Re: Question for the Electricians on 110V
[Re: MR_P_BODY]
#2866245
12/29/20 10:20 PM
12/29/20 10:20 PM
Posts: 3,625 Millinocket, Maine
JonC
Millinocket, Maine
Well just blew another switch......screw this crap... I'll get my buddy over here when we get back from vacation... not wasting $30 a pop Ok, you so far have spent $60.00 and add on another $30.00 for another one, that's $90.00. Hire a qualified and licensed electrician for one hour at (in my area $50.00 an hour) and get it done. Geeeezz
11B40
[Re: JonC]
#2866389
12/30/20 11:19 AM
12/30/20 11:19 AM
Posts: 374 Alberta, Canada
300rag
Alberta, Canada
The problem is there are at least three different arrangements to wire a three way (with a single light). Without seeing how the original wiring is, it would be almost impossible to walk someone with limited knowledge through it. I know a couple Master Electrician in my area that can't even do the simple way to do it. Again, without determining how the wires are run it will be difficult to walk anyone through it. JMHO When identifying which wires are which in a 3way circuit, the number of possibilities in how the wires are run is not relevant. All you need is the three wires on each switch. No matter what the setup is, there will always be two wires that run between and are connected to both two switches, one switch will have the line connected, and the other will have the load connected.
Peter
'65 300 'vert 413/4spd '18 Challenger R/T Shaker '19 Durango R/T
[Re: Stanton]
#2866418
12/30/20 12:09 PM
12/30/20 12:09 PM
Posts: 2,642 Pewaukee, WI
Airgrabber
Pewaukee, WI
The reason you keep blowing circuits is as follows. Green, bare copper, or aluminum on the device are the only places the ground goes period. Groups of whites never go on to any switches in this scenario. They are know as neutrals which return to the panel-board to complete the circuit 60 times a second. The odd or different color screw is for the Hot (Power) or the Switch leg which goes up to the light fixture. The other 2 single wires that are red, black, or white (which should be taped as black by code are the travelers or dummies). It does not matter whatsoever which remaining terminals the travelers get connected to. Hope this helps all of you. It's a simple 3 way meaning three terminals on the switch and the capability of controlling a fixture from 2 locations. If the light is controlled at 3 or more locations then a 4-way switch comes into the equation. Please consult a professional licensed and experienced electrician if you are unsure of what you are doing. Invest in a voltage tester as well. Happy to Year!
