14x7 Road wheel - Rare? #2869120
01/04/21 10:28 PM
01/04/21 10:28 PM
Anchorage AK
AKcharger Offline OP
Anchorage AK
I've never seen a 14x7 road wheel only 14x5.5. What were these offered on and are they rare?
Re: 14x7 Road wheel - Rare? [Re: AKcharger] #2869146
01/04/21 11:35 PM
01/04/21 11:35 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Fords & Mercurys.
Re: 14x7 Road wheel - Rare? [Re: topside] #2869156
01/04/21 11:50 PM
01/04/21 11:50 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
iagree
& at Chrysler Corp.:
all chrome "ROAD WHEELS"
1967-'68
14x5.5" for B-bodies
14x6.0" for C-bodies
"chrome style ROAD WHEELS" w/trim ring
1969-'76 (or so)
14x5.5" - on various year A, B, E, F-bodies
1971-'79 (or so)
14x6.0" - on various year B, F-bodies
Re: 14x7 Road wheel - Rare? [Re: 6bblgt] #2869274
01/05/21 01:02 PM
01/05/21 01:02 PM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
If you look at the backside of the wheel , along the rim edge , you should see a Ford name in a circle.
Also those are really good cores ( the rim shells ) to make 14 x 7 small bolt steel wheels.
Inside of the rim shell is 12.25 , just right for 14 x 7 small bolt or large bolt ralley or steel wheels.
Frank
Re: 14x7 Road wheel - Rare? [Re: duster2] #2869430
01/05/21 05:44 PM
01/05/21 05:44 PM
fl
clem melson Offline
clem melson  Offline
fl
Dont waste your breath with this dork, he wont believe you. He knows it all.
I met him shortly after he moved to spring hill, fl. My great aunt married the guy that developed this town (deltona corp). They also did deltona and marco island.
This clown said if i need to know anything about spring hill, ask him.
What a jerk.
Re: 14x7 Road wheel - Rare? [Re: clem melson] #2869476
01/05/21 07:35 PM
01/05/21 07:35 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
What a jerk.
WTH are you talking about?????
Re: 14x7 Road wheel - Rare? [Re: RJS] #2869554
01/06/21 12:27 AM
01/06/21 12:27 AM
Anchorage AK
Anchorage AK
I couldn't find any "Ford "markings anywhere on the wheel but I'm pretty sure that's the answer. appearently Ford made14x7's for Ranchairo's. What's suprising is they are IDENTICAL to MOPAR road wheels in every way!
Thanks guys!
Re: 14x7 Road wheel - Rare? [Re: AKcharger] #2869584
01/06/21 06:31 AM
01/06/21 06:31 AM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
I don't think Mopar or Ford make wheels?
Kelsey Hayes and others probably do that 'for them'...
A different centre hole is the biggest give-away from memory??? shruggy
Don't think that matters with this style of wheel.
Always prefer a 15 incher myself... catfight
Are you talking about Homer in Springfield??? drinking Clem?
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: 14x7 Road wheel - Rare? [Re: Gtxxjon] #2869615
01/06/21 10:21 AM
01/06/21 10:21 AM
Anchorage AK
Anchorage AK
Good point and easy to forget Ma MOPAR didn't MAKE every part.
- I didn't measure the hole but looks the same
- Agree, these cars need 15's minimum. I just want to keep an original set for each car
Re: 14x7 Road wheel - Rare? [Re: AKcharger] #2869641
01/06/21 11:26 AM
01/06/21 11:26 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Kelsey-Hayes and Motor Wheel both made wheels for the OEMs, likely others did as well depending on volume, construction style, etc.
The "Magnum" centers for the Fords & Mopars seem to be the same dimensions, so the same stamping could be used.
That's not the case with "regular steelies", which has been well-documented.
Several times, I've used Ford 14x7 Magnums on Mopars, and nobody appeared to notice.
Re: 14x7 Road wheel - Rare? [Re: topside] #2869720
01/06/21 02:43 PM
01/06/21 02:43 PM
Anchorage AK
Anchorage AK
wish I would have found these things before!
Re: 14x7 Road wheel - Rare? [Re: AKcharger] #2869729
01/06/21 02:53 PM
01/06/21 02:53 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The wheels are easier to find than the original brushed trim rings, which were discontinued many years back.
Re: 14x7 Road wheel - Rare? [Re: Gtxxjon] #2872766
01/11/21 06:16 PM
01/11/21 06:16 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
You're right about the center hole. The Ford wheel is pretty much a press fit on the mopar axle center.
I usually remove the lug nuts and have to kick the side of the tire to break it loose. LOL
I have run them for years because they look so good on the back of my 66.
Re: 14x7 Road wheel - Rare? [Re: Jwilli500] #2872954
01/12/21 01:21 AM
01/12/21 01:21 AM
Anchorage AK
Anchorage AK
All I know is they fit on my 1970Charger with no issues?
Re: 14x7 Road wheel - Rare? [Re: AKcharger] #2872999
01/12/21 06:46 AM
01/12/21 06:46 AM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
Up until 1970 nobody was making many 15 inch tyres!
I remember being in LA about 15 years ago and I saw a set of 32 inchers on a 4x4.
Things change over the years and guys/gals who stick to 14 inchers are probably are just trying to be true to 60's muscle!
If you are going to fit 1970 single piston disc brakes/calipers then its gotta be a 15 incher I'm afraid... wrench
The old kelsey four pots are a 'mare' at the best of times... realcrazy
Gotta keep it realistic, and make life easy for yourself. drive
Re: 14x7 Road wheel - Rare? [Re: AKcharger] #2873919
01/13/21 07:01 PM
01/13/21 07:01 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
My '73 Charger SE had the original 14X6" Road wheels, with the brushed trim rings, still with it when I bought it a few years ago. Looked almost identical to your rims.
Plymouth Makes It!
Re: 14x7 Road wheel - Rare? [Re: RoadRunnerLuva] #2875299
01/16/21 11:15 PM
01/16/21 11:15 PM
Anchorage AK
Anchorage AK
Yup, the Ford wheels (which I believe they are) are identical in every way
Re: 14x7 Road wheel - Rare? [Re: Gtxxjon] #2875300
01/16/21 11:23 PM
01/16/21 11:23 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
If you are going to fit 1970 single piston disc brakes/calipers then its gotta be a 15 incher I'm afraid... :
Not true. Lots of .mopars built back then 14" rims and disc brakes
Re: 14x7 Road wheel - Rare? [Re: gtx6970] #2875306
01/16/21 11:39 PM
01/16/21 11:39 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
iagree every 1972-'74 E-body, 1973-'76 A-body, 1976-'80 (non-Kit Car or Super Coupe) F-body with disc brakes had 14" wheels
