hemi rockers #2862078
12/19/20 10:53 AM
12/19/20 10:53 AM
bonney lake washington
W
w2stroker Offline OP
W
i'm in the process of building an alcohol blown hemi to go 10.5 outlaw racing. down to the last few parts i need to buy. i could use recommendations on what rocker arms to buy and a good place to buy from. indy? stage 5? i'm also looking for an msd mag drive, blower intake, and fuel pump to work with my enderle injection if anyone has leads. Thanks!!!
Re: hemi rockers [Re: w2stroker] #2862165
12/19/20 02:39 PM
12/19/20 02:39 PM
Cab_Burge Online work
Cab_Burge  Online Work
Who heads are you using?
Hemiroid heads and rocker gear can be a real pain too get them where they will RPM pass 7500 RPM whiney
Don't buy cheap or rebuilt and blue printed stocker types either tsk
See if you can look at Ray Barton rocker set ups and for which head he makes them for scope twocents
Re: hemi rockers [Re: Cab_Burge] #2862173
12/19/20 03:08 PM
12/19/20 03:08 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
If you have longer valve stems, it makes a difference. I had a hard time getting good geometry with landy rockers and .100 longer stems. Stage V was spot on, I got them from FHO
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: hemi rockers [Re: Cab_Burge] #2862179
12/19/20 03:16 PM
12/19/20 03:16 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
iagree
If you building a tru Blown alky motor your not considering Indy stuff (not bashing Indy just just another level of performance). Typically the intake and heads come from the same mfg, for instance I use Veney Heads and intake. If you have Brad heads you use a Brad intake and so on. Your not going to get much better than Stage V. How about a list of what parts your using? Everything is bigger on a blown alky motor 7/16th push rods for instance, The Rods are beefier, Piston pins 1.09"... The Blown alcohol Hemi is kinda like a SB Chevy. There are a lot of parts mfgs and sellers out there.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: hemi rockers [Re: W.I.N. Racing] #2862235
12/19/20 05:54 PM
12/19/20 05:54 PM
W
W
Originally Posted by W.I.N. racing
iagree
this is certainly the help i'm looking for and thanks to all who chime in. my one shot at doing it right so not afraid to spend where it counts. what i have so far is a fresh kb stage 5 solid block. aries piston, gmp aluminum rods, bryant billet crank, donovon gear drive, msd pro mag 44 minus drive, little field 14-71 with enderle injection. the heads are a vintage kb set off of a alcohol funny car from the 80's. i'll check the pn on it tomorrow. will be ordering a turbo 400 with no first gear on monday. car is a tube chassis duster.
Re: hemi rockers [Re: w2stroker] #2862236
12/19/20 05:58 PM
12/19/20 05:58 PM
New York
polyspheric Offline
polyspheric  Offline
New York
little field 14-71
What does the discharge side look like - rectangle or triangle?
Boffin Emeritus
Re: hemi rockers [Re: polyspheric] #2862237
12/19/20 06:03 PM
12/19/20 06:03 PM
W
W
rectangle and it is a stripped blower
Re: hemi rockers [Re: w2stroker] #2862245
12/19/20 06:18 PM
12/19/20 06:18 PM
W
W
The short block and blower
Re: hemi rockers [Re: w2stroker] #2862248
12/19/20 06:19 PM
12/19/20 06:19 PM
W
W
I cant seem to figure out how to get the blower pic to attach
Re: hemi rockers [Re: w2stroker] #2862254
12/19/20 06:27 PM
12/19/20 06:27 PM
W
W
The chassis
Re: hemi rockers [Re: w2stroker] #2862263
12/19/20 06:56 PM
12/19/20 06:56 PM
Byron, NY
Byron, NY
Fixed it for you.
Relay doesn't matter what blower discharge you have, your going to make more power than you need. I use a full opening and just set my fuel system for it. I'm not running a Pro/mod so I don't worry about it. I see your out in WA, contact Spud Miller at FIE, he can help with your ignition and fuel system flowing. RBS superchargers is a good source as is Good Vibrations for the hundred or so little items your going to need.
'60 Willys CJ5
