Re: Best points conversion these days
[Re: SomeCarGuy]
#2862866
12/21/20 09:35 AM
12/21/20 09:35 AM
Posts: 4,961 WI
Dcuda69
WI
MSD stuff works ok, until it doesn’t. I always saw those fail suddenly and stayed away Agree but.....I've been turning wrenches since electronic ignition was new. I've seen them all fail,GM,Chrysler,Ford, Honda,Toyota, Mallory, MSD, etc. They all work great until they don't...that's the electronic part...lol. Sometimes ya just gotta pick something and run with it while hoping for the best. I currently run an Mopar dist and an orange box w/MSD coil in my stroker low deck. It's all 25 years old and works perfect. I'm aware once that old orange box craps I'll need something else and the new stuff is scrap so I have an MSD box waiting in the wings......$100 from a buddy that took it off his car, I heard it run minutes before he removed it.
[Re: Dcuda69]
#2862896
12/21/20 11:50 AM
12/21/20 11:50 AM
Posts: 20,925 A collage of whims
topside
A collage of whims
Something I learned several years ago is that the MSD boxes are sensitive to degradation of oil-filled coils, especially if the coil is horizontally mounted. Pretty much a lottery as far as time, as those coils aren't completely full of oil. An epoxy-filled coil avoids that, but doesn't look stock. On several cars since, I've used a re-curved MP electronic dist, MSD6 box, and F150 epoxy coil, when stock-appearing wasn't necessary. On every one, the cars will light off almost immediately, run crisply, and run without failure.
It's one of the areas where restoration/originality and higher performance diverge, like headers.
[Re: moparx]
#2863136
12/21/20 09:50 PM
12/21/20 09:50 PM
Posts: 15,536 Omaha Ne
TJP
Omaha Ne
probably the ONLY good thing about a GM HEI conversion is, you can find a modual at any grocery store or library around the country for 89 cents plus tax if yours takes a dump. ![biggrin biggrin](/ubbthreads/images/graemlins/custom/biggrin.gif) if you want to carry a spare in the glove box, they take up slightly less room than a ballast resistor. just my ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) which is worth "slightly" less than that. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) As you can with the mopar stock electronic system. I learned a lesson 40+ years ago about the aftermarket cr-p. I worked swing shift and got off at midnight. Still wide awake i decided to hit the locak car wash and hose my engine down. I THOUGHT I was prepared with paper towels etc if the Dist. got wet. Sure enough it did. I popped the cap off and was drying things up when i heard this "ting" noise. It didn't take to long to find the center conductor of the rotor on the back of the motor. Back then they still had "SERVICE STATIONS" and many were open & within walking distance. But none had a rotor for a Mallory distributor. the stock stuff works well with a few upgrades IMO. Now if you have 14:1 compression and running on alcohol. Go for the MSD, otherwise put you $$ somewhere that will do some good ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: moparx]
#2863171
12/21/20 11:20 PM
12/21/20 11:20 PM
Posts: 4,961 WI
Dcuda69
WI
probably the ONLY good thing about a GM HEI conversion is, you can find a modual at any grocery store or library around the country for 89 cents plus tax if yours takes a dump. ![biggrin biggrin](/ubbthreads/images/graemlins/custom/biggrin.gif) if you want to carry a spare in the glove box, they take up slightly less room than a ballast resistor. just my ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) which is worth "slightly" less than that. While that was true a few years back it may not be now.....just did a quick search of the AZ,Advance,Napa stores in my area....they all list the 4 pin HEI module but none in stock. Couple days out. Gotta remember those 4 pin modules were late 70s...by the mid 80s GM had incorporated ECM control and the modules changed......soon after distributors disappeared. Coil packs for an LS are likely easier to come by than a 4 pin HEI module.
[Re: SomeCarGuy]
#2863207
12/22/20 04:34 AM
12/22/20 04:34 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
There is not a failure proof system nowdays. So I would stick with Pertronix yet for the easy conversion on stock look.
[Re: NachoRT74]
#2863263
12/22/20 10:31 AM
12/22/20 10:31 AM
Posts: 6,330 nowhere
Sniper
nowhere
There is not a failure proof system nowdays. So I would stick with Pertronix yet for the easy conversion on stock look. Points are a whole lot less failure prone than the offshore electronic crap being foisted on us these days.
[Re: Dcuda69]
#2863299
12/22/20 11:43 AM
12/22/20 11:43 AM
Posts: 4,704 Wichita
GY3
Wichita
How about a Mopar electronic dist. triggering a buried MSD box firing a disguised MSD coil? Done right it would be hard to tell at a glance. Just my 2 The new MSD digital boxes are garbage offshore stuff. We use the older analog 6AL's triggered by an OE Mopar electronic distributor and an OE Mopar coil for spark. Stock look and you can find analog 6AL's virtually everywhere! The 6AL is hidden under the battery tray and has the advantages of a rev limiter and an added timing controller in the form of a knob on the dash (for nitrous retard). This basic setup has been bulletproof in two different cars for years.
