Page 1 of 4 1 2 3 4
Parasitic draw or bad battery #2864873
12/26/20 12:40 PM
12/26/20 12:40 PM
Central Florida
larrymopar360 Offline OP
Stud Muffin
Stud Muffin
Central Florida
Been wondering if I have a parasitic draw or battery going bad in my Diplomat AHB. Battery runs down way to quick after sitting just a week to ten days in the garage. It's a big Interstate just over three years old. I finally got around to pulling negative cable and checking with multi-meter, and shows 60 milliamps. I thought this was kind of a lot, but wasn't sure, so I pulled every single fuse, and NO change.
Battery going bad? Am I missing something? I pulled every fuse. Is 60 Ma unusual necessarily?
Thanks.
Larry
Facts are stubborn things.
Re: Parasitic draw or bad battery [Re: larrymopar360] #2864879
12/26/20 12:51 PM
12/26/20 12:51 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Ensure you have everything turned off, map lights etc. if you have a newer vehicle with an ECM etc. you will need to let it "time out" or "go to sleep" for testing the draw, this includes ensuring your door is closed (no draw from a dome light, under hood light etc.)
Disconnect the negative battery terminal, now make that connection by hooking an ammeter between the batteries negative terminal and the disconnected battery cable end.
This will tell you the draw.
You can pull fuses and disconnect things until you find the suspect circuit. Then you will know if you have an excessive draw.
Re: Parasitic draw or bad battery [Re: UCUDANT] #2864884
12/26/20 01:07 PM
12/26/20 01:07 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Disconnect the alternator and check it again.
Kevin
Re: Parasitic draw or bad battery [Re: Twostick] #2864903
12/26/20 02:01 PM
12/26/20 02:01 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Kevin
Okay, will do. So are you saying 60Ma could be normal, and should always test with alternator disconnected, or that alternator might be bad (bad diode)?. I'm going to test with it disconnected, just wondering what to conclude afterward. If no change and still 60Ma then what? Or, if significant drop? Thanks, Larry.
Re: Parasitic draw or bad battery [Re: Twostick] #2864910
12/26/20 02:15 PM
12/26/20 02:15 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Kevin
Feel the alt.& see if its warm,alts.can draw on a battery when there's an internal fault.
Re: Parasitic draw or bad battery [Re: 71GTX471] #2864911
12/26/20 02:16 PM
12/26/20 02:16 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Kevin
Okay will do. It was really strange that the meter never moved even a tiny bit when I pulled any of the fuses. Thanks! Larry
Re: Parasitic draw or bad battery [Re: UCUDANT] #2864916
12/26/20 02:22 PM
12/26/20 02:22 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
when disconnecting the neg.batt. terminal to connect a DVOM you have to hold the leeds against the terminals if it disconnects & goes open the vehi.wakes up again {on newer cars} & you have to wait for it to go to sleep again.
Re: Parasitic draw or bad battery [Re: 71GTX471] #2864932
12/26/20 02:39 PM
12/26/20 02:39 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Re: Parasitic draw or bad battery [Re: 71GTX471] #2864939
12/26/20 02:52 PM
12/26/20 02:52 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Dodge Diplomat AHB. '89. I had help so leads were secure. Had to have help so I could pull fuses one by one.
Re: Parasitic draw or bad battery [Re: larrymopar360] #2864943
12/26/20 02:59 PM
12/26/20 02:59 PM
Andrewh Online content
Andrewh  Online Content
what does the battery voltage measure just sitting there?
I ran into the same question and then remembered that a battery going bad isn't going to have a high resting voltage like a new one.
the battery was 12.5 volts. vs the normal 13.5 you would expect.
I even ran it on a charger for a while and it came back down to the 12.5 volts after just sitting.
Re: Parasitic draw or bad battery [Re: Andrewh] #2864962
12/26/20 03:59 PM
12/26/20 03:59 PM
5thAve Offline
5thAve  Offline
I've had a lot of bad batteries the last few years. Some even loose their charge being disconnected. Others being connected even the smallest load like what the clock memory draws is enough to make a difference even if the battery holds a charge when it's disconnected.
