Re: 14x7 Road wheel - Rare?
[Re: topside]
#2869156
01/04/21 11:50 PM
01/04/21 11:50 PM
Posts: 17,507 Las Vegas, NV
6bblgt
Las Vegas, NV
& at Chrysler Corp.:all chrome " ROAD WHEELS" 1967-'68 14x5.5" for B-bodies 14x6.0" for C-bodies " chrome style ROAD WHEELS" w/trim ring 1969-'76 (or so) 14x5.5" - on various year A, B, E, F-bodies 1971-'79 (or so) 14x6.0" - on various year B, F-bodies
[Re: 6bblgt]
#2869274
01/05/21 01:02 PM
01/05/21 01:02 PM
Posts: 1,014 Midwestern Indiana
duster2
Midwestern Indiana
If you look at the backside of the wheel , along the rim edge , you should see a Ford name in a circle.
Also those are really good cores ( the rim shells ) to make 14 x 7 small bolt steel wheels. Inside of the rim shell is 12.25 , just right for 14 x 7 small bolt or large bolt ralley or steel wheels.
Frank
[Re: clem melson]
#2869476
01/05/21 07:35 PM
01/05/21 07:35 PM
Posts: 6,221 JERSEY
RJS
JERSEY
Dont waste your breath with this dork, he wont believe you. He knows it all.
I met him shortly after he moved to spring hill, fl. My great aunt married the guy that developed this town (deltona corp). They also did deltona and marco island.
This clown said if i need to know anything about spring hill, ask him.
What a jerk. WTH are you talking about?????
[Re: RJS]
#2869554
01/06/21 12:27 AM
01/06/21 12:27 AM
Posts: 64 Anchorage AK
AKcharger
Anchorage AK
I couldn't find any "Ford "markings anywhere on the wheel but I'm pretty sure that's the answer. appearently Ford made14x7's for Ranchairo's. What's suprising is they are IDENTICAL to MOPAR road wheels in every way!
Thanks guys!
[Re: AKcharger]
#2869584
01/06/21 06:31 AM
01/06/21 06:31 AM
Posts: 348 Isle of Sheeps
Gtxxjon
Isle of Sheeps
I don't think Mopar or Ford make wheels? Kelsey Hayes and others probably do that 'for them'... A different centre hole is the biggest give-away from memory??? Don't think that matters with this style of wheel. Always prefer a 15 incher myself... Are you talking about Homer in Springfield??? Clem?
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
[Re: Gtxxjon]
#2869615
01/06/21 10:21 AM
01/06/21 10:21 AM
AKcharger
Anchorage AK
I don't think Mopar or Ford make wheels? Kelsey Hayes and others probably do that 'for them'... Good point and easy to forget Ma MOPAR didn't MAKE every part. - I didn't measure the hole but looks the same - Agree, these cars need 15's minimum. I just want to keep an original set for each car Thanks
[Re: AKcharger]
#2869641
01/06/21 11:26 AM
01/06/21 11:26 AM
Posts: 20,644 So Near, Yet So Far
topside
So Near, Yet So Far
Kelsey-Hayes and Motor Wheel both made wheels for the OEMs, likely others did as well depending on volume, construction style, etc. The "Magnum" centers for the Fords & Mopars seem to be the same dimensions, so the same stamping could be used. That's not the case with "regular steelies", which has been well-documented. Several times, I've used Ford 14x7 Magnums on Mopars, and nobody appeared to notice.
[Re: topside]
#2869720
01/06/21 02:43 PM
01/06/21 02:43 PM
AKcharger
Anchorage AK
Several times, I've used Ford 14x7 Magnums on Mopars, and nobody appeared to notice. wish I would have found these things before!
[Re: Gtxxjon]
#2872766
01/11/21 06:16 PM
01/11/21 06:16 PM
Posts: 2,077 Oklahoma City
Jwilli500
Oklahoma City
You're right about the center hole. The Ford wheel is pretty much a press fit on the mopar axle center. I usually remove the lug nuts and have to kick the side of the tire to break it loose. LOL I have run them for years because they look so good on the back of my 66. I don't think Mopar or Ford make wheels? Kelsey Hayes and others probably do that 'for them'... A different centre hole is the biggest give-away from memory??? Don't think that matters with this style of wheel. Always prefer a 15 incher myself... Are you talking about Homer in Springfield??? Clem?
[Re: Jwilli500]
#2872954
01/12/21 01:21 AM
01/12/21 01:21 AM
AKcharger
Anchorage AK
All I know is they fit on my 1970Charger with no issues?
[Re: AKcharger]
#2872999
01/12/21 06:46 AM
01/12/21 06:46 AM
Gtxxjon
Isle of Sheeps
Up until 1970 nobody was making many 15 inch tyres! I remember being in LA about 15 years ago and I saw a set of 32 inchers on a 4x4. Things change over the years and guys/gals who stick to 14 inchers are probably are just trying to be true to 60's muscle! If you are going to fit 1970 single piston disc brakes/calipers then its gotta be a 15 incher I'm afraid... The old kelsey four pots are a 'mare' at the best of times... Gotta keep it realistic, and make life easy for yourself.
[Re: AKcharger]
#2873919
01/13/21 07:01 PM
01/13/21 07:01 PM
Posts: 5,283 Land 'O Lakes
RoadRunnerLuva
Land 'O Lakes
My '73 Charger SE had the original 14X6" Road wheels, with the brushed trim rings, still with it when I bought it a few years ago. Looked almost identical to your rims.
Plymouth Makes It!
[Re: Gtxxjon]
#2875300
01/16/21 11:23 PM
01/16/21 11:23 PM
Posts: 21,346 It's a dry heat
gtx6970
It's a dry heat
If you are going to fit 1970 single piston disc brakes/calipers then its gotta be a 15 incher I'm afraid... :
Not true. Lots of .mopars built back then 14" rims and disc brakes
[Re: gtx6970]
#2875306
01/16/21 11:39 PM
01/16/21 11:39 PM
6bblgt
Las Vegas, NV
Not true. Lots of .mopars built back then 14" rims and disc brakes every 1972-'74 E-body, 1973-'76 A-body, 1976-'80 (non-Kit Car or Super Coupe) F-body with disc brakes had 14" wheels
