Roller lifters choices #2870624
01/07/21 07:40 PM
01/07/21 07:40 PM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
I know this subject has come up before. What are my choices for good reasonably priced solid roller lifters? This is a somewhat mild build RB 511 ,indy EZ heads standard port. Not going for max hp.Stock block. This is not a daily driver mostly a track car but occasional street time. I'll have someone more knowledgeable then me spec a cam that is easy on parts. I have read some some of the posts where guys are using hydraulic rollers making decent power so that is not out of the question either.
America First!
Re: Roller lifters choices [Re: carnut68] #2870628
01/07/21 07:43 PM
01/07/21 07:43 PM
birdtracker Offline
birdtracker  Offline
a friend told me there is no good cheap roller lifters. Birdtracker
Re: Roller lifters choices [Re: carnut68] #2870635
01/07/21 07:53 PM
01/07/21 07:53 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
I just went through this myself and this is what I think.
Seems like the hydraulic roller lifters are just not that great in reliability, and with the heavy valvetrain of a BB, you just can't run enough spring to make them work the way you want. Just my opinion....
As far as solid rollers, I would stay away from the smaller axle rollers. If your block is lifter bushed and plan on running pin oiling, you need to consider a totally different lifter body.
For me, I had a lifter bushed block and the Crower lifters appealed to me so they made me a set of BB chevy 904 bodied lifters on a BB mopar tie-bar. I went with the Crowers because I liked the orbit-formed axle retention (without retaining clips) and the HIPPO pin option and larger axle and wheels. I'm sure others will have there own favorite lifter opinions.
AG.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Roller lifters choices [Re: birdtracker] #2870637
01/07/21 07:59 PM
01/07/21 07:59 PM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
I agree. I didn't say cheap. I said reasonably priced. Reliable. I have a couple of friends who have used the Comp 829's with no problems. But haven't heard anything good lately.
America First!
Re: Roller lifters choices [Re: birdtracker] #2870664
01/07/21 08:38 PM
01/07/21 08:38 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
haha. When buying Roller lifters and roller rockers you should pick out the best you can afford and then save your money to buy better ones. A failure here can be catastrophic.
Features to keep in mind:
Bushings instead of needle bearings. don't want those little bits of hard steel floating around in your engine
Pressure lube axles.
Can not uncover oil galleys at base circle or max lift.
If you want to pushrod oil the rockers make sure the lifters can do that. Some don't. Do not rely on the description on their web page. Sometimes they say pushrod oiling but that feature is for Gm not Mopar. You might have to get AMC spec lifters.
Re: Roller lifters choices [Re: GomangoCuda] #2870674
01/07/21 08:53 PM
01/07/21 08:53 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Morel makes good lifters for the industry.
https://morellifters.com/dealers
Re: Roller lifters choices [Re: GomangoCuda] #2870678
01/07/21 08:55 PM
01/07/21 08:55 PM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
I have read about the Comp AMC lifters. This is a stock unbushed block. Rockers oiled thru the shafts.
America First!
Re: Roller lifters choices [Re: carnut68] #2870699
01/07/21 09:15 PM
01/07/21 09:15 PM
If your cam is not grooved on the #4 journal for oiling the shafts full time now you should have that done to help get more oil on the valve springs for extra cooling, especially for the street use up wrench twocents
Re: Roller lifters choices [Re: Cab_Burge] #2870703
01/07/21 09:22 PM
01/07/21 09:22 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
What's the spring pressures? S/F...Ken M
Re: Roller lifters choices [Re: EchoSixMike] #2870714
01/07/21 09:34 PM
01/07/21 09:34 PM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
As of now they are set up for sft 155/ 355. That will be determined by the cam specs. If I go to solid roller the #4 will get a groove a friend even suggested this.
America First!
Re: Roller lifters choices [Re: carnut68] #2870716
01/07/21 09:38 PM
01/07/21 09:38 PM
AndyF Offline
AndyF  Offline
I'd use the Comp AMC lifters with the Mopar width tie bars. That gives you pressurized oiling to the wheel and to the pushrod. Then I'd use an oiling type pushrod so I have pressure fed oil to the ball and cup. With oil at the wheel and at the ball and cup you should be good to go. Just keep an eye on the lash so you know if anything is moving around or going away on you. You'll also want to use the Hughes oil pump gear if possible since the bronze gears tend to wear out fairly quickly. But you can run a bronze gear as long as you pull it out every 1000 miles and inspect it.
