Racer Brown Valve Springs (need help identifying) #2871858
01/09/21 09:06 PM
01/09/21 09:06 PM
USA
Suregrip391 Offline OP
USA
I was wondering if anyone could tell me what I have here? I believe the box says Racer Brown. Pics attached...very vintage, hard to read. I took one out to show it’s a double spring with a damper as well. Someone wrote on the box Hemi Valve Springs. Does anyone have any old Racer Brown paperwork? Just curious what they are good for? Thanks!
The outer spring is
The OD is 1.487
The ID is 1.04
Wire diameter is .201
Height is 1.950
Also has a damper in it.
The inner spring is
OD .985
ID .725
Wire diameter .123
Height 2.049
Thanks guys.
Re: Racer Brown Valve Springs (need help identifying) [Re: Suregrip391] #2871859
01/09/21 09:07 PM
01/09/21 09:07 PM
USA
USA
One more pic
Re: Racer Brown Valve Springs (need help identifying) [Re: Suregrip391] #2871861
01/09/21 09:09 PM
01/09/21 09:09 PM
USA
USA
Last pic
Re: Racer Brown Valve Springs (need help identifying) [Re: Suregrip391] #2871912
01/09/21 11:03 PM
01/09/21 11:03 PM
Cab_Burge Online work
Cab_Burge  Online Work
Don't trust anything written when it comes to older Hi Po parts tsk
Take them to a good automotive machine shop or good Hi Po engine shop and have them tested so you know exactly if there useable or not scope
The original Racer Brown cam shop closed a long time ago, I'm thinking all the stock Mopar Street Hemi valve springs where 1.500 or slightly bigger, nothing smaller on the O.D.
Re: Racer Brown Valve Springs (need help identifying) [Re: Cab_Burge] #2871965
01/10/21 08:57 AM
01/10/21 08:57 AM
USA
USA
Will do, thanks Cab.
