VP Q16 MTPE vs. REG #2871323
01/08/21 08:00 PM
01/08/21 08:00 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Time to get me a few drums of Q16.
Any know if the MTPE is any good compared to the REG type Q16?
Re: VP Q16 MTPE vs. REG [Re: Sammy] #2871447
01/09/21 01:21 AM
01/09/21 01:21 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I always try to get REG I've been told it is better but have not done any back-to-back personally
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: VP Q16 MTPE vs. REG [Re: WHITEDART] #2872519
01/11/21 12:58 PM
01/11/21 12:58 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Q16 REG is the one you want it is the original formulation with MTBE in it. It is about 20ish HP better, combination dependent than new formula which is simply labeled Q16, we have tested it on the dyno and on track. It was introduced to get around some of the states that have outlawed MTBE. Then VP came back out with the old formula as they say by popular demand.
Also DO NOT buy it by the drum. Any exposure to oxygen will reduce its effectiveness. You are better off to use 5 gallon pails. We have even used nitrogen on top when we have an open can to keep the oxygen away. You could do the same I suppose with a drum but every time you use some the fuel will be exposed to oxygen and that will affect the fuel.
