Pushrod makers #2873539
01/13/21 08:12 AM
01/13/21 08:12 AM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Need a new set of pushrods made for a small block. Nothing crazy, just swapped to Trick Flow 190 heads and need a little longer pushrod. Fairly mild flat tappet cam. I know of Trend, Smith Brothers and Manton. Any other place that makes them that I should check out?
Re: Pushrod makers [Re: DusterKid] #2873551
01/13/21 09:09 AM
01/13/21 09:09 AM
okla.
sam64 Offline
sam64  Offline
okla.
Comp cams,
Re: Pushrod makers [Re: DusterKid] #2873561
01/13/21 09:41 AM
01/13/21 09:41 AM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Steward Performance
Re: Pushrod makers [Re: GTS340] #2873637
01/13/21 11:10 AM
01/13/21 11:10 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
You mentioned the best three. I prefer Manton but have used Trickflow in a pinch
Re: Pushrod makers [Re: DusterKid] #2873641
01/13/21 11:16 AM
01/13/21 11:16 AM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
I had a problem with some Trend push rods, they went above & beyond to help me, they sent me the correct new ones at no charge, the best customer service & product I have ever had !!!
Re: Pushrod makers [Re: CSK] #2873650
01/13/21 11:23 AM
01/13/21 11:23 AM
an8sec70cuda Offline
I use either Manton or Smith Brothers...no real preference. Excellent service from both. up
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Pushrod makers [Re: an8sec70cuda] #2873653
01/13/21 11:25 AM
01/13/21 11:25 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Manton has made a couple of sets for me. Great service and product.
'63 Dodge 330
11.19 @ 121 mph
Re: Pushrod makers [Re: DusterKid] #2873745
01/13/21 01:21 PM
01/13/21 01:21 PM
PA
Harry's Taxi 2 Offline
PA
https://stewardperformance.com/
Your Dad knows Denny.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Pushrod makers [Re: Harry's Taxi 2] #2873771
01/13/21 01:50 PM
01/13/21 01:50 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have been real happy with smith brothers, but honestly haven't use anyone else.
68 Barracuda Formula S 340
Re: Pushrod makers [Re: Bad340fish] #2873805
01/13/21 02:38 PM
01/13/21 02:38 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
same here. Always been good customer service
....BAD A$$ STREET CAR.....
Re: Pushrod makers [Re: Bad340fish] #2873807
01/13/21 02:39 PM
01/13/21 02:39 PM
Being on the west coast I've used both Smith Bros and Mantons.
Manton are head and shoulders better in quality and customer service than Smith Bros. twocents scope
Re: Pushrod makers [Re: DusterKid] #2874217
01/14/21 12:42 PM
01/14/21 12:42 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I suffered from a valve train instability/harmonic issue a few years back that almost cost my a motor. Dwayne Porter traced the problem back to improper valve spring installed height and issues with valves spring tension versus the capacity of the hydraulic lifters available for big block Mopars to handle spring loads heavy enough to control the hydraulic lifters with out them collapsing from the pressures. My initial setup lost control of the valvetrain at around 5800rpm. A power dip was evident on my dyno sheet. Dwayne spotted it right off.
I switched to solid rollers to bypass the problem. I also used Mike at B3 Racing to get a geometry correction kit and ordered custom rocker arms from T&D to adjust my valve train geometry to a more optimum relationship and up-sized and upgraded my pushrods to a set of 7/16" Manton Stage 5 parts. Their customer service, tech advice and turn around time were great.
In the end, these changes gave me one of the smoothest reving and running RB motors I have ever experienced in 40 some odd years. My lash has only needed a minor(.001-.0015") adjustment in 3000+ miles. I usually shift below 7k rpm at the max, and there is an entire magnitude of harmonics or higher frequency vibrations that is noticably absent from this engine now. I believe it is due to the optimized valvetrain geometry, the stiffer pushrods etc. Almost all my previous 440's had the same noise/vibrations while reving.
Re: Pushrod makers [Re: DusterKid] #2874261
01/14/21 01:36 PM
01/14/21 01:36 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Steward Performance
Re: Pushrod makers [Re: DusterKid] #2874286
01/14/21 02:34 PM
01/14/21 02:34 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
A thicker wall and proper length is all you need imo.Are you keeping stock rocker gear?If you can get the length Comp should be fine.
Re: Pushrod makers [Re: Clanton] #2874763
01/15/21 03:01 PM
01/15/21 03:01 PM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
I can’t say enough good about Manton.
I am an amateur with a lot questions and ideas and they are very patient and responsive
Re: Pushrod makers [Re: Wirenut] #2874859
01/15/21 06:46 PM
01/15/21 06:46 PM
Georgia and Washington
JMCarter Offline
JMCarter  Offline
As already mentioned, Steward Performance
Re: Pushrod makers [Re: JMCarter] #2874994
01/16/21 08:48 AM
01/16/21 08:48 AM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
TREND or Smith Brothers. Both excellent companies to do business.
