Page 1 of 4 1 2 3 4
For Sale - Big Block Engine - 1st Quarter #2867403
01/01/21 10:22 AM
01/01/21 10:22 AM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
Re: For Sale - Big Block Engine - 1st Quarter [Re: moparts] #2867847
01/01/21 09:45 PM
01/01/21 09:45 PM
MI
6PAX Offline
6PAX  Offline
MI
Cal Custom El Toro air cleaner wing nut. $5
Used chrome thermostat housing. $5
Used Crane cam #278-2. Cam only, no lifters. $75
Four new extra wide chrome valve cover hold down clamps. $10 for the set
New exhaust manifold heat stove to air cleaner hose. $20
1970 Single nipple oil breather with hose. $35
New 12" oval 4 barrel aluminum air cleaner with filter. It measures 12" L x 8 1/4" W x 3" H and has a 5 1/8" carb opening. $60
NOS Direct Connection big block double roller timing chain #P4120264. $75
Cal Custom 9" finned air cleaner top and base. No filter. $75
Mr. Gasket 1" thick carb spacer. $15
137 Spectre brand radiator and heater hose clamp covers. Some chrome, some red and some blue anodized. Various sizes. $50 for the lot.
As-new never used Edelbrock STR-15 383-400 crossram intake manifold with linkage. $2600
1972 400 oil pump $5
4 Groove crank pulley from a 1972 400. $20
187 Oil pan from a 1972 400. Is dented so will need straightening. No pick-up. $50
1972 400 spark plug shields $10 pair
1972 400 exhaust manifold heat stove for non-hp manifolds $15.
Carb. throttle linkage pin. $10
1967 Carter 4327S carburetor for 440 automatic from a 67 GTX. Needs rebuild. $125
Vintage Cal Custom scoop style air cleaner. Includes often missing matching wingnut. $300
Pair of big block exhaust manifolds. Part numbers 2532626 & 2532464. $100
Alternator date coded 1965. $40
1969 B-body 4 bbl. air cleaner top. $200
Prices do not include shipping. gt340 @ yahoo.com
Re: For Sale - Big Block Engine - 1st Quarter [Re: 6PAX] #2867894
01/01/21 11:01 PM
01/01/21 11:01 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
3462346 heads that came off of a 1971 Charger 440.They have 2.08 int. and 1.74 exh.
$100
Will not ship
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: For Sale - Big Block Engine - 1st Quarter [Re: moparts] #2868257
01/02/21 08:25 PM
01/02/21 08:25 PM
MI
6PAX Offline
6PAX  Offline
MI
Water pump pulleys and fan spacers. $15 each. Fan spacers from left to right are 2 7/8" x 1 1/4", 2 7/8" x 1 3/8" and 2 3/4" x 1 1/16". Pulleys are left to right top row: 7 7/16" x 1 3/4", 6 3/8" x 1 7/8", 5 13/16" x 1 1/4". Bottom row L to R: 5 1/4" x 1 3/16", 5 1/16" x 1 1/4", 5 1/4" x 1 1/4".
2 3/4" x 1 1/16" spacer on far right is sold.
Top left 7 7/16" pulley is sold.
gt340 @ yahoo.com
Water pump pullies.JPG (2089 downloads)
Fan spacers.JPG (2096 downloads)
Re: For Sale - Big Block Engine - 1st Quarter [Re: moparts] #2868799
01/04/21 10:31 AM
01/04/21 10:31 AM
Tennessee
727builder Offline
727builder  Offline
Tennessee
Weiand Intake fits RB engines. Weiand part number 7512
Never cut or milled. No stripped bolt holes. Was cleaned and glass beaded
$175 picked up locally.
$200 shipped to your door. Providing you are in the lower 48.
Can email me @Mcroft360@aol.com
Or call or text 423-402-6752
Thanks Moparts!!
Thermoquad Carburetor 9077S [Re: moparts] #2868889
01/04/21 02:02 PM
01/04/21 02:02 PM
RI
cudascooter Offline
cudascooter  Offline
RI
I have a 1977/1978 Thermoquad 9077S. I believe it is 850 CFM. The previous owner of my Roadrunner had bought it as a NOS unit. I removed it to put the original carb back on the car. Take notice that there is no choke. That is the way it was set up with the intake gasket choke blocked for better performance. I removed it from the car about six months ago and it ran great then and you should still be able to bolt on as is. However, I can’t guarantee with today’s fuel. $200.00 plus the ride. Thanks!
