Re: B Body Sending Unit
[Re: Tony440]
#2865201
12/27/20 11:49 AM
12/27/20 11:49 AM
Posts: 10,713 North Dakota
6PakBee
North Dakota
It's been a long time since I did it but I replaced the sending unit on a '67 Belvedere years ago. IIRC, I did not have to drop the tank. If you can get the car on a hoist, do it. Makes the job soooo much easier.
[Re: Tony440]
#2865258
12/27/20 02:06 PM
12/27/20 02:06 PM
Posts: 15,350 Omaha Ne
TJP
Omaha Ne
In over 50 years I have never seen a blocked line inside a tank. I would suggest putting a vacuum gauge on the pump to make sure it's pulling and then move the gauge to the hose at the sending unit and repeat the test. If you have the same vacuum reading then you have eliminated everything to the tank You didn't say what motor, type of pump etc. you're dealing with so I'm assuming it's a mechanical pump. A l oose or rotted hose or a pinhole in the line (rusty) will wreak havoc. If it happens to be a big block it could also be the fuel pump pushrod. getting the car up with the rear end hanging will give you much better access to the sending unit if you do wind up going there. keep us posted
[Re: TJP]
#2865278
12/27/20 02:37 PM
12/27/20 02:37 PM
6PakBee
North Dakota
In over 50 years I have never seen a blocked line inside a tank. I would suggest putting a vacuum gauge on the pump to make sure it's pulling and then move the gauge to the hose at the sending unit and repeat the test. If you have the same vacuum reading then you have eliminated everything to the tank You didn't say what motor, type of pump etc. you're dealing with so I'm assuming it's a mechanical pump. A l oose or rotted hose or a pinhole in the line (rusty) will wreak havoc. If it happens to be a big block it could also be the fuel pump pushrod. getting the car up with the rear end hanging will give you much better access to the sending unit if you do wind up going there. keep us posted Unfortunately, the Belvedere one I replaced was due to the 'sock' filter in the tank being completely and totally plugged with crud. So yes, it does happen. As a note, if you resort to blocking or jackstands, keep the car level. If you have the rear end elevated and there is gas in the tank, there is a good possibility of it coming out when you remove the sender. DAMHIK. I know some will talk about siphoning the gas out but I have never had good luck doing that on a '67 B-body tank. Just be careful, we don't want to play Buddhist monk here.
[Re: TJP]
#2865307
12/27/20 03:55 PM
12/27/20 03:55 PM
Posts: 4,724 Florida
BDW
A l oose or rotted hose or a pinhole in the line (rusty) will wreak havoc. keep us posted This happened to me, rubber line from hard line to fuel pump had small split/hole that took me a while to figure out.
[Re: Tony440]
#2865628
12/28/20 11:13 AM
12/28/20 11:13 AM
Posts: 6,241 nowhere
Sniper
nowhere
Thanks again for everyone's input since the rubber line from the steel line to the pump and the line from the sending unit to the steel line is over 20 years, old I'm going to replace them as a start. I was always told that you should not put one of the paper type filters before the pump, because it will decrease fuel pressure to the pump. That's why the factory put the fuel filter between the pump and carbs. Is this true? Is it true? Yes and no. It doesn't "decrease fuel pressure to the pump" as there is no pressure there, but rather a vacuum. What it does is make it harder for the pump to draw from the tank and the dirtier the filter gets the more it affects the draw. Fuel pumps are better at pushing than pulling so you don't want a restriction on the pull side The sock on the pickup in the tank is fairly coarse and is designed to keep the big chunks out of the pump. The filter between the pump and carb is designed to catch much smaller stuff that normally does not affect the pump but will affect the carb.
[Re: Sniper]
#2865657
12/28/20 12:51 PM
12/28/20 12:51 PM
TJP
Omaha Ne
But will clarify, A paper filer before the pump may restrict the flow a small amount and technically require a bit more vacuum (which is negative pressure) But it is unlikely you would be able to measure the difference unless you were using laboratory grade instruments. But as stated above if the filter starts getting dirty, the vacuum the pump produces will remain the same, but the flow will be reduced. The dirtier it becomes the lower the flow to the point it is completely blocked. If you look at most fuel injection aftermarket systems they require a 10 micron filter Before the pump and a 3 micron after
