426 hemi fuel injection for crossram intake #2867728
01/01/21 07:42 PM
01/01/21 07:42 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006 OP
Rhinotruck
Rhinodart  Online Penguin-006 OP
Rhinotruck
Has anyone done a modern fuel injection system for a second gen 426 hemi using a Mopar cross ram intake? I have looked online and see the Sniper system but it was on a blower application. Anyone know someone who has done it on a cross ram? shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: 426 hemi fuel injection for crossram intake [Re: Rhinodart] #2867750
01/01/21 08:08 PM
01/01/21 08:08 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
There is no reason you couldn't. IIRC there was an article on some guys who put EFI on a either a Hemi or Big Block mopar and did the power tour a few years ago. They used two OEM throttle bodies off of something.
68 Barracuda Formula S 340
Re: 426 hemi fuel injection for crossram intake [Re: Rhinodart] #2867753
01/01/21 08:12 PM
01/01/21 08:12 PM
AndyF Online content
AndyF  Online Content
Scroll thru the "whats new" section of FAST Man EFI and you'll see that he has done most everything. https://www.fastmanefi.com/papers
Re: 426 hemi fuel injection for crossram intake [Re: AndyF] #2867789
01/01/21 09:01 PM
01/01/21 09:01 PM
STL ,MO
Handygun Offline
Handygun  Offline
STL ,MO
They used the C/R with the removable tops and had the wiring harness hidden inside the plenum, very sanitary installation.
Re: 426 hemi fuel injection for crossram intake [Re: Handygun] #2867800
01/01/21 09:19 PM
01/01/21 09:19 PM
Rhinotruck
Rhinotruck
Interesting, that is the manifold I plan on using, I will check it out! wave
A-Body's RULE!
Re: 426 hemi fuel injection for crossram intake [Re: Rhinodart] #2867893
01/01/21 11:57 PM
01/01/21 11:57 PM
Las Vegas, NV
chargerbr549 Offline
Las Vegas, NV
I believe Chucks speed and RV in Arizona did an efi on a crossram and hid alot of it inside the manifold, I had stopped in there about 10 years ago and the owner was talking about his car that was in the shop being in one of the mopar magazines where they hid alot of the efi inside of the crossram.
https://chucksspeedcenter.com/
Re: 426 hemi fuel injection for crossram intake [Re: chargerbr549] #2867903
01/02/21 12:34 AM
01/02/21 12:34 AM
Rhinotruck
Rhinotruck
Well I will be out in Scottsdale the third week of January, and in Vegas for the trip home. I will have to stop by Chuck's... wave
A-Body's RULE!
Re: 426 hemi fuel injection for crossram intake [Re: Rhinodart] #2867917
01/02/21 01:50 AM
01/02/21 01:50 AM
Use dual throttle bodies and then you don't need to worry about the plumbing and wiring. FAST makes a good dual throttle body system or you could use dual Holley Terminators. Call Rich at FAST Man EFI and he'll tell you what the best way to put EFI on a cross ram is.
Re: 426 hemi fuel injection for crossram intake [Re: AndyF] #2867983
01/02/21 10:28 AM
01/02/21 10:28 AM
Rhinotruck
Rhinotruck
I emailed him and he got right back to me, I will call him next week. Thanks again!
A-Body's RULE!
Re: 426 hemi fuel injection for crossram intake [Re: Rhinodart] #2869513
01/05/21 09:52 PM
01/05/21 09:52 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I have done this several different ways. From running two TBI throttle bodies to port injection with everything hidden inside. I'm not a fan of the results running dual TBI throttle bodies. Harder to tune, and too high in some cases. The port injection systems worked well. My first approach was using fuel rails but later I used individual -3AN lines for each injector. This was easier to fabricate and worked very well because it consumed less space.
Re: 426 hemi fuel injection for crossram intake [Re: Mopar_Rich] #2869516
01/05/21 10:02 PM
01/05/21 10:02 PM
STL ,MO
Handygun Offline
Handygun  Offline
STL ,MO
Thats the one I remember the article on. The cannon plug brought it back. Neat setup
Re: 426 hemi fuel injection for crossram intake [Re: Mopar_Rich] #2869519
01/05/21 10:03 PM
01/05/21 10:03 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
THAT is wicked ass cool
Re: 426 hemi fuel injection for crossram intake [Re: gtx6970] #2869522
01/05/21 10:11 PM
01/05/21 10:11 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Here's another one where all the injectors were mounted under the manifold in the valley area. Lots of work to machine the nozzles, but it worked GREAT!
Yes, they look like carburetors but they're just throttle bodies. Nice retro result where unless you're looking the fuel lines going to the carbs you'd never know.
Re: 426 hemi fuel injection for crossram intake [Re: Mopar_Rich] #2869562
01/06/21 01:04 AM
01/06/21 01:04 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
That is a sanitary installation but I'm curious how it might affect airflow and how much the reduction in plenum volume might matter.
Kevin
Re: 426 hemi fuel injection for crossram intake [Re: Twostick] #2869671
01/06/21 12:47 PM
01/06/21 12:47 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I did dyno this engine and it did well, but I have no before and after numbers. Obviously, this was a street/show car so all that was needed was good driveability and it had that in spades.
Re: 426 hemi fuel injection for crossram intake [Re: Mopar_Rich] #2869723
01/06/21 02:45 PM
01/06/21 02:45 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
How satisfied were you with the final injector orientation in that set-up?
It certainly looks cool, well executed, and meets all the objectives for stealth, but I'm wondering performance, flow disruption, etc wise, what it leaves on the table.
Re: 426 hemi fuel injection for crossram intake [Re: Mopar_Rich] #2870023
01/06/21 07:34 PM
01/06/21 07:34 PM
Rhinotruck
Rhinotruck
That is the ultimate goal driveability! The customer dosen't care that much about utlimate speed and quarter mile ability, he just wants to turn the key and have fun, which in the current state of tune gets old very fast!
A-Body's RULE!
Re: 426 hemi fuel injection for crossram intake [Re: Rhinodart] #2870082
01/06/21 09:18 PM
01/06/21 09:18 PM
A cross ram is the wrong intake to choose if the customer wants the engine to fire up easily and drive nicely. If the customer is willing to spend a bunch of money for an EFI conversion then it could be made to work. Not sure what the bill for a conversion like that is going to be, probably several thousand dollars.
Re: 426 hemi fuel injection for crossram intake [Re: AndyF] #2870093
01/06/21 09:33 PM
01/06/21 09:33 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Troy’s Hemi Dart cross ram fires right up. Even dead cold (So Cal)
Maybe has to do with a large plenum and crevices for fuel to puddle??
I know he put a LOT of effort into tuning it and cam selection upfront. Of course he built it, maintains it, and drives it. Having a knowledge and responsibility from cradle to grave goes a long way.
Re: 426 hemi fuel injection for crossram intake [Re: AndyF] #2870094
01/06/21 09:33 PM
01/06/21 09:33 PM
Rhinotruck
Rhinotruck
Money is never an object with him, he had the car built as a Hemi Dart clone and likes the look, just wants better driveablility as he is tired of cars that aren't fun to drvie.
A-Body's RULE!
