Re: Looking to buy 2005 Dakota 4.7HO
[Re: DaytonaTurbo]
#2860495
12/15/20 09:34 PM
12/15/20 09:34 PM
Posts: 10,486 Freeport IL USA
poorboy
Freeport IL USA
I don't think I would be wailing on that thing. Lots of trucks for sale with blown 4.7's. Lots of trucks scrapped for just that reason. For the most part, you have purchased a fragile piece of equipment. If you have hope of it making it to the 150K miles, you would have a better chance of getting there by not abusing it. A 4.7 is not of the family of Mopars past. What ever you do, DO NOT let it overheat! One time will kill it. My brother in law bought a Dakota with a 4.7 brand new. It got all the recommended service from our local Dodge dealership, and he has never abused his stuff. He got 60,000 miles out of the first 4.7. He bought another new Dakota with a 4.7 and got just over 75,000 from it. He no longer drives Dodge trucks. Gene
[Re: JDMopar]
#2860841
12/16/20 03:26 PM
12/16/20 03:26 PM
Posts: 12,493 Western Colorado High Desert
moparmarks
Around here you can buy a real nice Dakota with a blown 4.7 for around 800.00 My machinist says they are junk. Oiling problems, dropping valve seats and a piss pour timing chain tensioner design. He charges 4000.00 to rebuild one and make it right except for the tensioner. Nobody makes a better one.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: JDMopar]
#2860846
12/16/20 03:33 PM
12/16/20 03:33 PM
Posts: 453 PNW
Beebuzzn
PNW
Wow, don't know now if I should sell and get something else or take a gamble of getting some miles out of it. I've read many conflicting stories on 4.7 engines over the last couple days and it sure seems a 50/50 deal to make the 150k mile mark. Truck sure is a nice driver, very comfy and quiet but only gets about 11.5 mpg city driving. I guess that might be impacted from the AWD system ? is the AWD 4x4 drivetrain problematic also ? Have 2018 ford RCSB I'm installing whipple on and bought Dakota for work rig, hum....have to check into what remanufactured engines go for a worse case..... Thanks all for input
[Re: Beebuzzn]
#2860907
12/16/20 04:51 PM
12/16/20 04:51 PM
Posts: 5,997 Salem
Grizzly
Moparts Proctologist
Salem
Pfft, I'd be more concerned about that complicated Ford than a 4.7 Dakota. If it pukes, it just gives you a great reason to swap a 5.7 in.
Mo' Farts
Moderated by "tbagger".
[Re: Beebuzzn]
#2860969
12/16/20 07:24 PM
12/16/20 07:24 PM
Posts: 8,473 Candler,NC / Myrtle Beach, SC
JDMopar
Wow, don't know now if I should sell and get something else or take a gamble of getting some miles out of it. I've read many conflicting stories on 4.7 engines over the last couple days and it sure seems a 50/50 deal to make the 150k mile mark. Truck sure is a nice driver, very comfy and quiet but only gets about 11.5 mpg city driving. I guess that might be impacted from the AWD system ? is the AWD 4x4 drivetrain problematic also ? Have 2018 ford RCSB I'm installing whipple on and bought Dakota for work rig, hum....have to check into what remanufactured engines go for a worse case..... Thanks all for input Mine was $2799, and worth every penny! I couldn't find anyone to rebuild it locally. A lot of places said they'd do the machine work, but nobody wanted to fool with the Rubik's Cube timing chains! Powertrain was very easy to deal with, and they do a lot of upgrades to make the engines better than they wee from the factory. I checked with Jasper and Carolina Machine, and neither one acted like the cared whether I bought their engine or not. Everybody I dealt with at Powertrain bent over backwards to help me. I would buy from them again in a heartbeat! My 4.7 I got from them hasn't leaked or burnt the first drop of oil, nor has it made the first tick or noise. Keep them in mind if you ever need a motor. https://www.powertrainproducts.net/DODGE-4-7-V8-ENGINE-99-06-DAKOTA-RAM-1500-GRD-CHK-p/1341.htm
[Re: Beebuzzn]
#2861790
12/18/20 02:58 PM
12/18/20 02:58 PM
Posts: 3,365 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
For what it's worth, I got 230,000 out of my 03 2WD Dakota before a guy rear-ended it while parked in front of the house.
Lifters clattered like crazy for about 60-90 seconds on cold start every morning, but other than that I never had a major issue with it.
The water pump once puked on me on the way to work one morning, but luckily I got it pulled over and shut off FAST before it overheated...
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: wingman]
#2861952
12/18/20 09:06 PM
12/18/20 09:06 PM
moparmarks
Ya it is a crap shoot. Same with the early 5.7 Hemi. Know of some that made it well over 200K and others that either dropped a valve seat or burned a bearing before 100K.
[Re: moparmarks]
#2877903
01/21/21 03:08 PM
01/21/21 03:08 PM
Posts: 12,408 Kalispell Mt.
HotRodDave
Kalispell Mt.
the main problem with that 4.7 is the timing chain set up, replace it immediately if you buy the truck, it should be done as preventative maintenance at 100,000-150,000 miles, the trouble you will run into with that plan is that most shops are terrified to work on one, they are not that hard. The chains start slapping and most shops say the engine is blown up instead of doing the chains, tensioners and guides. The other issues that come up are valve seats and head gaskets going bad when overheated (don't overheat it and those will not be issues) and the rockers falling off when parked a long time (there are thingies you can get to put on that keep them from going anywhere when the "lifter" deflates that are very easy to install before you have an issue). They are not a good engine to drive and ignore like a 318 but the issues are not insurmountable.
