Six pack solenoid #2874124
01/14/21 07:08 AM
01/14/21 07:08 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Where is the best place to get one of these for a 69 six pack. I see them on eBay and they are pricy to say the least. I’ve heard the new repos are junk that last about a month. I don’t need one with the oem part number.
Re: Six pack solenoid [Re: fastmark] #2874137
01/14/21 07:49 AM
01/14/21 07:49 AM
MI, Livingston
P
plymth70 Online content
plymth70  Online Content
P
MI, Livingston
I am also looking for one. Have heard the same about repo's.
Re: Six pack solenoid [Re: plymth70] #2874140
01/14/21 08:00 AM
01/14/21 08:00 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I found who I was looking for on eBay but his prices are the same on his store. Hoover auto parts out of Idaho Falls. $399.95. That’ll almost make you spit your coffee out. Don’t tell my wife!
Re: Six pack solenoid [Re: fastmark] #2874165
01/14/21 10:06 AM
01/14/21 10:06 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
We don't use one on our 6 bbl, no ill effects to my knowledge....
Joe
Re: Six pack solenoid [Re: fastmark] #2874168
01/14/21 10:22 AM
01/14/21 10:22 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Is correct appearance important? or merely function?...if function is your goal, Holley has a universal solenoid, but you'll need to modify or fabricate your own bracket to mount it as the barrel diameter is larger, but they are reliable, I've been running then for a few decades on my sixpack cars with zero issues....otherwise you'll need to pony up the coin for "aesthetics"
Mike
Re: Six pack solenoid [Re: DAYCLONA] #2874229
01/14/21 01:06 PM
01/14/21 01:06 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
One car is a clone but he wants it to look right. The other is a real A12. I’m afraid I will need it. He did not before because the company ratio was 8.1. We’ve raised it to 10.3 with alum heads. It gets hot in Texas.
Re: Six pack solenoid [Re: fastmark] #2874274
01/14/21 02:17 PM
01/14/21 02:17 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
The "high idle" solenoid is used on the 3x2's to minimize or prevent "dieseling" when the engine is shut off. The 3x2's have a higher idle RPM and without the high idle solenoid the throttle does not close all the way and you can have engine run on or "dieseling" as Chrysler calls it. If you don't have the issue without the solenoid then that's a good thing but if it happens, well the answer is obvious what's needed wink
Also the original high idle solenoid is and was sourced through GM from their Delco Remy parts and it was also used on a '60's Pontiac GTO so maybe find a Pontiac GTO website/forum or Facebook and see if there is a reproduction made or a source for OE? If you find one on a GTO forum please let us know, thanks.........................................(I tried a few years ago, found which model and year it was used on but have to dig to find the info, back later if I find it)
Mike
Re: Six pack solenoid [Re: A12] #2874278
01/14/21 02:24 PM
01/14/21 02:24 PM
A727Tflite Offline
A727Tflite  Offline
Mike
Mike, are you aware of any differences between the Street Hemi solenoid and the 6 BBL ?
Re: Six pack solenoid [Re: A727Tflite] #2874289
01/14/21 02:39 PM
01/14/21 02:39 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
I found a couple Standard Products ES6 solenoids 4-5 years ago. They are also hard to find these days. Maybe someone will reach out to standard and see if the could re-introduce. Link
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Six pack solenoid [Re: A727Tflite] #2874301
01/14/21 02:53 PM
01/14/21 02:53 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Mike
Transman, the biggest visual difference with the A12 ('69-1/2) versus say the '70 is a hex on the A12 versus round "pad" (need help with a term?). I think the Street Hemi solenoids have round pads?? Function should be similar, maybe the "throw" of the solenoid is different? Where the wire attaches to the solenoid (male spade) is also a little different along with the angle of the attached mounting bracket to the solenoid body. I think either can be made to function it's mostly optics correctness but could be wrong.
Mike
Re: Six pack solenoid [Re: A12] #2874304
01/14/21 02:57 PM
01/14/21 02:57 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
See page 11 "What The Solenoid Does"
Master Tech Ref Book 69 12 page 10a.jpgMaster Tech Ref Book 69 12 page 11a.jpgMaster Tech Ref Book 69 12 page 12a.jpg
Re: Six pack solenoid [Re: A12] #2874314
01/14/21 03:13 PM
01/14/21 03:13 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Deleted
Re: Six pack solenoid [Re: A12] #2874317
01/14/21 03:17 PM
01/14/21 03:17 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Some solenoid images I found, just throwing them out here.
solenoid OEM Delco Remy 1969 1114420 copy.jpgSolenoid DR 1114429 and Standard ES6 copy.jpgsolenoid 00002 copy.jpgsolenoid 00001 copy.jpg
Re: Six pack solenoid [Re: A12] #2874327
01/14/21 03:51 PM
01/14/21 03:51 PM
A727Tflite Offline
A727Tflite  Offline
Thanks Mike 👍
Re: Six pack solenoid [Re: A727Tflite] #2874338
01/14/21 04:16 PM
01/14/21 04:16 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
'68-'72 Pontiac solenoid...............has the look but male spade is around the back
some images of DR1114423 '68-'72 Pontiac
Re: Six pack solenoid [Re: A12] #2874341
01/14/21 04:25 PM
01/14/21 04:25 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
The round top is the '70-'71 3x2 solenoid plunger. The HEX top (which looks like a standard 1/4-20 bolt shock) is the '69 A12 solenoid plunger (at least that's how I have the image labeled for years ) That seems way too easy to just modify a round plunger to a hex. Can anyone confirm the hex bolt in the image is actually one out of a DR1114420?
Re: Six pack solenoid [Re: A12] #2874484
01/14/21 08:57 PM
01/14/21 08:57 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Well, after looking around, I guess the best deal out there is through Hoover auto parts In Idaho Falls. According to his website and eBay, he takes bare NOS solenoids and adds the bracket and part no and then replates them. They do look nice and he can make either 69 or 70. $399.00 He sells the plungers separately for each year. One year guarantee. There is an nos one on b bodies for 1500 obo! Starting out at that price makes it hard to make a offer that won’t insult him.
Re: Six pack solenoid [Re: fastmark] #2874504
01/14/21 09:36 PM
01/14/21 09:36 PM
South San Francisco, Ca
70sixpkrt Online content
70sixpkrt  Online Content
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Six pack solenoid [Re: fastmark] #2874537
01/14/21 11:14 PM
01/14/21 11:14 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
. . . There is an nos one on b bodies for 1500 obo!
Holy smokes!!! I refinished 3 for my project. Been holding the other 2 in case anything goes south but that price could make a guy question his plan
Re: Six pack solenoid [Re: AAR#2] #2874607
01/15/21 07:33 AM
01/15/21 07:33 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
It’s his stuff. He can ask what he wants. I have two of the ES6 from Standard that will work for me on my cars. I bought them 35 years ago, cheap. You can’t hardly see the part number on my original on the car with the air cleaner anyway.
Looking at all the evidence, looks like Hoover’s is the best deal out there. I constantly tell my customers, “ We don’t live in the day of 20 cent hamburgers anymore.”
