anything can be made to fit if a guy has enough fabrication skills !
seriously now. not having those columns in front of me to compare, i'll go out on a limb [of course with a running chainsaw
] and say it's possible.
i'm "guessing" you can use the 76 shaft to install in the 68 column, but if i were doing this, i would just "collapse" the 68 shaft and use whatever splined coupling shell you need to connect the column shaft to the power box.
if i remember correctly, the power box is approximately 1 1/2" longer than the manual box.
all of the columns i have taken apart allow the shaft to collapse 8 or 9" in a crash, so there will still be enough "crash protection" [in my opinion] to "shorten" the shaft a little.
the plastic injection "pins" shear easy, and the rest of the plastic remains around the flat part of the shaft to support the two pieces.
use caution when tapping the shaft shorter, and measure carefully when deciding how much the shaft needs to be shortened.
i hope this "explanation" is clearer than any mud i may have caused.
you can do it ! i have faith in you !
please keep us updated.
