E-body steering column interchange #2866170
12/29/20 07:38 PM
12/29/20 07:38 PM
Scranton, PA
Montclaire Offline OP
Scranton, PA
Hello, anyone know the interchange on E-body steering columns? Specifically 1974 floor shift. I believe 71-74 are mostly the same but figured there might be a change in the wiring harness over the years. Looking for a direct drop in.
Re: E-body steering column interchange [Re: Montclaire] #2866307
12/30/20 05:59 AM
12/30/20 05:59 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
70/74 wiring doesn't really changes at column. Of course 70 column is diff due the locking system, but not on the electrical related to plugs at least. Sure ign and turning switches got their physical diff too on 70 with the rest ( also first 71s turning switches ), but still plugs remain the same so all years will plug between them.
As far I know, all 71/74 will interchange on E bodies being plug and play.
Re: E-body steering column interchange [Re: NachoRT74] #2866585
12/30/20 04:36 PM
12/30/20 04:36 PM
Scranton, PA
Scranton, PA
Thanks, Nacho - hope you are doing well.
Re: E-body steering column interchange [Re: Montclaire] #2867636
01/01/21 03:52 PM
01/01/21 03:52 PM
JCFcuda Offline
JCFcuda  Offline
If you get a 1970 steering column you will need to go to the 1970 ignition lock set.
Jim F
