Re: My world aluminum block showed up!
[Re: gregsdart]
#2875443
01/17/21 12:08 PM
01/17/21 12:08 PM
Posts: 1,108 Massillon, Ohio
cudatom
Massillon, Ohio
I bought mine through Todd at Marsh perf. Each retailer will set thier price, usually discounting the retail price some. And that will change a bit as more blocks hit the market. I recommend dealing with Todd at Marsh. Knowledgeable and goes out of his way to take care of customers. Couldn't agree more. Todd has been great to work with for build. I have recommended him to my friends.
Ok
[Re: cudatom]
#2875483
01/17/21 01:02 PM
01/17/21 01:02 PM
Posts: 16,933 NC
440Jim
NC
Here is another observation, maybe just a useless "factoid" This is a wedge block, and has the wedge side motor mount lugs cast and drilled. But notice the 3-point Hemi pattern on the block. Just drill points and a milled area.
[Re: 440Jim]
#2876038
01/18/21 01:17 PM
01/18/21 01:17 PM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
Nice piece, Greg! I know you've been wanting a big chunk of alum up front for a very long time!
"Any fool can know. The point is to understand"
- A. Einstein
[Re: EvilB1Dart]
#2876141
01/18/21 03:37 PM
01/18/21 03:37 PM
Posts: 19,678 north of coder
moparx
why are the water passages [shown a couple of replies ago] in the head gasket [cometic] so much larger than the block holes ? is that the shape of the coolant passage of "most" heads commonly used with this block ? if the head holes are close to the size of the block holes, would/could this shape in the gasket have the potential to cause cavitation or steam pockets ? or am i WAY overthinking stuff here ? TIA for setting me straight on this.
[Re: moparx]
#2876588
01/19/21 02:10 PM
01/19/21 02:10 PM
Posts: 16,933 NC
440Jim
NC
why are the water passages [shown a couple of replies ago] in the head gasket [cometic] so much larger than the block holes ? is that the shape of the coolant passage of "most" heads commonly used with this block ? Here is a picture of a factory Chrysler BB deck. It should answer your question.
[Re: 440Jim]
#2889568
02/17/21 11:06 AM
02/17/21 11:06 AM
cudatom
Massillon, Ohio
Damn never knew Bill Mitchell was so close to me. His shop is 15 min from my winter get away home. Lol
Ok
[Re: sasquatch]
#2889618
02/17/21 01:24 PM
02/17/21 01:24 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I wonder when they moved to Florida.
They used to be in Ronkonkoma NY.
[Re: fast68plymouth]
#2889621
02/17/21 01:36 PM
02/17/21 01:36 PM
Posts: 16,933 NC
440Jim
NC
They used to be in Ronkonkoma NY. Its a COVID thing, Florida treats people better than NY... LOL
#2890125
02/18/21 03:48 PM
02/18/21 03:48 PM
Posts: 1,265 New York, USA
Chargerfan68
New York, USA
They used to be in Ronkonkoma NY. Dwayne, when Steve and I went out to BMP in ronkonkoma to pick up his block a few years ago, we met with Bill’s son, who was handling things up here already. That was about 2 years ago. He mentioned to us then, that they were going to move the operation down to Florida. His father was already down there at that point.
