Re: Truck trans
[Re: cudaman1969]
#2872541
01/11/21 01:32 PM
01/11/21 01:32 PM
Posts: 2,255 IL
furious70
IL
you need the conversion flexplate to use a 3 or 4spd auto, available many places. The easiest deal is an early stick truck computer with a hotwire.com harness for that and a 727/518/46rh. But you may want to have the 5, 6, or 8 gears depending on your projects. There are controllers for them and wiring from hotwire but the price goes up.
70 Sport Fury 68 Charger 69 Coronet 72 RR
Re: Truck trans
[Re: 52savoy]
#2884686
02/06/21 12:50 PM
02/06/21 12:50 PM
Posts: 2,255 IL
furious70
IL
you 'just' need the adapter flexplate and then whatever you're going to use to control the hemi.
Re: Truck trans
[Re: furious70]
#2885481
02/08/21 11:59 AM
02/08/21 11:59 AM
Posts: 1,548 Michigan
Kiddart
I might have a Mancini Racing adapter plate for sale. My son changed to a Rossler trans and I think its a different hole pattern on the flex plate. I don't know much about his trans
Thank you Kiddart
Re: Truck trans
[Re: cudaman1969]
#2885627
02/08/21 06:24 PM
02/08/21 06:24 PM
Posts: 70 Souderton
Taylor
Souderton
I ran a 46RH in my 2014 Ram for a while and have a 727 in my 04 Ram now , I used the ATI one in the 14 and the 04 I'm using Hays # 40-518 from Holley .
04 Ram 4x2 11.66@ 122 4750LBS ...phat pig Moves for fully loaded truck with NA 345ci Hemi 2020 1320 Challenger....stock daily driver.