***PENDING****
New Year's Cleaning: [Re: cudascooter] #2869329
01/05/21 01:35 PM
01/05/21 01:35 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Multiple sets of stock heads. I have one set of 906's, two sets of conventional 452's, 2 sets of 452 police/motorhome heads with the additional coolant passages. They have been shot blasted and freeze plugs pulled. Asking $200/set, if you want them machined and finished, that's an option too, I have access to a machine shop. S/F....Ken M
Re: New Year's Cleaning: [Re: EchoSixMike] #2869338
01/05/21 01:47 PM
01/05/21 01:47 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
RB stroker kit. 4.15" This came from an orphaned build, I believe it is an Ohio crank and Ohio H-beam rods w/ARP2000 rod bolts. It has SRP 213459 pistons, for 4.375 bore, I will include the bearings pictured. It has been balanced, I spun it and it's within 1.5 gms. I do not have any RB stuff, otherwise I would use it. It appears to have been dynoed, or maybe run for break in, it cleaned up with light soda blasting. Asking $1250, prefer you pick it up, north of Chicago, shipping will be a PITA. S/F....Ken M (Sold pending payment, Thank you Moparts)
Re: New Year's Cleaning: [Re: EchoSixMike] #2869345
01/05/21 01:52 PM
01/05/21 01:52 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
I also have a 383 forged crank from a tear down, it's been jet washed and the journals polished. It's .010 on the mains and the rods are .020. I will include a set of coated .020 rod bearings that were used for assembly, and then things changed. $150, no pictures, sorry.
Set of Crane ductile BB 1.5 rockers, just the rockers. Asking $350. S/F....Ken M
Re: For Sale - Big Block EngineSOLD - 1st Quarter [Re: moparts] #2869366
01/05/21 02:26 PM
01/05/21 02:26 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
512 STROKER MOTOR 400 based build MANLEY ARP CLEVITE COMP CAMS 10-1 COMP EVERYTHING NEEDED TO RUN to much to list will gladly answer questions looking for local pick up san diego area but could ship on buyers dime please PM me for full details asking 9500.00$ have more pics if needed SOLD
Water pump housing [Re: moparts] #2869677
01/06/21 12:02 PM
01/06/21 12:02 PM
In the Middle
roadntrack Offline
roadntrack  Offline
In the Middle
Water pump housing assy
cast 02068
Original factory pump!
$75 plus ship PM for more info
0306211034 (2).jpg (18 downloads)
Remember when cars were FUN?
RV Water pump housing [Re: roadntrack] #2869678
01/06/21 12:04 PM
01/06/21 12:04 PM
In the Middle
roadntrack Offline
roadntrack  Offline
In the Middle
Motorhome water pump housing
$45 plus ship
PM for more info
906 head cores [Re: moparsquid] #2869694
01/06/21 12:48 PM
01/06/21 12:48 PM
In the Middle
roadntrack Offline
roadntrack  Offline
In the Middle
2843906 head cores
one dated 01039 Jan 3 1969 SOLD!
one dated 10248 Oct 24 1968 ?
$75 each plus ship
PM for more info
MOPAR 906 HEAD.jpg (1834 downloads)
Re: For Sale - Big Block Engine - 1st Quarter [Re: moparts] #2869705
01/06/21 01:16 PM
01/06/21 01:16 PM
West Virginia
B1Frank Offline
B1Frank  Offline
West Virginia
Edelbrock #1411 = 750 electric choke carb for sale,..runs great, to much carb for what im building, can put a calibration kit , and knock it down #2-3 jet's, but i would rather buy a new carb, , save so money ...idle time only ! $300.00 free shipping
bubs macho truck #3.jpg (1844 downloads)
ROCKER SHAFTS [Re: B1Frank] #2869722
01/06/21 01:44 PM
01/06/21 01:44 PM
In the Middle
roadntrack Offline
roadntrack  Offline
In the Middle
Pair of NOS TRW chrome rocker shafts
$95 plus ship
PM for more info
ROCKER SHAFT.jpg (1837 downloads)
main bearings [Re: old_racer] #2871546
01/09/21 10:37 AM
01/09/21 10:37 AM
Wi.
old_racer Offline
old_racer  Offline
Wi.
new set of main brgs i've had for a long time , would be good for stock rebuild, std size 440 rb motor, they are not tri metal, thrust is fully groove others are not. $30 plus shipping. SALE PENDING
Re: Thermoquad Carburetor 9077S [Re: cudascooter] #2871669
01/09/21 01:58 PM
01/09/21 01:58 PM
RI
cudascooter Offline
cudascooter  Offline
RI
Price cut! Now $100.00 plus shipping for the carburetor.
****Pending*****
68-69 440 Unsilenced Air Cleaner With K&N Filter [Re: moparts] #2872379
01/11/21 03:05 AM
01/11/21 03:05 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
68-69 440 Air Cleaner With K&N Filter. Used, $300 + Shipping. Payment via US Postal Money Order. Shipping: US Address Only!
Call Steve 810-629-1097
68-69 Air Cleaner.jpg (1319 downloads)
Factory Carb Stud With Wing Nut [Re: Memongo] #2872380
01/11/21 03:06 AM
01/11/21 03:06 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Factory Carb Stud With Wing Nut. Used, $15 + Shipping. Payment via US Postal Money Order. Shipping: US Address Only!
Big Block Distributor Hold Down Bracket [Re: Memongo] #2872382
01/11/21 03:08 AM
01/11/21 03:08 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Big Block Distributor Hold Down Bracket. Used, $20 + Shipping. Payment via US Postal Money Order. Shipping: US Address Only! Call Steve 810-629-1097
Page 1 of 4 1 2 3 4
