Re: Correct name for Dana antislip unit
[Re: fastmark]
#2873526
01/13/21 05:41 AM
01/13/21 05:41 AM
Posts: 5,364 Port Huron, Michigan
MI_Custumz
Read on a couple pages, take it as you will:
1958-1969 used the Dana Power-Lok (# 2881487) 1969-1974 used the Borg Warner Spin Resistant (# 2881343)
(Source: 1984 Direct Connection Chassis Book) 9 ¾ AKA Dana 60 The early rear ends were 23 tooth "Power Lok" (1966 - 1969) differentials. In 1970 the 9 ¾ went to 35 tooth axle shafts and were called "Track Lok" differentials. Dana Power Lok, 1962 - 1969 which are rebuildable (clutch packs) Borg-Warner Spin Resistant, Late 1969 - 1974 which are not rebuildable (cone type)
[Re: MI_Custumz]
#2873531
01/13/21 06:44 AM
01/13/21 06:44 AM
Posts: 5,677 Abilene, Texas
fastmark
Abilene, Texas
Ok. I have a question. All the Danas I’ve built so far have the Power Lok. I’ve got a 73 Dana rebuilt by DoctorDiff. It has a Track Lok. I’ve got a 70 b body from a charger that has never had the cover off. So your saying it should have the Track Lok and all ebodies as well? I was considering cutting this 73 Dana down to ebody width. I can’t seem to give it away as a 73 b body. I’ve got extra axles and a Power Lok but they are 68 b body.
[Re: fastmark]
#2873542
01/13/21 07:22 AM
01/13/21 07:22 AM
Posts: 1,218 Tucson AZ,
MadMopars
Tucson AZ,
I was considering cutting this 73 Dana down to ebody width. I can’t seem to give it away as a 73 b body. Define "give it away".  Seriously, I'd love to save it from getting cut down and put it in my 73 GTX. If you are considering letting it go, shoot me a PM and let me know.
[Re: V194]
#2874219
01/14/21 11:47 AM
01/14/21 11:47 AM
Posts: 1,192 central il.
second 70
central il.
We have sure grip but what is the official MoPar name for the "posi" in a 1970 Dodge dana 60. 70 had both powr- loc and trac-loc check housing number the trac-loc is a weaker unit.
[Re: moparx]
#2874961
01/16/21 12:21 AM
01/16/21 12:21 AM
Posts: 3,841 Moved to N.E. Tennessee
GomangoCuda
i see 5.13 and 5.38 ratios were listed. i wonder how many of those were sold ? Notice the years an axle lengths of those. They never came in any production car. They were sold over the counter as Direct Connection items for building race cars. IF I remember correctly they had 44" or 52" housings and fit cars that had the springs moved into the frame rails.
[Re: GomangoCuda]
#2875017
01/16/21 09:11 AM
01/16/21 09:11 AM
Posts: 1,766 Michigan
Transman
i see 5.13 and 5.38 ratios were listed. i wonder how many of those were sold ? Notice the years an axle lengths of those. They never came in any production car. They were sold over the counter as Direct Connection items for building race cars. IF I remember correctly they had 44" or 52" housings and fit cars that had the springs moved into the frame rails. Exactly.
