Re: Pushrod makers
[Re: GTS340]
#2873637
01/13/21 11:10 AM
01/13/21 11:10 AM
Posts: 19,355 Las Vegas
Al_Alguire
Las Vegas
You mentioned the best three. I prefer Manton but have used Trickflow in a pinch
Re: Pushrod makers
[Re: DusterKid]
#2873641
01/13/21 11:16 AM
01/13/21 11:16 AM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
I had a problem with some Trend push rods, they went above & beyond to help me, they sent me the correct new ones at no charge, the best customer service & product I have ever had !!!
Re: Pushrod makers
[Re: CSK]
#2873650
01/13/21 11:23 AM
01/13/21 11:23 AM
Posts: 13,351 Marion, South Carolina [><]
an8sec70cuda
I use either Manton or Smith Brothers...no real preference. Excellent service from both.
Re: Pushrod makers
[Re: an8sec70cuda]
#2873653
01/13/21 11:25 AM
01/13/21 11:25 AM
Posts: 4,663 Wichita
GY3
Wichita
Manton has made a couple of sets for me. Great service and product.
Re: Pushrod makers
[Re: DusterKid]
#2873745
01/13/21 01:21 PM
01/13/21 01:21 PM
Posts: 287 PA
Harry's Taxi 2
PA
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Pushrod makers
[Re: Harry's Taxi 2]
#2873771
01/13/21 01:50 PM
01/13/21 01:50 PM
Posts: 8,018 Tulsa OK
Bad340fish
Tulsa OK
I have been real happy with smith brothers, but honestly haven't use anyone else.
68 Barracuda Formula S 340
Re: Pushrod makers
[Re: DusterKid]
#2874217
01/14/21 12:42 PM
01/14/21 12:42 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I suffered from a valve train instability/harmonic issue a few years back that almost cost my a motor. Dwayne Porter traced the problem back to improper valve spring installed height and issues with valves spring tension versus the capacity of the hydraulic lifters available for big block Mopars to handle spring loads heavy enough to control the hydraulic lifters with out them collapsing from the pressures. My initial setup lost control of the valvetrain at around 5800rpm. A power dip was evident on my dyno sheet. Dwayne spotted it right off.
I switched to solid rollers to bypass the problem. I also used Mike at B3 Racing to get a geometry correction kit and ordered custom rocker arms from T&D to adjust my valve train geometry to a more optimum relationship and up-sized and upgraded my pushrods to a set of 7/16" Manton Stage 5 parts. Their customer service, tech advice and turn around time were great.
In the end, these changes gave me one of the smoothest reving and running RB motors I have ever experienced in 40 some odd years. My lash has only needed a minor(.001-.0015") adjustment in 3000+ miles. I usually shift below 7k rpm at the max, and there is an entire magnitude of harmonics or higher frequency vibrations that is noticably absent from this engine now. I believe it is due to the optimized valvetrain geometry, the stiffer pushrods etc. Almost all my previous 440's had the same noise/vibrations while reving.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
Re: Pushrod makers
[Re: DusterKid]
#2874286
01/14/21 02:34 PM
01/14/21 02:34 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
A thicker wall and proper length is all you need imo.Are you keeping stock rocker gear?If you can get the length Comp should be fine.