[Re: Sniper]
#2863301
12/22/20 11:44 AM
12/22/20 11:44 AM
GY3
Wichita
There is not a failure proof system nowdays. So I would stick with Pertronix yet for the easy conversion on stock look. Points are a whole lot less failure prone than the offshore electronic crap being foisted on us these days. The problem is the replacement points are offshore garbage now as well. You have to find an older set to get quality.
[Re: GY3]
#2863431
12/22/20 04:01 PM
12/22/20 04:01 PM
Posts: 19,641 north of coder
moparx
There is not a failure proof system nowdays. So I would stick with Pertronix yet for the easy conversion on stock look. Points are a whole lot less failure prone than the offshore electronic crap being foisted on us these days. The problem is the replacement points are offshore garbage now as well. You have to find an older set to get quality. you treed me with your statement above about the offshore points available, which you most likely have to order as well. last year [2019] i had a new, just installed set toss one of the contacts after just a few minutes run time. back in the mid to late 60's, we always had a match book [even those are kinda hard to come by today ! ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) ] in the glove box to gap points on the road. i have even gapped just the springs to get home ! that took a bunch of fiddling to do to get [semi] right [imagine doing this at night using your buddy to hold your zippo while you are fiddling with what is left of the points after you have had a "few teas" [ ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) ], but it worked long enough to get home. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: GY3]
#2863743
12/23/20 05:01 AM
12/23/20 05:01 AM
NachoRT74
Valencia, España
Won't requote all the quoting lines, but once again there is NO a failure proof system nowdays INCLUDING POINTS, sooo since he is requesting for an upgrade from points and being Pertronix a system which keeps your stock system and look I still would go with it.
Even the ballast can still be in place since if you want or need to bypass it, just need a jumper wire ( no need to cut and splice wires together )... or even replace the resistor element from back of the ceramic and install a wire in place to make a cleaner look.
[Re: NachoRT74]
#2863752
12/23/20 07:06 AM
12/23/20 07:06 AM
Posts: 21,509 It's a dry heat
gtx6970
It's a dry heat
There is not a failure proof system nowdays. So I would stick with Pertronix yet for the easy conversion on stock look. This is exactly why I will stay with points. I dont need to breakdown along the road due to a system that NO ONE stocks parts for locally. I about to buy some NOS mopar and standard electronics points and condensors , plus a couple tan caps . Just to put on the shelf ,,, as a just in case
[Re: gtx6970]
#2863758
12/23/20 07:59 AM
12/23/20 07:59 AM
NachoRT74
Valencia, España
yeah, well, if wished to keep with points and get acces to good quality parts that's a good idea, but is he still wish the upgrade ( for whatever reason ) I wouldn't get worried about Pertronix "quality issues" over the rest of options.
[Re: Alchemi]
#2865118
12/27/20 12:47 AM
12/27/20 12:47 AM
Posts: 259 Khemi, Stygia
Mebsuta
Khemi, Stygia
So some food for thought for points users
A while back I was having hassles setting a consistent gap on my 383, so I measured every gap for a full rotation, there was a .004 spread and it was very random from lobe to lobe. It was a 50+ yo distributor so no real surprises there, but I wonder how true they were from factory? I wonder how many old cars that were hard to tune were from this? The mind boggles
A pedantic person could go through and file/polish down the taller ones to ensure an even gap, I just set the gap off one of the ones in the middle of the variance - so only a +/- .002 difference at most, not ideal as such, but a much better result than if I had randomly set it off one of the + or - .002's
In retrospect a dial gauge would be the easiest way to check that - didnt have one back then lols I use points. All the distributors I have tried had mysterious problems except something called an Accel Blueprinted Distributor. I got it from PAW a long time ago and it has always worked for me. If it ever wears out I guess I'll have to switch to electronic.
68 Roadrunner. 383 4-spd. Beat up.
[Re: michiganhotrod1]
#2865497
12/27/20 10:40 PM
12/27/20 10:40 PM
Posts: 10,234 Someplace you aren't
SomeCarGuy
The reason I don’t like points is an old super stock racer showed me how many were bad out of the box. He had stacks of them from when he would test several on his sun machine before a race. These were back when these cars were pretty much new. Had boxes and boxes so he could always get a handful of good sets to take with him. Lost a race and started really watching for the problem after that. That all stopped when his Chrysler contact scored him the then new electronic stuff. Couple that with my desire to work about an hour on a car, then drive the rest of the day, and forget about a chore that can be eliminated with one swoop. As long as good stuff can be obtained that is.
I want my fair share
