Re: To Clutch fan or Not to Clutch fan
[Re: Sniper]
#2865596
12/28/20 09:34 AM
12/28/20 09:34 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
This graph show the viscous clutch on the original Mopar 340 V8 Doubtful, the 340 isn't a 5.7L. More likely it's a SBC. No, I have read those two footnotes and the fan/viscous data is from a Society of Automotive Engineers (SAE) on the then new 340 V8. Some of the generator shaded area in the graph showing variation is from a SBC 350
[Re: 360view]
#2865602
12/28/20 09:49 AM
12/28/20 09:49 AM
Posts: 6,246 nowhere
Sniper
nowhere
This graph show the viscous clutch on the original Mopar 340 V8 Doubtful, the 340 isn't a 5.7L. More likely it's a SBC. No, I have read those two footnotes and the fan/viscous data is from a Society of Automotive Engineers (SAE) on the then new 340 V8. Some of the generator shaded area in the graph showing variation is from a SBC 350 You'd think the SAE would know the difference between a 5.6 and a 5.7l engine. Of course one wonders where they found a 350 with a generator since they started using an alternator in 65 and the 350 came out in 67. Basic mistakes like that makes you doubt the data.
[Re: Sniper]
#2865635
12/28/20 11:47 AM
12/28/20 11:47 AM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
FFS's electric.Try ZERO horsepower loss. What is wrong with you people? Except for the HP to run the alternator to run the fan, no free rides out there. As long as you stay moving Sniper. My electric fan never runs.
Mo' Farts
Moderated by "tbagger".
[Re: gtx6970]
#2865716
12/28/20 02:47 PM
12/28/20 02:47 PM
Posts: 12,076 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Clutch or not to clutch.
Just how much gain is there to be had by a clutch? Are you running pro stock where every last horse power needs to be there?
For me, a failing fan clutch is one less thing I have to worry about failing down the road. Be it a torgue drive or temp controlled IMO makes no difference. Sooner or later it will fail.
Ive heard the argument a direct drive fan is noisier , I'll call BS to that . Mine inst loud at all and I assure you I can not hear it windows open or closed, I surely cant hear it going down the road Always room for one more opinion. Even when that opinion is the complete opposite of all the other posters.
Master, again and still
[Re: DaveRS23]
#2865750
12/28/20 03:37 PM
12/28/20 03:37 PM
Posts: 21,428 It's a dry heat
gtx6970
It's a dry heat
So,,,,,,Just how much is to be gained by adding a clutch fan over a direct drive fan ? Anyone done a side by comparison is the blade pitch any different between the 2 styles of fans The diam and blade count is the same. Then makes since the only gain is horsepower. So whats the side by side comparison ?
[Re: gtx6970]
#2865863
12/28/20 08:52 PM
12/28/20 08:52 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
So,,,,,,Just how much is to be gained by adding a clutch fan over a direct drive fan ? Anyone done a side by comparison is the blade pitch any different between the 2 styles of fans The diam and blade count is the same. Then makes since the only gain is horsepower. So whats the side by side comparison ? It is not a big deal nor is it worth arguing about. Virtually all OE manufacturers went to the clutch fan as they became available and cost effective. Especially our Mopars. If you want to live in the pre-68 +/- era, that is your prerogative. For the rest of us, post '68 with a clutch fan or post '85 +/- electric fan is the way to go. Your opinion goes against 50+ years of experience for the OEs and most posters here. And you are welcome to it.