Re: Roller lifters choices [Re: carnut68] #2870719
01/07/21 09:41 PM
01/07/21 09:41 PM
AndyF Offline
AndyF  Offline
I wouldn't groove the #4 journal on the cam. When you do that it pulls oil away from the adjacent rod bearings and you can smoke a bearing.
Re: Roller lifters choices [Re: AndyF] #2870783
01/07/21 11:21 PM
01/07/21 11:21 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
I've been using the 892 Comp Cams roller lifters on 2 of my engines for 10+years now & thats with loading thats over 700lb on the nose. The oldest set is starting to require replacements now but I am seriously happy with the life & performance I have received from them. I'll probably replace my oldest set after this next season, but I'll buy the same again, no problem.
Re: Roller lifters choices [Re: rebel] #2870873
01/08/21 08:49 AM
01/08/21 08:49 AM
birdtracker Offline
birdtracker  Offline
so I got bit hard by this topic this summer. First my old motor had Comp 829s in it forever. 400 passes easy. Got the first set and the body broke down where the axle goes thru. So had a Moparts member here send me 16 relatively new ones that had flat spots on 12 of 16 of the axle. You could feel it with your finger just rolling it. I also was measuring body diameters and they were not all .904 so I sent them back to him and told him what I thought. I know Crane offers a very good lifter that Indy recommended to me and they were around $650-$700. They have roller bearings. My next choice would be bushed Isky red zone. There is a bushed version and a roller bearing version. Birdtracker
Re: Roller lifters choices [Re: carnut68] #2870877
01/08/21 09:07 AM
01/08/21 09:07 AM
portland, ct
Since1822 Offline
Since1822  Offline
portland, ct
I just picked up a solid roller and did some research regarding the same question. The BAM roller lifters with the larger .815 roller is what I decided to go with. They make a nice piece and are available with an offset as well.
Re: Roller lifters choices [Re: birdtracker] #2870879
01/08/21 09:09 AM
01/08/21 09:09 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
These are the guys who made them for Crane according to the fellow who recommended them to me.
Not cheap , but nice parts.
GS products
Re: Roller lifters choices [Re: carnut68] #2870937
01/08/21 10:29 AM
01/08/21 10:29 AM
bronx n.y
O
one bad fish Offline
O
bronx n.y
what do u mean a grove on the cam it self
Re: Roller lifters choices [Re: one bad fish] #2870986
01/08/21 11:22 AM
01/08/21 11:22 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I think he means instead of the head getting oil to the top only when the oiling holes in the cam journal align with each
head, if you were to groove completely around that cam journal,
oil will be supplied constantly to the heads.
Thus Andy's concern.
Joe
Re: Roller lifters choices [Re: jlatessa] #2870993
01/08/21 11:27 AM
01/08/21 11:27 AM
bronx n.y
O
O
bronx n.y
Joe
oh ok
Re: Roller lifters choices [Re: jlatessa] #2871000
01/08/21 11:38 AM
01/08/21 11:38 AM
Johnstown
69dart Offline
69dart  Offline
Johnstown
I've run the Herbert Roller TDV lifters for several years. I learned the hard way buy the Alpha S608 240lbs springs and really really good rockers.
My engine guy says the Herbert lifter are Morrel lifters.
Don't let the engine idle super low for extended periods as that kills roller lifters in BB Mopars - My engine will actually idle at 600RPM but I leave it around 1000RPM to help the lifter oiling.
I flog hundreds of laps a year on my junk 383 and used to break the mopar/crane rockers on a monthly basis.
I think this contributed to couple of lifters going bad over the years.
I finally upgraded to the Hughes Cryo treated rockers and Alpha s608 springs and things have been solid since.
Last year I did finally break a herbert cam in half after countless runs. I'm guessing all those broken rockers finally caught up.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
