Restoring leaf springs on AAR
#2862752
12/20/20 09:52 PM
12/20/20 09:52 PM
Posts: 2,403 WASHINGTON, PA
11secaarcuda
WASHINGTON, PA
Looking for factory Mopar part numbers for the following parts for my leaf springs: The locating pin and nut (this holds the spring pack together) Zinc liners between the springs (there are 2 sizes) Plastic liners Any help is appreciated. Thanks.
67 Dart GT 340 4 speed 70 AAR Cuda 408 6 barrel 96 Indy Ram original owner 2011 Hemi Durango
Re: Restoring leaf springs on AAR
[Re: 4406bbl]
#2862844
12/21/20 04:39 AM
12/21/20 04:39 AM
Posts: 1,923 Medina, Ohio
HEMICUDA
Medina, Ohio
Frank Badalson has a nice kit. The center bolt and nut are a little different so save your originals, even in the 70s and 80s when you ordered original bolts they were not quite the same, and the nut was shorter, just a generic part at least when I ordered some. Frank's kits have the correct zinc liners Frank 804-275-2155 sixpackfrank@aol.com