[Re: gtx6970]
#2865894
12/28/20 10:12 PM
12/28/20 10:12 PM
Posts: 15,355 Omaha Ne
TJP
Omaha Ne
Ive heard the argument a direct drive fan is noisier , I'll call BS to that . Mine inst loud at all and I assure you I can not hear it windows open or closed, I surely cant hear it going down the road There are no simple answers to your question as the size, pitch and number of blades all come into the equation. Normally a Clutch fan will have a more aggressive draw when engaged than a non clutch version but only drains the power when it's needed. The non clutched version on the other hand is a constant drain on the output of the motor whether it's needed or not. I believe when people say a direct drive is noisier they are likely referring to an aftermarket flex fan some which can be very noisy. If I remember correctly articles in the past have claimed a 7-10 hp difference on a healthy V8 A post over at A bodies only claims a 15 HP difference was verified on a dyno, I'd like to see the article as the only way to confirm that is if they used the same exact fan w and w/o a clutch and repeated the test several times LINK TO A BODIES POST
[Re: 360view]
#2866285
12/30/20 12:55 AM
12/30/20 12:55 AM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
Try running that big 7 blade fan without a clutch at 6000 rpm or more. You will be wasting 40 horsepower if the belt stays on. A fan clutch is the next best thing to electric. Better than a flex fan. On some cars, electric look/sounds too stupid, so you need mechanical.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: 360view]
#2866290
12/30/20 01:14 AM
12/30/20 01:14 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
Some of the 18 wheel trucks now use fan clutches that you can engage or disengage electrically. I would not mind trying one of those. I tried the electrically engaged Horton on my '96 Diesel Dually, I saw NO gains at all. When engaged it was NOISY. Later I got an FL-60 w/ Cat 3126, 250hp with a viscous thermostatically controlled fan. I went back to stock and sold the Horton. I'd like to try the Mercedes electric setup but don't really want to upgrade my '60's electrical system to deal with it.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 360view]
#2866296
12/30/20 02:07 AM
12/30/20 02:07 AM
Posts: 6,003 Salem
Grizzly
Salem
I liked my experiments running without any radiator fan, except the one time I hit a near traffic stall on an Atlanta ring road during hot weather when I wanted the AC to have airflow while barely inching along. Mack has had that since at least 1980. I would turn the fan on when going down hill and use it for braking and max cooling then over-ride the fan and shut it off when climbing the other side. Yes, I said "braking": that's how much power that fan is making when it's locked up. Speaking of brakes, if the water temp was too much and you still had hill left to climb and had to switch the fan back on, it was like tapping the brake. I took my fans off all my Rams. One has an electric and I never use it. But, I don't have gridlock to deal with either. Carry on with your debate about clutch vs solid...........I'll stick with my electric or no fan at all. Less water pumps to replace too because that heavy turd is not beating on that little bicycle bearing that's in the water pump (which fails every time) And Joel, yes, I agree with you the electric fan looks stupid on a vintage car, especially to folks like you and I that appreciate a stock appearance. But the benefits out-weigh the esthetics. Hide it inside the rad shroud, that's what I do.
Mo' Farts
[Re: 3hundred]
#2866362
12/30/20 10:06 AM
12/30/20 10:06 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I'd like to try the Mercedes electric setup but don't really want to upgrade my '60's electrical system to deal with it. I ran the Mercedes fan on a blown Hemi A body I built a few years ago. There was no room for any kind of mechanical fan. It did a great job of cooling. I would have one on my Cuda today, but the clutch fan does a good job and I like the period correct look. The only down side with the clutch fan was when I ran the KOS races at the local track. It was tough to keep the engine as cool as I wanted while sitting in the staging lanes when we hot lapped. No overheat issues, just wanted the engine cooler at the line.
[Re: gtx6970]
#2866365
12/30/20 10:17 AM
12/30/20 10:17 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Agreed, I've run nothing but 5-7 blade fixed fans for decades on my toys, no complaints, then again for those that can hear their fan over their exhaust note, then their not driving a real "musclecar" in the first place....
[Re: DAYCLONA]
#2866391
12/30/20 11:22 AM
12/30/20 11:22 AM
Posts: 348 Isle of Sheeps
Gtxxjon
Isle of Sheeps
Who would have thought you could this much discussion over a fan? Well it has been raging for many years and there is no definitive answer. Form over function, stock or custom, how hot is too hot? Most cars and trucks work well ‘most of the time’ with any fan type. The poo hits the fan when it’s a hot windless day and you hit a JAM! I haven’t daily driven a Mopar for many a year, but I have friends who do. One uses an Ali rad with an electric fan and the other has an original rad and clutch fan. Both live in around the biggest car park in Europe called the M25 motorway... Well on the whole, they both do OK most of the time... Once the engine gets really hot, it’s real hard to get the heat back out with an all iron engine...
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
[Re: 383man]
#2868545
01/03/21 04:44 PM
01/03/21 04:44 PM
Posts: 5,108 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
It is all about trail and error. If you are a car show groupie then run a clutch and you can not hear it when the car is shut off. I have run and electric water pump drive on my motor on the street cooled ok but was a better choice for the track. Right now I run a 26 inch nice clean factory rad, mated water pump and housing rad has the shroud.I do not run a clutch on my factory 7 blade fan. I also have a hi flow thermostate 160. It is a 430 ci Hemi and it is more than stock and see a lot of RPM. Mech. gauge shows 163 degrees.I have driven it in 90 plus degrees and it still runs 163. I can see on the gauge move when the 160 opens up. These clutch fans have some noise to them so you might have to live with it. I have seen more than one fan come apart at the track so High RPM might not be a good thing for the factory clutch. Your choice of what you use, some times there is no answer to your question until you play with parts.
1971 HEMI E BODY REGISTRY
