll be replacing them. Does anyone know what kind of adhesive was used to mount these at the factory? Since these are made of unobtainium and had just enough spares from junkyards to make a complete set I don't want them popping off going down the highway. Pic for reference, not my tailpanel.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: 17 Chally tail panel. What adhesive for reflectors? [Re: Michael Ecks] #2874727
01/15/21 01:47 PM
01/15/21 01:47 PM
moparx Offline
moparx  Offline
i can't help with the adhesive issue, but the title of your thread may not help in your quest.
maybe posting this in the restoration section would be better ?
please don't take this as a bash of any kind on you.
just trying to help.
beer
Re: 17 Chally tail panel. What adhesive for reflectors? [Re: moparx] #2874749
01/15/21 02:37 PM
01/15/21 02:37 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
beer
iagree Also, your title says 17, may want to change to 71.
Re: 17 Chally tail panel. What adhesive for reflectors? [Re: 318 Stroker] #2874766
01/15/21 03:09 PM
01/15/21 03:09 PM
Kirkland, Washington
Pacnorthcuda Offline
And “Chally” is so gay......just sayin.
Re: 17 Chally tail panel. What adhesive for reflectors? [Re: Pacnorthcuda] #2874769
01/15/21 03:24 PM
01/15/21 03:24 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
THANK YOU!!! I've owned my 73 Challenger since 73, and I've never once called it that,
or ever heard that nickname used. MCG uses it, and it's like fingernails on a blackboard to me!
Re: 17 Chally tail panel. What adhesive for reflectors? [Re: 318 Stroker] #2874860
01/15/21 06:49 PM
01/15/21 06:49 PM
MD
floyd Offline
floyd  Offline
MD
Originals had pretty thick foil backing behind the reflector lens with an adhesive backing to stick to the metal tail panel. The foil appears to have been glued to the backside of the lens with a very thin bead of adhesive along the inside edges of the lens. I’ll post some pics next time i get out to the shop.
I used super glue gel to attach the foil to the back of the reflectors and some high quality waterproof double sided tape to attach the reflectors to the tail panel.
Oh, there are two different sizes of reflectors BTW. The inboard ones are taller if I recall al correctly.
Re: 17 Chally tail panel. What adhesive for reflectors? [Re: floyd] #2874918
01/15/21 09:41 PM
01/15/21 09:41 PM
Columbus, GA
Columbus, GA
LOL saying "so gay" this day and age is pretty gay too. There's only so many letters in the title bar. Was trying to conserve them. Pretty sure everyone would know what car I was talking about if I hadn't mistyped "17" instead of '71. And if Chally (which I don't actually use either) keeps someone from replying, then screw 'em.
Thanks floyd for offering actual useable info. Got the two sizes part (yes inboard is the tall one) and the foil back though I am looking at replacing it with pieces of modern retroreflective tape. Going to test both and see which one does better behind the lens once I get them cleaned and polished. Also saw how the factory did it, just wasn't sure what they used to get it to hang on there for 50 years. I was trying to avoid superglue because the fumes have a habit of creating haze on nearby plastics. I take it you didn't have any problems like that? Are their different thicknesses of mounting tape out there? I tried the mounting tape option on one that is currently on the car but it was thick enough to make it sit out too far from the rest of the tail light surround for my taste.
Re: 17 Chally tail panel. What adhesive for reflectors? [Re: Michael Ecks] #2874959
01/16/21 12:58 AM
01/16/21 12:58 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
How about e6000? I've used it on several different projects and the stuff remains flexible. I used clear to attach clear vinyl tubing to metal patio furniture legs. Split the hose glue and the stuff is still stuck and has not yellowed, furniture is outside, alll year going on 6 yrs now. I've started using it for all sorts of projects and have not had a failure. I like it stays flexible.
Re: 17 Chally tail panel. What adhesive for reflectors? [Re: srt] #2874999
01/16/21 09:15 AM
01/16/21 09:15 AM
MD
floyd Offline
floyd  Offline
MD
It’s been long enough that I can’t remember precisely what I used but I’m pretty sure it was crazy glue and I didn’t get any fogging. For the foil, I used the aluminum tape used for duct work. I still have some extra parts in a box and will check to see what type of 2-sided tape I used.
Re: 17 Chally tail panel. What adhesive for reflectors? [Re: floyd] #2875001
01/16/21 09:26 AM
01/16/21 09:26 AM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
Not that this helps with the posters question but he did say they were unobtainium, Laysons Restorations shows the reflectors on their site for those in need.
Re: 17 Chally tail panel. What adhesive for reflectors? [Re: Suregrip391] #2875009
01/16/21 09:50 AM
01/16/21 09:50 AM
Columbus, GA
Columbus, GA
Laysons does carry replacements. But from the posts I tracked them down from, they are reportedly a little shorter than the factory ones leaving a gap exposed between the reflector and tail light surround. Also they and most of the lenses they carry are on major backorder according to Laysons when I called last week.
Re: 17 Chally tail panel. What adhesive for reflectors? [Re: 318 Stroker] #2875244
01/16/21 08:03 PM
01/16/21 08:03 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
x3
Mo' Farts
Moderated by "tbagger".
Re: 17 Chally tail panel. What adhesive for reflectors? [Re: Grizzly] #2875270
01/16/21 09:33 PM
01/16/21 09:33 PM
MD
floyd Offline
floyd  Offline
MD
The repros I’ve seen didn’t include the adhesive backing. I’m not sure if they even had the foil backing?
I checked my leftovers and no sign of a the two-sided tape I used. It’s been a few years and I can’t remember exactly. Sorry.
Re: 17 Chally tail panel. What adhesive for reflectors? [Re: Suregrip391] #2878556
01/22/21 06:55 PM
01/22/21 06:55 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
DO NOT USE the reproduction lenses !!!! They are WAY to small ! NOBODY makes a correct repro of these lenses .
