440 source intermediate shaft w/bronze gear #2865603
12/28/20 09:49 AM
12/28/20 09:49 AM
Maryland
mrob Offline OP
mrob  Offline OP
Maryland
Hi,
Does anyone have any experience with the 440 Source bronze gear intermediate shaft? I need to replace mine and I'm just wondering how good this one is in comparison to the Milodon or MP ones.
Link to 440 source bronze gear shaft: http://store.440source.com/Bronze-Gear-Intermediate-Shaft/productinfo/200-1085/
Re: 440 source intermediate shaft w/bronze gear [Re: mrob] #2865612
12/28/20 10:27 AM
12/28/20 10:27 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Use the Crane melonized instead if you are changing out for a roller cam.
'63 Dodge 330
11.19 @ 121 mph
Re: 440 source intermediate shaft w/bronze gear [Re: GY3] #2865646
12/28/20 12:09 PM
12/28/20 12:09 PM
Maryland
mrob Offline OP
mrob  Offline OP
Maryland
Hi GY3,
Thanks for the response, but I don't think that I can use the melonized gear because I've had the hydraulic roller cam in my motor for 6 years. As far as I know, you're supposed to use the melonized gear with a new cam. That's why I'm asking about my options for the bronze gears.
Re: 440 source intermediate shaft w/bronze gear [Re: mrob] #2865654
12/28/20 12:32 PM
12/28/20 12:32 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I don't have first hand knowledge of their part, but make sure you limit it's up and down travel with a distributor shaft collar. My bronze gear wear was dramatically reduced once I did that. I was going to try and have the part cryo treated by Hughes, but I switched cams and went with the melonized gear.
Re: 440 source intermediate shaft w/bronze gear [Re: jbc426] #2865722
12/28/20 02:54 PM
12/28/20 02:54 PM
Maryland
mrob Offline OP
mrob  Offline OP
Maryland
Thanks, jbc. That's a very good idea.
If I remember correctly, a 1/2" ID shaft collar will work (like shown in your pic). Do you remember where you found yours?
Re: 440 source intermediate shaft w/bronze gear [Re: mrob] #2865842
12/28/20 07:57 PM
12/28/20 07:57 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Ace Hardware and Tractor Supply have them
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 440 source intermediate shaft w/bronze gear [Re: mrob] #2866085
12/29/20 03:28 PM
12/29/20 03:28 PM
Idaho
LaRoy Engines Offline
Idaho
I haven't purchased the 440 Source bronze gear intermediate shafts for over 10 years now. My experience with them at that time has me buying the Mopar or Milodon ones now. Who knows....they may have been improved since then.
Re: 440 source intermediate shaft w/bronze gear [Re: LaRoy Engines] #2866122
12/29/20 05:11 PM
12/29/20 05:11 PM
Maryland
mrob Offline OP
mrob  Offline OP
Maryland
Thanks for the responses. Guess I'll be a guinea pig and order one. Hope it turns out to be a useable part.
Re: 440 source intermediate shaft w/bronze gear [Re: mrob] #2866136
12/29/20 05:54 PM
12/29/20 05:54 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
As mentioned above, and at the other online hard parts suppliers as well. Be sure to disassemble and thoroughly clean the set screw and collar with brake or carb cleaner and loctite the screw. I also replaced and burnished the intermediate shaft bushing with the Mopar specific tool, lubed it with assembly lube and used a feeler gauge between the combined parts to position the collar once the distributor hold down was fully seated. I left the collar just snugged at first to allow it to slide to the proper position, and then fully tightened it. That allows enough room for oil to float the intermediate shaft gear on the top of the bushing.
Re: 440 source intermediate shaft w/bronze gear [Re: jbc426] #2866359
12/30/20 10:04 AM
12/30/20 10:04 AM
Maryland
mrob Offline OP
mrob  Offline OP
Maryland
Thanks for the detailed explanation jbc! One more question: which type of Loctite do you recommend? The high temp red or the high temp blue?
Re: 440 source intermediate shaft w/bronze gear [Re: mrob] #2866445
12/30/20 01:09 PM
12/30/20 01:09 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Loctite has somewhat recently come out with an orange loctite that holds like red, but removes easier, more like the blue. I have been using red lately and only one fastener was super hard to disassemble, but still doable. I'm going to buy some of the orange if I can find it.