If you have the ignition switch light make sure that goes off. That stopped timing out on a friends car. Unless there's something aftermarket the only real stuff on an M to cause drains is problems with the radio, ignition module, or a light that's not going out. Or the alternator thing that was mentioned altho I've never personally seen that problem.
Re: Parasitic draw or bad battery [Re: Andrewh] #2864969
12/26/20 04:15 PM
12/26/20 04:15 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I wouldn't expect a 13.5V reading on a battery. 12.6v is fully charged. 12.5v isn't bad at all.
https://haynes.com/en-us/tips-tutorials/how-test-car-battery-multimeter
Re: Parasitic draw or bad battery [Re: 5thAve] #2864971
12/26/20 04:26 PM
12/26/20 04:26 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I thought about the ignition light but either it's burned out or disabled due to AHB. Factory radio so minimal draw there. As you mention, not much on M bodies. I'm going to test again with alternator disconnected. I did leave negative cable disconnected yesterday after testing, just to see if that changes anything. I probably won't have a chance to get back to testing it again for a week or so anyway.
Re: Parasitic draw or bad battery [Re: 5thAve] #2864992
12/26/20 05:42 PM
12/26/20 05:42 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Gonna add rear window defrost to list.
Also, forgive me,but I've noticed in a lot of your post you feel to follow diplomat with AHB or AFB why is that?
Re: Parasitic draw or bad battery [Re: moparjim79] #2865003
12/26/20 06:01 PM
12/26/20 06:01 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
AHB means cop spec, lots of differences between the cop and civilian spec M bodies.
Re: Parasitic draw or bad battery [Re: larrymopar360] #2865057
12/26/20 08:58 PM
12/26/20 08:58 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Thanks.
Larry
Yessir and that will drain a good battery. If pulling the fues didn't identify the culprit then it is something likely connected all the time, IE: alternator as suggested, starter, starter relay (doubtful), ignition switch or wiring in the column. Has to be something that is non fused (box wise) and connected to the battery when the switch is off. I had one that drove us nuts for a bit, it was the clock motor that wound the spring. The clock didn't work so I didn't think to looks at it. However the points that open when the spring is wound were stuck shut thereby energizing the clock motor 24/7. Can't remeber the draw but it was 30ma + I think, Happy hunting and do keep up posted beer)
Re: Parasitic draw or bad battery [Re: TJP] #2865080
12/26/20 09:45 PM
12/26/20 09:45 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Thanks.
Larry
Thanks for reply. I'm going to first try disconnecting alternator. Hope that's it, because I actually have a spare taking up room.
Re: Parasitic draw or bad battery [Re: larrymopar360] #2865191
12/27/20 11:11 AM
12/27/20 11:11 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
When you first take a battery off the charger you will have a "surface charge" which is really fake news for voltage. Do something like turn the headlights on for a second then back off and you will see the actual voltage after that. A fully charged 12V battery at rest should be 12.65-12.75 at rest. Even as low as 12.3 is significantly discharged and has a big effect on the output capability.
The alternator is a good place to check like mentioned before. It sure is frustrating when the item that charges the battery also discharges it.
68 Barracuda Formula S 340
Re: Parasitic draw or bad battery [Re: Bad340fish] #2865216
12/27/20 12:27 PM
12/27/20 12:27 PM
Alberta
440_Offroader Offline
Alberta
If you have an aftermarket voltage gauge installed, it could be that as well. I had one it my Powerwagon, that would discharge the battery enough in a week, it wouldn't turn over. Not sure why a gauge would do that, but it did.
Re: Parasitic draw or bad battery [Re: 440_Offroader] #2865261
12/27/20 02:11 PM
12/27/20 02:11 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Good suggestion wink It did that because it is supposed to be hooked up to a "switched" source meaning it turns off with the ignition switch or it will continue to draw current and drain the battery. We have seen that issue a couple of times ourselves beer
Page 1 of 4 1 2 3 4
