Towing rear suspension, air bags or helper leafs?
#2872908
01/11/21 10:08 PM
01/11/21 10:08 PM
Posts: 11,293 Taxes & Virus's R-US, NY
Dragula
Got me a real nice 2011 2500 diesel shortbed. It rides great, but when I hook the trailer to it, it drops that back like a rock. I have bags on my 2003 2500 diesel and they have been great, should I do that again, or add the helper leafs? I was also planning to add a rear sway bar if that matters.
Re: Towing rear suspension, air bags or helper leafs?
[Re: Dragula]
#2873140
01/12/21 12:12 PM
01/12/21 12:12 PM
Posts: 1,626 Byron, NY
W.I.N. racing
Byron, NY
FOR SALE'02 D1500, Blown/Inj KB, Veny Heads,Bruno/CS2,Dana 60 FOR SALE '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T8 '60 Willys CJ5 '01 International LPX - Project, 8.3L Cummins, Allison 2000 '64 Plymouth Valiant S/P, 528 Hemi, 2spd
[Re: ruderunner]
#2873417
01/12/21 08:20 PM
01/12/21 08:20 PM
Posts: 39,708 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I had bags on my 2004 quad cab 4x4 shortbed one ton and loved them. The original owner had a 200 gallon diesel tank in the back to fill his construction equipment and left them on when he traded it in. Bad it and forget it! The only thing I wish he would have put in was a built in compressor with a switch in the cab. To change stiffness there were dual fillers in the bumper to fill it manually.
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#2874223
01/14/21 11:58 AM
01/14/21 11:58 AM
Dragula
Can you elaborate on this? Bags it is....Might even opt for an on board compressor with pressure read out. My tongue weight must be up there pretty good, none of the 1/2 ton truck like my trailer and my '03 2500 ended up with bags on after a few years.
[Re: 5thAve]
#2874984
01/16/21 07:07 AM
01/16/21 07:07 AM
Posts: 2,720 ohio
ruderunner
ohio
He probably means using a weight distribution hitch. You might want to check the tongue weight to make sure it's not overloading the hitch on the truck,
Bags sound like the best way to go. I guess that's the one disadvantage of the newer truck suspensions. Yes weight distribution hitch. Just because the rear end doesn't squat doesn't mean the package is balanced properly. If you've never towed with weight distribution you don't know what you're missing.
[Re: mgoblue9798]
#2875053
01/16/21 11:18 AM
01/16/21 11:18 AM
Posts: 4,419 new jersey usa
11secdart
new jersey usa
Air bags !!! I had a set on my 02 Durango, when I bought my 08 H.Q.C. I actually made brackets to adapt the same set to the 08 after 17 years one bag developed a leak I purchased a new pair and they bolted right to the same brackets. when I purchased the 08 the nose sat lower than the rear , I installed a 2 inch leveling kit the air bags are good for keeping the truck level even when not towing.
