The “Do’s” for high performance/Race engines that sit a whil #2863518
12/22/20 07:07 PM
12/22/20 07:07 PM
New York, USA
Chargerfan68 Offline OP
New York, USA
I generally do drive my cars all year round and keep them regularly exercised. But, sometimes, due to the weather in the Northeast with snow on the roads, once every couple of years, my cars sit for a few months. I used to have a habit of running the engine every 2 weeks or so in garage or driveway without driving them and then shutting it down after a few minutes. I’ve learned that’s not the best thing for the car. So, what i have been doing in the past 10 years or so is:
1. Have fuel stabilizer in tank and run car at end of season with it before parking it
2. Rotate by hand, the engine 1/4 turn every 2 weeks.
3. Keep car/tires up off ground if parked for more than a month
4. Keep battery maintained by auto charger
That’s it. Is there anything else that i should be doing for short term storage? What do you do if parked for a month-6 months long?
Re: The “Do’s” for high performance/Race engines that sit a whil [Re: Chargerfan68] #2863582
12/22/20 09:17 PM
12/22/20 09:17 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
You probably do it, but never store an engine with used oil in the pan. Combustion makes acids, most go out the tail pipe, but some get into the engine oil because of blow-by. Depends how dirty the oil is but the acid can etch the bearings.
Re: The “Do’s” for high performance/Race engines that sit a whil [Re: Chargerfan68] #2863595
12/22/20 09:42 PM
12/22/20 09:42 PM
New York
polyspheric Offline
polyspheric  Offline
New York
DO NOT start the engine unless you can drive it long enough to get the oil temperature up.
Boffin Emeritus
Re: The “Do’s” for high performance/Race engines that sit a whil [Re: polyspheric] #2863638
12/22/20 10:33 PM
12/22/20 10:33 PM
Mo.
racerx Offline
racerx  Offline
Mo.
I try to bring my up to 180-200 temp. burn off the moister in the fuel (e-85) and shut it down.
Re: The “Do’s” for high performance/Race engines that sit a whil [Re: polyspheric] #2863664
12/22/20 11:37 PM
12/22/20 11:37 PM
iagree up
Same thing on using the starter to turn the motor over with no oil pressure tsk Don't do THAT runaway
That practice and the reasoning for it started back in the mid 1950 with the then new SB V8 Chevy motors, the racers would turn them over with the starter with the coil wire or ignition feed switch off until they got oil pressure and then let the motor fire off, STUPID rant
The oil pump will provide oil pressure a lot quicker at 500+ RPM running than it will at 25 to 100 RPM on the starter shruggy work
As far as condensation in any metal containers, including engine and transmission cases, moisture will condense inside of them when the outside air temps. change from night time until day time of more than 20F whiney
I learn that while living in SO CA in the Mojave desert, I found a thin skim of rust in a cylinder in one of my old race cars stored inside my enclosed insulated shop that wasn't heated, air temps would vary from 105 F during the day to close to 60F at night in the summer, similar differences in the fall, winter and spring going from 75F during the day down to +15 F at night shruggy
Re: The “Do’s” for high performance/Race engines that sit a whil [Re: Chargerfan68] #2863771
12/23/20 08:38 AM
12/23/20 08:38 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
if longer than a month or two, take the plugs out. Spray some WD40 in each cylinder or 10W oil. Rotate the engine every week or 10 days to keep the cyl walls rust free . Other than that depending on where the car is stored thing about capping off the exhaust.
....BAD A$$ STREET CAR.....
Re: The “Do’s” for high performance/Race engines that sit a whil [Re: n20mstr] #2863792
12/23/20 09:33 AM
12/23/20 09:33 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I keep mine on a Battery Tender any time the car is home , since I rewired the car and went to a one wire alternator the tender goes from charge mode to maintain mode with in a few minutes. I start it every week to ten days and run it for a couple of minutes. I always turn the fuel pump off and run the carb out of fuel before shutting it off. Put the rear on jack stands to get the tires off the ground. An advantage to that is when I run the car I can run the trans and rear also.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: The “Do’s” for high performance/Race engines that sit a whil [Re: racerx] #2863832
12/23/20 10:59 AM
12/23/20 10:59 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Regardless of water temperature, oil temperature tracks load and won't even exceed ambient by much unless the car is driven.
Boffin Emeritus
Re: The “Do’s” for high performance/Race engines that sit a whil [Re: polyspheric] #2863989
12/23/20 05:42 PM
12/23/20 05:42 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Drain the fuel tank, run engine until all fuel is out of fuel system, turn engine over with ignition off while spraying WD 40 into carb, shoot WD40 it carb bleeds, change or drain the oil, back off all rockers to relieve spring pressure, seal exhaust. Worked for me for years and never had a problem.
Re: The “Do’s” for high performance/Race engines that sit a whil [Re: polyspheric] #2864137
12/23/20 11:27 PM
12/23/20 11:27 PM
New York, USA
New York, USA
Yeah....i used to do that and then learned the damage i was doing. So, i don’t runnit anymore unless i take it out to get full operating temp. Thx
Re: The “Do’s” for high performance/Race engines that sit a whil [Re: Dabee] #2864140
12/23/20 11:30 PM
12/23/20 11:30 PM
New York, USA
New York, USA
I used to do all that and use fogging oil down carb when i put them to sleep for many long months. But, now i just keep them parked 2 months max. I make sure they are driven during the cold season when no snow out.
Re: The “Do’s” for high performance/Race engines that sit a whil [Re: Chargerfan68] #2864195
12/24/20 07:16 AM
12/24/20 07:16 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I don't do anything besides disconnect the battery. Even with my racecar I'd let it sit untouched. Now my 440+6 RR gets the same treatment. Park it in the fall, drive it in the spring,
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: The “Do’s” for high performance/Race engines that sit a whil [Re: A39Coronet] #2864281
12/24/20 12:28 PM
12/24/20 12:28 PM
A727Tflite Offline
A727Tflite  Offline
Same here. One year I parked my stocker and it sat in the garage a whole year.
Then decided to race it at the Gators. Took it out of storage, washed it, warmed it up and changed the oil, filter and plugs and threw it in the car hauler.
Of course fuel was better back then.
