Re: RR project 700 hp street/strip
[Re: Since1822]
#2877828
01/21/21 01:09 PM
01/21/21 01:09 PM
Posts: 31,082 Oregon
AndyF
Looks great Andy! Have you thought about making your valley plates with a removable center? Wondering if that is the trick flow one? I was making plates with a removable center before Trick Flow came along. I stopped making them when Trick Flow started to sell theirs.
[Re: DFlanagan]
#2878937
01/23/21 02:45 PM
01/23/21 02:45 PM
Posts: 19,641 north of coder
moparx
they look like the "made for you" [?] brand. if that's not the brand, try looking up nylon plug wire separators. i know they are made in several sizes, at least 7, 8, 8.5, and 10mm. you can find these on the 'bag, or amazon.
[Re: AndyF]
#2879696
01/24/21 11:47 PM
01/24/21 11:47 PM
Posts: 1,545 USA
hudsonhornet7x
USA
I'm still working on the electrical system. I have a couple of the new wiring harnesses built and have a couple more to go. Looks like the best way to go is to mount a small relay module under the battery tray. The relays will handle the fuel pump as well as both electric fans. Looks very nice Andy. I would like to know more about the battery. What is it? What needs changed in the electrical system to run it? Since this car will be street driven and not just raced, I am very curious. Thank you.
[Re: AndyF]
#2879726
01/25/21 01:19 AM
01/25/21 01:19 AM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
It is a half sized battery from Braille. Nothing in the electrical system needs to be changed to run it, you just need a good alternator to keep it charged. I use the same battery in both of my cars. What alternator do you run with it?
[Re: mopowers]
#2879895
01/25/21 02:18 PM
01/25/21 02:18 PM
AndyF
I use a Denso alternator on anything I build.
[Re: RROD]
#2885355
02/07/21 10:46 PM
02/07/21 10:46 PM
Posts: 1,545 USA
hudsonhornet7x
USA
What block are you using? I see cross bolt main bolts. It looks like a modified stock block to me, but I could be wrong.
[Re: DirectConnection]
#2885404
02/08/21 01:33 AM
02/08/21 01:33 AM
AndyF
what is the wheel tire combo upfront backspacing etc
looks great Tires are 225/70-15. I don't know the wheel specs.
