Is this bondo?
#2869129
01/04/21 10:51 PM
01/04/21 10:51 PM
Posts: 10,178 Someplace you aren't
SomeCarGuy
I might be losing my touch. Guy got kinda upset I pressed him on pics from the bottom side of this area. Says car has no bondo.
I want my fair share
Re: Is this bondo?
[Re: SomeCarGuy]
#2869132
01/04/21 10:53 PM
01/04/21 10:53 PM
SomeCarGuy
Was told this isn’t rust on the door lip. Said Michigan guys call it “foundry grit.” Also that I’m seeing oil that was sprayed on it, to preserve it. Even though there isn’t any rust...
Re: Is this bondo?
[Re: SomeCarGuy]
#2869138
01/04/21 11:03 PM
01/04/21 11:03 PM
Posts: 1,110 Usa
A39Coronet
Usa
Guy got kinda upset I pressed him on pics from the bottom side of this area. Red flag. Any honest person selling a car divulges what he himself would want to know prior to buying a car. Any salesman who gets upset when a buyer asks legitimate questions is trying to intimidate you to back off your review, for a reason.
Re: Is this bondo?
[Re: GODSCOUNTRY340]
#2869166
01/05/21 12:15 AM
01/05/21 12:15 AM
SomeCarGuy
Thanks guys. What got me thinking it was bondo was the paint looking different right there.
The foundry grit thing was a new one on me.
He took pics of the underside I asked for on his lift. Strangely he couldn’t manage any of that spot I said mattered most to me. Really gives me pause. One of the frame stubs running out to a rocker looks so what bad too, but it’s right in the cutoff of the pic so hard to say. Think this car is out so doesn’t matter anyway.
Re: Is this bondo?
[Re: SomeCarGuy]
#2869171
01/05/21 12:48 AM
01/05/21 12:48 AM
Posts: 8,390 Highland, MI.
Sunroofcuda
Highland, MI.
"Foundry grit." NEVER heard of this one before - that's a new one on me! That's made-up BS. To me, I'd need a better close-up of the door bottom to see if the lip is getting fat. It looks pretty crusty to me in the photo.
The dogleg area looks OK to me, but I'd like a better close-up. There was some seam sealer used in those areas, so if paint comes off, it can look like some bondo. They were never done neatly from the factory. Same with the blobs of sealant in the trunk pan seams that were really slopped on & painted over.
Re: Is this bondo?
[Re: Sunroofcuda]
#2869210
01/05/21 09:05 AM
01/05/21 09:05 AM
RWG75
RWG75
Rust is a relative thing.
Re: Is this bondo?
[Re: ]
#2869224
01/05/21 10:09 AM
01/05/21 10:09 AM
Posts: 10,666 North Dakota
6PakBee
North Dakota
Rust is a relative thing. Amen. I remember a seller from Michigan once stating that if a car still cast a shadow it was rust-free.
Re: Is this bondo?
[Re: SomeCarGuy]
#2869232
01/05/21 10:30 AM
01/05/21 10:30 AM
Posts: 17,801 S.E. Michigan
ZIPPY
S.E. Michigan
Michigan guys call it “foundry grit.” . Michigan guys who aren't trying to misrepresent a car usually call it "rust". The rocker area looks like factory slop/lead+messy seam sealer and early stage rust. The lap joints are always first to go. Dipping will take care of it but has to be done perfectly and can create other problems.
Rich H.
Esse Quam Videri
Re: Is this bondo?
[Re: SomeCarGuy]
#2869327
01/05/21 02:30 PM
01/05/21 02:30 PM
Posts: 5,137 East Aurora (Buffalo) NY
RoadRunner
On the door jamb area, that area is trick. The factory used lead to cover the seam where the quarter overlaps the rocker. But there is also a seam sealer used between the quarter and the jamb metal panel. Sometimes there is some excess seam sealer that squishes out at the bottom. This location gets exposed to moisture on the inside by any water that leaks past the outside window seal. The water should drip down and out the drain channel between the quarter and rocker panel that is behind it. Unfortunately, the seam sealer sometimes catches some of the water dripping and will cause some rust. I don't think that area looks too bad. The corner of the door looks like someone sprayed some of the rust converter/sealer in the corner of the door.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
Re: Is this bondo?
[Re: Kern Dog]
#2869358
01/05/21 03:10 PM
01/05/21 03:10 PM
Posts: 19,239 north of coder
moparx
way back in the mid 70's when my buddy and i were going to the auction all the time, an interesting thing happened. we were looking at a car [which neither of us can recall what it was to this day] and an old guy pressed his head between us and said : "Cars with Bondo aren't Safe !" my buddy and i looked at each other, turned around, and the guy was GONE ! just disappeared ! we looked for him the rest of the day, and for MANY more auction days at ALL of the auction sites we attended, and NEVER saw hide nor hair of him again ! just a weird experience in our lives. we talk of this almost any time rust or bondo is brought up.
Re: Is this bondo?
[Re: Kern Dog]
#2869362
01/05/21 03:20 PM
01/05/21 03:20 PM
Posts: 4,707 Moved to N.E. Tennessee
GomangoCuda
Back about 1975 or 6 there was an ad in a local trader type publication for a Hemi Coronet RT minus engine. The ad said No Rust and the price seemed low. So I went to the bank to get cash and picked up a friend that knew more about hemi cars than me. Off to Cleveland Ohio we went (about an hour away). First clue should have been when he invited us into his house. There was no furniture, bare wood floors with most of the finish worn off and a naked baby rolling a hotdog around on the filthy floor. He took us out to the garage to see the car. My friend and I looked the car over, told him not interested and left. We laughed so hard all the way home that it was hard to breath. He wasn't exactly lying. It was a correct hemi car but the reason there was no rust was because he had cut the bottom of both quarters off with a saber saw. Everything below the trunk floor was gone. Of coarse the last laugh was probably on us because years later the value of these cars skyrocketed and it would have been well worth it to replace sheet metal. Back then not so much. I highly regret not buying that car but we did get a good laugh. . 45 years later all we have do is say "No Rust" and we both burst out laughing.
