Blower motor gasket #2868015
01/02/21 11:10 AM
01/02/21 11:10 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I’m working on a 69 b body with heater only. The seal/insulator gasket is pretty hard. Does anyone make one of those? I checked DMT and he does not have one. It’s the seal that goes between the blower and fan through the backing plate on the heater.
Re: Blower motor gasket [Re: fastmark] #2868021
01/02/21 11:18 AM
01/02/21 11:18 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Detroit Muscle Technologies, you have to buy the rebuild kit, I think.
Joe
Re: Blower motor gasket [Re: fastmark] #2868024
01/02/21 11:21 AM
01/02/21 11:21 AM
MD
floyd Offline
floyd  Offline
MD
Check with Jim at DMT anyway. If he doesn’t have he he may make one for you using your original as a pattern. I think he’s always looking for new products to offer anyway.
Re: Blower motor gasket [Re: fastmark] #2868027
01/02/21 11:31 AM
01/02/21 11:31 AM
N
NITROUSN Offline
NITROUSN  Offline
N
I may have one. Post a picture.
Re: Blower motor gasket [Re: NITROUSN] #2868113
01/02/21 02:46 PM
01/02/21 02:46 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Here you go.
Re: Blower motor gasket [Re: fastmark] #2868216
01/02/21 08:10 PM
01/02/21 08:10 PM
N
NITROUSN Offline
NITROUSN  Offline
N
So it is just a round foam gasket. I believe I have it. Just give me the OD and ID and I will measure mine.
Re: Blower motor gasket [Re: NITROUSN] #2868238
01/02/21 08:53 PM
01/02/21 08:53 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
It’s not a round foam gasket. It’s made of rubber and has a raised part around the studs of the motor that goes through that metal back support of the rear of the box. Those raised portions collapse to help insulate from the vibrations of the fan. It has a part number molded into it.
Re: Blower motor gasket [Re: fastmark] #2868286
01/02/21 10:29 PM
01/02/21 10:29 PM
N
NITROUSN Offline
NITROUSN  Offline
N
sorry that I do not have.
Re: Blower motor gasket [Re: NITROUSN] #2868435
01/03/21 12:28 PM
01/03/21 12:28 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Not part of the kit nor is it available from them.
