Re: Question for the Electricians on 110V [Re: MR_P_BODY] #2866128
12/29/20 05:18 PM
12/29/20 05:18 PM
central il.
second 70 Offline
second 70  Offline
central il.
Originally Posted by MR_P_BODY
Well just blew another switch......screw this crap... I'll get my buddy over here when we get back from
vacation... not wasting $30 a pop down
wave
If you're blowing up switches there's something wrong. The only way the switch will blow is if it's grounded or you have opposite hot legs on each switch. Something is either grounded at the light or one of the switches. The switch you thought was good might be bad and grounded.
Re: Question for the Electricians on 110V [Re: MR_P_BODY] #2866245
12/29/20 10:20 PM
12/29/20 10:20 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
wave
Ok, you so far have spent $60.00 and add on another $30.00 for another one, that's $90.00. Hire a qualified and licensed electrician for one hour at (in my area $50.00 an hour) and get it done. Geeeezz
11B40
Re: Question for the Electricians on 110V [Re: JonC] #2866389
12/30/20 11:19 AM
12/30/20 11:19 AM
Alberta, Canada
300rag Offline
300rag  Offline
Alberta, Canada
Originally Posted by JonC
The problem is there are at least three different arrangements to wire a three way (with a single light). Without seeing how the original wiring is, it would be almost impossible to walk someone with limited knowledge through it. I know a couple Master Electrician in my area that can't even do the simple way to do it. Again, without determining how the wires are run it will be difficult to walk anyone through it. JMHO
When identifying which wires are which in a 3way circuit, the number of possibilities in how the wires are run is not relevant. All you need is the three wires on each switch. No matter what the setup is, there will always be two wires that run between and are connected to both two switches, one switch will have the line connected, and the other will have the load connected.
Peter
'65 300 'vert 413/4spd
'18 Challenger R/T Shaker
'19 Durango R/T
Re: Question for the Electricians on 110V [Re: 300rag] #2866411
12/30/20 11:51 AM
12/30/20 11:51 AM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
White is not "common", white is always "neutral". "Ground" is "common" - well of course it is - its the only wire that connects EVERYTHING.
Re: Question for the Electricians on 110V [Re: Stanton] #2866418
12/30/20 12:09 PM
12/30/20 12:09 PM
Pewaukee, WI
Airgrabber Offline
Airgrabber  Offline
Pewaukee, WI
The reason you keep blowing circuits is as follows. Green, bare copper, or aluminum on the device are the only places the ground goes period. Groups of whites never go on to any switches in this scenario. They are know as neutrals which return to the panel-board to complete the circuit 60 times a second. The odd or different color screw is for the Hot (Power) or the Switch leg which goes up to the light fixture. The other 2 single wires that are red, black, or white (which should be taped as black by code are the travelers or dummies). It does not matter whatsoever which remaining terminals the travelers get connected to. Hope this helps all of you. It's a simple 3 way meaning three terminals on the switch and the capability of controlling a fixture from 2 locations. If the light is controlled at 3 or more locations then a 4-way switch comes into the equation. Please consult a professional licensed and experienced electrician if you are unsure of what you are doing. Invest in a voltage tester as well. Happy to Year!
Re: Question for the Electricians on 110V [Re: Airgrabber] #2866509
12/30/20 02:51 PM
12/30/20 02:51 PM
5thAve Offline
5thAve  Offline
Did you pull the other dimmer switch yet to see how it was wired?
At this point I'd call an electrician. Ask for an estimate up front to avoid the ones that might try to rip out off because it shouldn't be an expensive call.
