Re: Kickdown
[Re: JFChallenger440]
#2860967
12/16/20 07:18 PM
12/16/20 07:18 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Kick down is the wrong word for it....it is a Throttle pressure linkage...and if it not install...the clutch pac burns up....so have a good time..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
Re: Kickdown
#2861142
12/17/20 08:20 AM
12/17/20 08:20 AM
Posts: 21,819 Kirkland, Washington
Pacnorthcuda
Sorry I’m just trying to understand this but what is the difference between having a kick down and not having one where you Just drop down into 2nd gear everytime ? It’s not a manual valve body , thanks Somebody like Kunkel or Transman can explain it better than I but a stock T-flite REQUIRES the linkage or it WILL burn up its clutches due to slippage. Do not drive the car until you get the linkage installed. I bought a car without (a 440 Cuda) back in 1992. Transmission was already acting up (would slip under high load) and as I tried to get the linkage installed over the course of a few weeks it died.
Re: Kickdown
[Re: Pacnorthcuda]
#2861144
12/17/20 08:23 AM
12/17/20 08:23 AM
Pacnorthcuda
And start learning about the adjustment. You want the lever at the tranny to start moving as soon as the carb linkage starts moving off-idle. The Lokar system works, but can be a pain due to the length of travel not being exactly right for a T-flite, but there are ways of dealing with that. If you can source a stock linkage get it!
Re: Kickdown
#2861204
12/17/20 10:55 AM
12/17/20 10:55 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Just wondering how many people on here don’t have a kickdown cable ?
The Charger I have just bought doesn’t have one and I was considering buying the kit but thinking more of it I don’t think it would bother me too much just to drop down to 2nd gear manually everytime I want some hard acceleration, in fact I kind of like the idea of controlling it manually
Any thoughts ?
Thanks Stay away from aftermarket junk cable "kickdowns". Just go get the correct factory piece and adjust it. When adjusted it will respond w/o the need to shift it manually. As mentioned you MUST run a "kickdown" or you will destroy the transmission.
Re: Kickdown
[Re: Mr.Yuck]
#2861275
12/17/20 12:55 PM
12/17/20 12:55 PM
Posts: 4,404 Michigan
MarkZ
Worthy
Worthy
Any thoughts ?
Thanks Stay away from aftermarket junk cable "kickdowns". Just go get the correct factory piece and adjust it. When adjusted it will respond w/o the need to shift it manually. As mentioned you MUST run a "kickdown" or you will destroy the transmission. What's wrong with the cable kits? I'm using a Lokar on my 518 and it works just fine. Haven't touched it since I put the motor in the car.
Re: Kickdown
[Re: MarkZ]
#2861294
12/17/20 01:53 PM
12/17/20 01:53 PM
Posts: 2,806 Northern NJ
StukaJU87
Northern NJ
Any thoughts ?
Thanks Stay away from aftermarket junk cable "kickdowns". Just go get the correct factory piece and adjust it. When adjusted it will respond w/o the need to shift it manually. As mentioned you MUST run a "kickdown" or you will destroy the transmission. What's wrong with the cable kits? I'm using a Lokar on my 518 and it works just fine. Haven't touched it since I put the motor in the car. I used the Bouchillon kit on my 440/727 combo in my old 69 wagon. The kit worked flawlessly.
Scott
1969 Super Bee, 383/4 speed
Re: Kickdown
#2861304
12/17/20 02:17 PM
12/17/20 02:17 PM
Posts: 3,069 Michigan
A727Tflite
Any thoughts ?
Thanks The problem you are facing is that you believe the only purpose for the “kickdown linkage/cable” is for downshifts. Besides the throttle pressure linkage controlling downshifts and upshifts based on throttle pressure/throttle opening is that it also increases line pressure when the throttle is opened. So without it you could pull the shifter down to a lower gear (and if you go deep in the throttle) without increasing the line pressure you would smoke the clutches and bands. Or, do a manual upshift from 1-2-3 and again go deep in the throttle you would burn the trans up. Hope that clears things up for you.
Re: Kickdown
[Re: MarkZ]
#2861314
12/17/20 02:30 PM
12/17/20 02:30 PM
Mr.Yuck
Brookeville, Md
Any thoughts ?
Thanks Stay away from aftermarket junk cable "kickdowns". Just go get the correct factory piece and adjust it. When adjusted it will respond w/o the need to shift it manually. As mentioned you MUST run a "kickdown" or you will destroy the transmission. What's wrong with the cable kits? I'm using a Lokar on my 518 and it works just fine. Haven't touched it since I put the motor in the car. I bought a Lokar, that thing was a total POS. I could never get it adjusted right. I was trying to get it right at the track and ended up throwing in the trash. I used my old stock unit and modified it with a piece of beer can and it worked perfectly. They are junk, there mounting bracket is flimsy AF...at least 15 years ago they were. I'd never use one again, way to easy to modify a stock unit.
Re: Kickdown
[Re: Pacnorthcuda]
#2861397
12/17/20 04:45 PM
12/17/20 04:45 PM
Posts: 1,978 USA
Suregrip391
USA
That rod does not look like it’s correct, the one in the yearone pic is. Atleast I’ve never seen that style on a 66-70
Re: Kickdown
#2861735
12/18/20 01:03 PM
12/18/20 01:03 PM
Posts: 25,747 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Thanks for the replies , I am just missing 1 rod for the old linkage system so will go with that rather than Lokar If your carb is aftermarket, be sure to use the correct throttle lever extension or the linkage won't work right.l
