Help Decoding a 1968 Hemi ? #2865727
12/28/20 02:59 PM
12/28/20 02:59 PM
Aripeka, Florida
2
2many Offline OP
2many  Offline OP
Aripeka, Florida
New here - so please do not blast me ! Looking for help on codes i took off of a car 68 Road Runner
I was directed here for the experts !
posting pix.
please let me know anything and everything the good bad and the ugly.
received_213699976999825.jpegreceived_435011624347343.jpegreceived_390420558726315.jpegreceived_1524419774395266.jpeg
Re: Help Decoding a 1968 Hemi ? [Re: 2many] #2865731
12/28/20 03:02 PM
12/28/20 03:02 PM
Aripeka, Florida
2
2many Offline OP
2many  Offline OP
Aripeka, Florida
I took pictures of everything. I think ?
received_1129489577485542.jpegreceived_434079397624415.jpegreceived_437604750919989.jpeg
Re: Help Decoding a 1968 Hemi ? [Re: 2many] #2865761
12/28/20 04:00 PM
12/28/20 04:00 PM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
Block was cast on April 15 1968. Assembled very late in 68 model year- 1st one assembled on June 11 1968 (maybe too late of assembly date for a '68). Non original trans out of a '66 383-4. Non original 489 rear diff '69-'74.
Re: Help Decoding a 1968 Hemi ? [Re: ratroaster] #2865771
12/28/20 04:22 PM
12/28/20 04:22 PM
So Near, Yet So Far
topside Offline
topside  Offline
So Near, Yet So Far
Hard to make out the yellow stamp date on the diff, maybe 9-18 ?
There may be another such stamped date on the left axle tube, clean that area carefully. Should be a later assy date than the diff.
What's the SPD (scheduled production date) on the fender tag ?
Any upper engine block pad stamps ?
As for the car itself: a '68-'69 will have J in VIN (5th position) and rosette VIN tag rivets.
Also K-frame sump guard, reinforcement plate on floor for pinion snubber, rear spring mount gussets & plates.
Hemi-specific underhood harness.
Oil pan bolt in pic is non-factory, FWIW.
Welcome to Moparts, there are a lot of really good & sharp folks here.
Re: Help Decoding a 1968 Hemi ? [Re: ratroaster] #2865813
12/28/20 06:18 PM
12/28/20 06:18 PM
Aripeka, Florida
2
2many Offline OP
2many  Offline OP
Aripeka, Florida
Ratroaster- Thank you, very much ! Should any of these numbers match the VIN or Production number on Fender Tag ?
Re: Help Decoding a 1968 Hemi ? [Re: topside] #2865820
12/28/20 06:38 PM
12/28/20 06:38 PM
Aripeka, Florida
2
2many Offline OP
2many  Offline OP
Aripeka, Florida
Topside - Thank you. You gave me some homework ! Took these
133720314_418638522883817_8690392744972921669_n.jpg133613726_885536882254765_6116596200216484074_n.jpg133785980_409316450417281_4935749041467729326_n.jpg133296027_403584637527885_5503741595731682197_n.jpg
Re: Help Decoding a 1968 Hemi ? [Re: 2many] #2865826
12/28/20 06:57 PM
12/28/20 06:57 PM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
Not any of the numbers you show. '68's were stamped on top rear of the engine right next to the transmission mounting flange. Kinda hard to get at when its in the car. These numbers should match the last 8 digits of the vin....
Re: Help Decoding a 1968 Hemi ? [Re: ratroaster] #2865831
12/28/20 07:27 PM
12/28/20 07:27 PM
Aripeka, Florida
2
2many Offline OP
2many  Offline OP
Aripeka, Florida
That is what someone else had said, told me to remove air cleaner - cover the carbs with a clean shop rag and climb up on fender and engine and look down !
Not thinking that is going to happen !
So all the other numbers I posted are kind of useful and not.
I Really thank you guys for the insight.
Crap.
Re: Help Decoding a 1968 Hemi ? [Re: 2many] #2865872
12/28/20 09:15 PM
12/28/20 09:15 PM
So Near, Yet So Far
topside Offline
topside  Offline
So Near, Yet So Far
What I do is lay a thick blanket over the grille & rad support area, and kinda lay on top of the carbs.
(One advantage to being skinny laugh2)
There's some debate over when they started stamping the partial VIN there, might be 1/1/68, don't know for certain.
Not uncommon for Hemis to have been replaced back in the day, or for people to stamp them after the fact (been a problem with Vettes for decades).
Reinforcement at front spring mount you posted is correct for Hemi car.
Original fuel line on them was 3/8, with a small vapor separator can near the alternator, commonly discarded/missing.
Original exhaust if still present would have resonators and chrome tips.
Wiper motor should be plated 3-speed, not black 2-speed, to clear air cleaner (Also check dash switch).
Re: Help Decoding a 1968 Hemi ? [Re: 2many] #2865889
12/28/20 09:59 PM
12/28/20 09:59 PM
BDW Offline
BDW  Offline
Crap.
Get a selfie stick and take remote pic with your cell phone.
