Six Pack Carb #2871317
01/08/21 07:54 PM
01/08/21 07:54 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Hi. I was wondering if anyone could tell me the difference between a 340 center carb or a 440 center carb? Will a 340 work on a 440? Thanks.
Working on cars teaches you patience... and every curse word imaginable.
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
Re: Six Pack Carb [Re: GTXKARL] #2871390
01/08/21 10:27 PM
01/08/21 10:27 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
the list # and jet size i put a 440 crab on a 340 work grate
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: Six Pack Carb [Re: 1969gtx] #2871482
01/09/21 08:43 AM
01/09/21 08:43 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
The meter block is different but I can’t tell you the difference. The emulsion tubes inside have different holes but you can’t get in there to measure them. Different cams have different vacuum so they all require tweaking some. Sometimes they interchange fine. The air bleeds may be different as well. I have never measured those.
Re: Six Pack Carb [Re: fastmark] #2871508
01/09/21 10:21 AM
01/09/21 10:21 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Agreed,... also regarding the air bleeds, they are larger on the 340 carbs, also the #4790 340 (auto) center is 350 cfm, the #4791 340 (manual) center carb is 355 CFM
As far as the OP's question on using a 340 carb(s) on a 440, no problem, I actually prefer running the 340 carbs on B/RB applications, mostly for the larger air bleeds
Mike
Re: Six Pack Carb [Re: DAYCLONA] #2871541
01/09/21 11:26 AM
01/09/21 11:26 AM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Do you know what size jets are in a center stock 440 carb? What size are in a stock 340 carb? Thanks in advance.
