Ignition points for dual point cars #2873328
01/12/21 05:22 PM
01/12/21 05:22 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
I know, Im living in the stone age. But I prefer to retain my original ignition system , at least till I can no longer get service parts for it anyway .
That said,
Whats the best source and or brand for points and condensers.
Also, is the original condenser a wire or metal strap
Re: Ignition points for dual point cars [Re: gtx6970] #2873331
01/12/21 05:25 PM
01/12/21 05:25 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
weren't they the same as a straight 6 chevy? Or has old age caught up to me.
Re: Ignition points for dual point cars [Re: gtx6970] #2873334
01/12/21 05:41 PM
01/12/21 05:41 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
I highly recommend reaching out to Ray aka HALIFAXHOPS on FBBO. Good guy and has the good stuff. I'm sure others will agree.
halifaxhops AT hotmail.com
Let me see if I can find his card...
Common sense is a flower that does not grow in everybody's garden
Re: Ignition points for dual point cars [Re: Ron_M] #2873351
01/12/21 06:05 PM
01/12/21 06:05 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Thanks, They are still readily avail in the aftermarket. And my brother runs a parts house back in Ky.
So getting them is not my problem
Just want to source quality parts or maybe find nos OEM if I can or should.
So far I think OEM condensor has a metal strap
Re: Ignition points for dual point cars [Re: gtx6970] #2873369
01/12/21 06:30 PM
01/12/21 06:30 PM
Kirkland, Washington
Pacnorthcuda Offline
Don’t know if it’s still true but in the 60’s, 70’s and 80’s the go-to brand was “Standard Blue Streak”.
Re: Ignition points for dual point cars [Re: Pacnorthcuda] #2873374
01/12/21 06:51 PM
01/12/21 06:51 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I second the Blue Streak, heavier spring and ground strap
Re: Ignition points for dual point cars [Re: gtx6970] #2873416
01/12/21 08:20 PM
01/12/21 08:20 PM
Minn
SportF Offline
SportF  Offline
Minn
You'll find only one set of points really wears (the set that opens first), the other set won't really wear for a long time. Also, unless the points are really pitted, don't change the condenser, there is no need to. So,you are down to changing the one set of points, not a big deal. Good luck.
Re: Ignition points for dual point cars [Re: SportF] #2873513
01/13/21 01:20 AM
01/13/21 01:20 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Thanks.
Found some nos mopar for less than $20 for a set of 2.
Also found some tan dist caps for less than $25 ea. So bought 3 of them...and no not the made in usa cap
Re: Ignition points for dual point cars [Re: Pacnorthcuda] #2873524
01/13/21 05:32 AM
01/13/21 05:32 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Yep, Standard Blue Streak was the top pick, but Standard was excellent also. Other than a slight appearance and price difference, the two looked to be identical. In performance, I could never detect any difference. In the recent past, Rock Auto has had Standard Blue Streak, but not now.
Re: Ignition points for dual point cars [Re: kentj340] #2873562
01/13/21 08:42 AM
01/13/21 08:42 AM
VA
dragon slayer Offline
VA
OEM are still plentiful and I would recommend that. Yes to the metal strap. The condenser also had the part number on it for OEM.
Re: Ignition points for dual point cars [Re: dragon slayer] #2873606
01/13/21 09:43 AM
01/13/21 09:43 AM
Niles , Ohio
therocks Offline
Its Lost
therocks  Offline
Its Lost
Niles , Ohio
I know NAPA could get Mallorys for stock dist.Blue streak is anothe great set.I ran nothing but Mallorys years ago.Both the dist and before that just the points to replace stock.IIRC Advance can still get Blue Streaks Might have to order them.Rocky
Chrysler Firepower
Re: Ignition points for dual point cars [Re: gtx6970] #2873616
01/13/21 09:53 AM
01/13/21 09:53 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted by gtx6970
Thanks.
I’m doing the same on points, did the seller have any more sets? Can I get their link?
Re: Ignition points for dual point cars [Re: cudaman1969] #2873861
01/13/21 03:38 PM
01/13/21 03:38 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Thanks.
I found them from the man I bought the car from.
He has some spares stock . I talked him out of 3 sets of pairs for $30 per pair.and with a nos condenser , I tried to get him to come off 5 sets total, but the he said nope. ( he has several cars still running them )
BUT,,,,,,,,I have him thinking about selling me one of his NOS green lettered coil
The dist caps and rotors I found on Amazon of all places. And one on Ebay
Standard # AL483
ps, by application is Marine, I currently have a NAPA Al1680 on the car now, Same application.
Looks just like the Mopar 2585000 cap, just without the Made In USA embossed lettering
Re: Ignition points for dual point cars [Re: gtx6970] #2874027
01/13/21 10:00 PM
01/13/21 10:00 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
According to Standard's website, AL-483 Distributor Cap does not fit 1969 340, 383, nor 440.
Re: Ignition points for dual point cars [Re: kentj340] #2874089
01/13/21 11:57 PM
01/13/21 11:57 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Like i said. Its marine applications.
I have the napa version on my car right now.
Its part number AL1680 ...same deal. Marine applications. My brother crossed the number to standard # .
I found the napa number in an old prestolite book years ago. And i sold a couple hundred of them.....NEVER had one complaint.
Re: Ignition points for dual point cars [Re: gtx6970] #2874090
01/14/21 12:33 AM
01/14/21 12:33 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
The marine version may differ by not having a vent hole under a clip. Could be as simple as that to meet different safety standards.
Re: Ignition points for dual point cars [Re: John Brown] #2874094
01/14/21 12:51 AM
01/14/21 12:51 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
That could be just that.
I will ck the one on my car tomorrow. But i dont remember there being one.
Does the oem mopar cap have this hole mentioned?
Re: Ignition points for dual point cars [Re: gtx6970] #2874164
01/14/21 09:00 AM
01/14/21 09:00 AM
VA
VA
Gasket up
Re: Ignition points for dual point cars [Re: dragon slayer] #2874308
01/14/21 02:02 PM
01/14/21 02:02 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
thumbs
X2 on the gasket, but a gasket wouldn't seal anything by itself if the cap had a vent hole.
Boats don't need fuel fumes coming anywhere near sparks, especially in an enclosed engine compartment. A fire in a boat has a lot worse consequences than a fire under the hood of a car. A car can pull over to the side of the road, a boat doesn't much choice on where to stop.
Re: Ignition points for dual point cars [Re: John Brown] #2874370
01/14/21 04:30 PM
01/14/21 04:30 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Dads boat 400s has the screen in the distributor not the cap
