Re: Portable safe heater for crawl space?
[Re: 70satelliteguy]
#2863439
12/22/20 04:14 PM
12/22/20 04:14 PM
Posts: 3,419 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
I need some heat to keep pipes from freezing in a small area where water pipes enter my home from the well. It only happens in very cold weather. It is an area that could easily catch fire if you use the wrong thing that falls over or cannot get too close to things. . Is thermostatic electrical pipe wrap safe to use or is something better available? What do you guy's use? I already have it covered with insulation but the coldest weather is coming. Thanks Mike If you are mainly wanting to keep the pipes from freezing I would use heat trace (electric heating cable). IMO it would be the safest and most efficient. Most are thermostatically controlled. Only down side for you is that ideally you would put it between the pipe and the insulation, not on top of the insulation, so you would have to remove and reinstall yours. Go to the Grainger website and search "heat trace" Many, many options to choose from.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: 5thAve]
#2863486
12/22/20 05:58 PM
12/22/20 05:58 PM
Posts: 4,334 Morrow, OH
markz528
Morrow, OH
2nd the heat trace. That's what I was going to say. Use self temperature regulating heat trace and insulate it.
[Re: markz528]
#2863531
12/22/20 07:38 PM
12/22/20 07:38 PM
Posts: 2,937 Calgary, Alberta Canada
a12rag
2nd the heat trace. That's what I was going to say. Use self temperature regulating heat trace and insulate it. Self regulating cable needs a thermostat to control it. It still is conducting, i.e. ON, all the time . . . it does not "shut itself off" . . .only regulates the amount of current and hence heat based on ambient temperature. Make sure you get thermostat . . . . follow all instructions. Good luck . . .
[Re: a12rag]
#2863537
12/22/20 07:41 PM
12/22/20 07:41 PM
Posts: 21,910 Kirkland, Washington
Pacnorthcuda
2nd the heat trace. That's what I was going to say. Use self temperature regulating heat trace and insulate it. Self regulating cable needs a thermostat to control it. It still is conducting, i.e. ON, all the time . . . it does not "shut itself off" . . .only regulates the amount of current and hence heat based on ambient temperature. Make sure you get thermostat . . . . follow all instructions. Good luck . . . There a LOT of tapes that have the thermostat built in. It’s a plastic button at the beginning of the tape that you secure against the pipe and it controls when the tape turns on. These are about 25-35 bucks and typically 20-30 feet.
[Re: MI_Custumz]
#2863780
12/23/20 09:07 AM
12/23/20 09:07 AM
Posts: 9,719 Home
SRT6776
I hate internal combustion engines!
Home
