Indy 440-1 Valve size in 4.35 bore #2870170
01/06/21 11:27 PM
01/06/21 11:27 PM
WNY
Moparrob68 Offline OP
WNY
Upgrading my bracket race 440 to a 493 this winter. .704 lift roller cam with 1.6 rockers.Sent the Indy 440-1 heads out for porting. Replacing all the valves. Should I stick with the 2.19 intakes or switch to the 2.25 intakes? Would the 2.25 valves be too shrouded by the 4.35 bore?
Re: Indy 440-1 Valve size in 4.35 bore [Re: Moparrob68] #2870173
01/06/21 11:36 PM
01/06/21 11:36 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
2.25 will fit, 2.30 needs a bigger bore and possibly a smaller exhaust valve. (1.78) due to radial clearance.
Re: Indy 440-1 Valve size in 4.35 bore [Re: Jeremiah] #2870398
01/07/21 12:34 PM
01/07/21 12:34 PM
gregsdart Online content
gregsdart  Online Content
Many motors run good with a 4.375 bore, which is only .0125 further from the valve.
